Local Time 10:22 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite i2c scanner
Calli
Posted: 06:10pm 28 Oct 2021
I did a i2c scanner like i2cdetect in linux.
Maybe helpfull for stuff :) (I try to get a VL53L0X to talk to me)
' i2cdetect like program
' Set Pins!
SetPin gp8, gp9, I2C
' Open first I2C
I2C open 100, 200
' Prep table
Print "     0  1  2  3  4  5  6  7  8  9  A  B  C  D  E  F"
' loop col/row
For y=0 To 7
 Print Hex$(y,2);": ";
 For x=0 To 15
   addr = y*16+x               ' calc address
   I2C write addr, 0, 1, &H00  ' write zerp to that adress
   If MM.I2C=0 Then            ' check for errors
     Print Hex$(addr,2);" ";   ' found one!
  Else
    Print "-- ";               ' nothing here..
  EndIf
 Next x
 Print
Next y
I2C close  ' clean up
Output:
00: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
01: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
02: -- -- -- -- -- -- -- -- -- 29 -- -- -- -- -- --
03: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
04: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
05: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
06: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
07: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
Best,
Carsten
Posted: 06:19pm 28 Oct 2021
That looks useful, thanks. :)
twofingers
Posted: 06:42pm 28 Oct 2021
Hi Carsten,
welcome to the TBS!
Your scanner seems very usefull and good looking!
I hope there will be a lot more code examples!
FYI: A similar scanner was one of my first projects for MMBasic too.
Best regards
Michael
Edited 2021-10-29 04:44 by twofingers
Calli
Posted: 08:03pm 28 Oct 2021
  twofingers said  Hi Carsten,
welcome to the TBS!
Best regards
Michael
Sharing is caring :)
Thanks!
Carsten
steview_de
Posted: 08:21pm 07 Dec 2022
Hey Calli,
thanks for the useful code.
Due to "OPTION  xxx" i dont need SetPin and I2C open for my purpose.
"Stevie"
Posted: 09:14pm 07 Dec 2022
Here is a PicoMite System I2C and I2C2 Address Scanner.
Print "PicoMite System I2C and I2C2 Address Scanner"
SDA = 4 : SCL = 5 ' I2C2 pins. Change pins to your usage, 0 if no I2C2
' (Do NOT use GP numbers, standard Pico RP2040 module pin numbers only)
Print
again = 1
Print "For System I2C"
Scan
If SDA Then
  SetPin SDA, SCL, i2c2
  I2C2 open 100,1000
  Print "For I2C2 - SDA = Pin("SDA"), SCL = Pin("SCL")"
  again = 0
  Scan
  I2C2 close
 Else
  Print "I2C2 not configured"
EndIf
Sub Scan
 Print "     0  1  2  3  4  5  6  7  8  9  A  B  C  D  E  F" ' Prep table
' loop col/row
 For y=0 To 7
  For x=0 To 15
   If again Then
     On Error Skip 3
     I2C write addr, 0, 1, &H00  ' write 0 to that adress
    Else
     I2C2 write addr, 0, 1, &H00  ' write 0 to that adress
   EndIf
   If MM.Errno = 0 Then
       device=addr
      Else
     EndIf
    Else
     Print " I2C not configured"
   EndIf
  Next x
'  -------------- Add your favorite devices here ------------------
  If device = &H68 Then : Print "RTC DS3232, DS1307 etc"; : device=0 : EndIf
  If (device > &H49) And (device < &H58) Then : Print "24Cxx EEPROM"; : device=0 : EndIf
  If device = &H3C Then : Print "LCD SSD1306"; : device=0 : EndIf
  Print
 Next y
 Print
End Sub
