Forum Index : Microcontroller and PC projects : Colour Maximite 2 (CMM2) V7.00.00 release candidates
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 6286 |
Peter, I found the issue with the write protect switch (bent pin on switch on socket, detecting write protect on some cards, and not on others). But the other issues (like the status line in above picture) I have not been able to repair. - I cleaned the contacts (contact cleaner with oil). - I replaced the micro-sd to sd adapter - I tested with another uSD card in the same adapter - I tested with a full size SD card I always get the status line. This is V7 (not yet V8). Please confirm that status line should not be there. It exists since you edit a program and save it (F1), and after that each new power-on. If this is not normal, I have to oder a new SD socket and replace the old one, since there must be something wrong inside it. Volhout PicomiteVGA PETSCII ROBOTS |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12264 |
The status line should be there at all times you are not running a program |
Hi Peter, Including the text "Check Disk"...?? In the filemanager, when renaming a file, the yellow text (where you type the new name" is overlayed with this status line the moment you release a keyboard key. I thought this was an error on the SD card. But it is an error in the filemanager then ? Volhout P.S. does the editor have an option "SAVE AS" ? Where you can save under a new name. I currently rename the .BAK file in the filemanager, end then edit that one. Sorry if I confuse, have been so used to Pico that this all feels new. Edited 2026-11-23 06:05 by Volhout PicomiteVGA PETSCII ROBOTS |
rename is a bug on the connected screen but works on teraterm - will fix Please try the V8.00.00b3 release from github which should fix it. Edited 2026-11-23 08:07 by matherp |
Hi Peter, That fixed it. From now on I will be in the V8 thread. Volhout PicomiteVGA PETSCII ROBOTS |
