Local Time 05:06 23 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Bummer .....
hitsware2
Posted: 03:12pm 03 Nov 2021
I am reminded to attach all ground pins on the PicoMite .
I only have one attached
my site
Posted: 04:24pm 03 Nov 2021
I usually ground one or two on each side. I don't bother otherwise. The AGND does need to be "clean" for best results when using the analogue inputs. It's not connected to the main ground, it's attached to a separate ground plane beneath the analogue lines and, I think, part of the RP2040.
Tinine
Posted: 02:12pm 04 Nov 2021
This works perfectly
Edited 2021-11-05 00:14 by Tinine
Posted: 02:28pm 04 Nov 2021
  Tinine said  This works perfectly
What are we looking at here?
Only when I noted what the image file is named do I have much of a clue: PGA2040 Running MMBasic.PNG (aside from the raspberry pi logo on the chip).
Tinine
Posted: 02:30pm 04 Nov 2021
This one from Pimoroni
Posted: 03:32pm 04 Nov 2021
Oh, what a pretty blob! :)
Tinine
Posted: 05:02pm 04 Nov 2021
OK, looks like I bricked it.
Attempted to go above 250MHz and MMBasic complained. Selected 245MHz and, as expected, lost the connection. Would not reconnect, port no-longer shows-up in device manager and of course, can't re-flash.
Posted: 05:11pm 04 Nov 2021
Aawwww....  Poor little thing...  :(
Tinine
Posted: 05:15pm 04 Nov 2021
  Mixtel90 said  Aawwww....  Poor little thing...  :(
Nope...it's back again
No amount of unplugging the USB made a difference but apparently it was Windoze that got its knickers in a twist.
Power-cycled the PC and all was good. Nuked the flash and re-flashed with MMBasic...all good
Edited 2021-11-05 03:16 by Tinine
Posted: 07:13pm 04 Nov 2021
Excellent news on the Phoenix chip!
At least you know its top speed now. :)
Posted: 07:22pm 04 Nov 2021
  Quote  Selected 245MHz and, as expected, lost the connection
The speed has to be such that the PLL can generate the 48MHz clock for USB. I haven't tried to check the validity of speeds as nothing I tried has given a problem thus far. Would certainly suggest you stick to multiples of 8 though. Did you try 250MHz which is known good (as is 200)
Edited 2021-11-05 05:23 by matherp
Tinine
Posted: 07:36pm 04 Nov 2021
Yeah, 250MHz seems rock solid. I only tried 245MHz to see if it would take weird values.
I kinda like this module because I can have my own beefy USB connector. Micro USB is too puny.
Tinine
Posted: 07:53pm 04 Nov 2021
  Mixtel90 said  Excellent news on the Phoenix chip!
Pretty funny because my control system is branded "Phenix" (no 'o')
Posted: 08:35pm 04 Nov 2021
Obviously made for each other.
hitsware2
Posted: 09:41pm 06 Nov 2021
Happy to say !
This One
Working fine ( V5.07.01b5.uf2 )
Evedently I got my wires crossed with the first one
my site
Posted: 10:26pm 06 Nov 2021
Nice little board. :)
hitsware2
Posted: 10:51pm 06 Nov 2021
Yes ....
my site
Posted: 10:59pm 06 Nov 2021
Tiny, innit? lol
hitsware2
Posted: 02:11am 16 Nov 2021
  Mixtel90 said  Tiny, innit? lol
And Works Like a Charm !
Edited 2021-11-16 12:12 by hitsware2
my site
