Local Time 12:23 21 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Dittering Pictures to PicoMite
     Page 2 of 3
Martin H.
Posted: 08:17am 24 Dec 2022
I Found a Video where javidx9 (One lone Coder) explains, how to Program Dithering Floyd-Steinberg Dithering. Seems to be not much, so I'II give it a try next week.
Dithering with Floyd-Steinberg in C++
'no comment
Martin H.
Posted: 08:22am 24 Dec 2022
  scruss said
Here are the BMPs generated from the above two commands:
dithering.zip
Thank you for showing another option.
Very nice Output Pictures. Good Job
For using them on the Pico, they have to be transfered back to 24Bit BMP or to Jpg.
  Mart!n
Edited 2022-12-24 18:23 by Martin H.
'no comment
homa
Posted: 08:52pm 30 Dec 2022
Hello,
I have found the following tool: http://christoph.laeubrich.de/files/uploads/19/grafikkonverterv1_4.zip
Detail here: https://www.mikrocontroller.net/topic/92623   or also here https://github.com/laeubi/grafikkonverter-tool
Unfortunately you have to enter the 16 colors once as a palette at the beginning, this can also not be saved :-(
Maybe someone can do something with the sources ...
Results see attached.
London extracted from the input post. The bird and a test picture of me ...
homa
Posted: 08:59pm 30 Dec 2022
Martin H.
Posted: 03:29pm 31 Dec 2022
Nice,
Unfortunately I don't know enough about Java to find the part, where you could store or load the palette.
The results are really great.
btw: Happy New Year
Edited 2023-01-01 01:30 by Martin H.
'no comment
homa
Posted: 09:00pm 31 Dec 2022
If then true to style ;-)
Happy New Year!
Martin H.
Posted: 03:05pm 02 Jan 2023
  homa said   _
I Think I've found the(by now) best solution.
Here is an Online Ditherer, where you can save (copy and Past) a Custom Color Palette and it dithers in many different ways:
https://ditherit.com/
the Custom Palette for the Pico to past in looks like this:
[{"hex":"#000000"},
{"hex":"#FF0000"},
{"hex":"#0000FF"},
{"hex":"#FF00FF"},
{"hex":"#004000"},
{"hex":"#FF4000"},
{"hex":"#0040FF"},
{"hex":"#FF40FF"},
{"hex":"#008000"},
{"hex":"#FF8000"},
{"hex":"#0080FF"},
{"hex":"#FF80FF"},
{"hex":"#00FF00"},
{"hex":"#FFFF00"},
{"hex":"#00FFFF"},
{"hex":"#FFFFFF"}]
Here the london png with Atkinson dithering looks like this
Mart!n
Edited 2023-01-03 01:25 by Martin H.
'no comment
Posted: 07:32pm 02 Jan 2023
Nice tool, this will help create better graphics.
Martin H.
Posted: 08:46pm 13 Oct 2025
Working on the illustration for Colossal Cave Adventures has resulted in significant changes to my MMB 4 Windows tool.
The program now determines the color thresholds itself.
First, the statistical mean for each color (RGB) is calculated for 8x8 pixel blocks, then the median of this list is determined from all the values.
These values are used as the threshold values.
These values can be changed later using buttons.
becomes
'MMB4W Modes etc. Loads a source PNG and translatet it to 121 RGB BMP
'Enter Source Filename here
FN$="testapple"
Mode 1
dim w, h as integer
open FN$ + ".png" for input as #1
s$ = INPUT$(24, #1) ' Erste 24 Bytes holen (bis Ende IHDR-Header)
' Breite aus Byte 17-20 (Index 16–19 in MMBasic, da 0-basiert)
w = ASC(MID$(s$,17,1))*16777216 + ASC(MID$(s$,18,1))*65536 + ASC(MID$(s$,19,1))*256 + ASC(MID$(s$,20,1))
' Höhe aus Byte 21–24 (Index 20–23)
h = ASC(MID$(s$,21,1))*16777216 + ASC(MID$(s$,22,1))*65536 + ASC(MID$(s$,23,1))*256 + ASC(MID$(s$,24,1))
close #1
BL%=(h*w)/64
Dim integer listR(BL%)
Dim integer listG(BL%)
Dim integer listB(BL%)
cls
load png FN$+".png"
Prescan
Scan
ui
save image FN$+".bmp",0,0,w,h
end
sub Scan
for y=0 to h
   for x=0 to w
       cl%=0
       n=Pixel(x,y)AND &HFFFFFF
       '-->get Red
       r=n AND &HFF
       'Check red thresholds if value is in then dither
       if r>LR and r<UR then
        if (y mod 2)then
        R=255*not (x mod 2)
        else
        R=255*(x mod 2)
        end if
       end if
       inc cl%,255*(r>UR):n=int(n/256)
       '-->get Green
       g=n AND &HFF
       'Check green thresholds, no dithering
       select case g
       case >UG
       inc cl%,&HFF00
       case >MG
       inc cl%,&H8000
       case >LG
       inc cl%,&H4000
       end select
       '-->get Blue
       n=int(n/256)
       b=n AND &HFF
       'Check Blue thresholds, if value is in then dither
       if b>LB and r<UB then
        if (y mod 2)then
        B=255*(x mod 2)
        else
        B=255*not (x mod 2)
        end if
       end if
       inc cl%,&Hff0000*(b>UB)
       pixel x,y,cl%
   next
next
End sub
sub ui
Font 2
px=w+6
do
Print@(px,0);"           threshold values"
Print@(px,20);"      RED       GREEN        Blue"
Print@(px,40);"    Q ";make$(LR);" W    E ";make$(LG);
PRINT " R      O ";make$(LB);" P"
Print@(px,60);"    A ";make$(UR);" S    D ";make$(MG);
PRINT " F      K ";make$(UB);" L"
Print@(px,80);"               C ";make$(UG);" V"
Print@(px,100);
Print@(PX,120);" SPACE = Repaint"
Print@(PX,140);" Enter = Save&Exit"
Print@(PX,160);"   ESC = Exit without Save"
do :k$=inkey$:Loop while k$=""
k$=Ucase$(k$)
select case k$
case "Q"
if LR>0 then inc LR, -1
case "W"
if LR<UR then inc LR
case "E"
if LG>0 then inc LG, -1
case "R"
if LG<MG then inc LG
case "O"
if LB>0 then inc LB, -1
case "P"
if LB<UB then inc LB
case "A"
if UR>LR then inc UR, -1
 case "S"
 if UR<255 then inc UR
  case "K"
if UB>LB then inc UB, -1
 case "L"
 if UB<255 then inc UB
   case "C"
if UG>MG then inc UG, -1
 case "V"
 if UG<255 then inc UG
     case "D"
if MG>LG then inc MG, -1
 case "F"
 if MG<UG then inc MG
 case " "
 load png FN$+".png"
  Scan
case chr$(13) ,chr$(10)
  Exit SUB
 case chr$(27)
  End
end select
loop
end sub
Function  make$(Value)
make$=STR$(Value)
do while (len(make$)<3)
 make$="0"+make$
loop
end Function
sub Prescan
FOR y = 0 TO h - 8 STEP 8
 FOR x = 0 TO w - 8 STEP 8
   sumR = 0 : sumG = 0 : sumB = 0
   FOR dy = 0 TO 7
     FOR dx = 0 TO 7
       n = Pixel(x + dx, y + dy) AND &HFFFFFF
       r = n AND &HFF
       n = INT(n / 256)
       g = n AND &HFF
       n = INT(n / 256)
       b = n AND &HFF
       sumR = sumR + r
       sumG = sumG + g
       sumB = sumB + b
     NEXT dx
   NEXT dy
   ' Mittelwert pro Block
   blockR = INT(sumR / 64)
   blockG = INT(sumG / 64)
   blockB = INT(sumB / 64)
   ' In Medianliste schreiben
   listR(blockIndex) = blockR
   listG(blockIndex) = blockG
   listB(blockIndex) = blockB
   blockIndex = blockIndex + 1
 NEXT x
NEXT y
pass = 0
do
   tausch = 0
   For ss = 0 To BL% - 2 - pass
       If listR(ss) > listR(ss + 1) Then
           tt = listR(ss):listR(ss) = listR(ss + 1):listR(ss + 1) = tt:tausch = 1
       End If
   Next
   Inc pass = pass
Loop Until tausch = 0
pass = 0
do
   tausch = 0
       If ListG(ss) > ListG(ss + 1) Then
           tt = ListG(ss):ListG(ss) = ListG(ss + 1):ListG(ss + 1) = tt:tausch = 1
       End If
   Next
   Inc pass = pass
pass = 0
do
   tausch = 0
       If ListB(ss) > ListB(ss + 1) Then
           tt = ListB(ss):ListB(ss) = ListB(ss + 1):ListB(ss + 1) = tt:tausch = 1
       End If
   Next
Inc pass = pass
LR=listR(BL%/3)      'Lower threshold Red
UR=listR(2*(BL%/3))  'Upper threshold
LG=listG(BL%/4)'Lower threshold Green
MG=ListG(2*(BL%/4)) 'Mid threshold
UG=ListG(3*(BL%/4)) 'Upper threshold
LB=listB(BL%/3)      'Lower threshold Blue
UB=listB(2*(BL%/3))  'Upper threshold
end sub
Maybe I'll give Atkinson a try after all.
 Martin
Edited 2025-10-14 07:52 by Martin H.
'no comment
dddns
Posted: 10:15pm 13 Oct 2025
Fantastic thread, thank you all! I'm new to grafics and didn't have an idea how to get into that.
Special thanks @scruss:
  scruss said  A couple of other ways to make pre-dithered images using the venerable (okay, maybe just old) Netpbm toolkit:
1.) Ordered dither
djpeg london.jpg | ppmdither -red=2 -green=4 -blue=2 | ppmtobmp > london_ordered.bmp
Result:
Under Linux all there is to do:
apt install libjpeg-progs
djpeg bird_orig.jpg | pnmremap -floyd -mapfile=<(echo P3 16 1 3 0 0 0 0 2 0 0 2 3 3 3 3 0 3 3 3 0 3 3 0 0 3 1 0 3 2 3 3 2 0 3 1 3 0 3 0 3 3 0 0 1 3 0 0 3 0 1 0) | ppmtobmp > bird_orig_FS.bmp
to have that wonderful result and that is exactly how it look on my unmodified VGA:
load image "b:bird_orig_fs.bmp" :  save image "pico_org.bmp"
Thanks a lot!!
Edit:
Weils soo schön ist:
Mode 3 @800x600
Edited 2025-10-14 08:47 by dddns
Martin H.
Posted: 09:38am 14 Oct 2025
sub Prescan Accelerated many times (from 3-4S to 200ms) over and greatly shortened (Sometimes it doesn't hurt to look in the manual)
please replace with:
sub Prescan
   'Determine the average values of each color in the image
   'to auto calculate the thresholds
   'pass1: Sample and store the color-values of 8x8 blocks.
   local integer r,g,b,n,dx,dy,ss
       FOR dy = y TO y+7
         FOR dx = x TO x+7
           n = Pixel(dx, dy) AND &HFFFFFF
           r=n AND &HFF:g=n AND &HFF00:b=n AND &HFF0000
           inc sumR,r:inc sumG,g:inc sumB,b
         NEXT
       NEXT
       ' Values *64 (8x8)pro Block
       listR(blockIndex)=sumR:listG(blockIndex)=sumG:listB(blockIndex)=sumB
       inc blockIndex
     NEXT
   NEXT
   '2.Pass sort the sampled values for each color to find the median
   SORT ListR(), , , ,BL%:SORT ListG(), , , ,BL%:SORT ListB(), , , ,BL%
   LR=listR(BL%/3)>>6      'Lower threshold Red
   UR=listR(2*(BL%/3))>>6  'Upper threshold
   LG=listG(BL%/4)>>14     'Lower threshold Green
   MG=ListG(2*(BL%/4))>>14 'Mid threshold
   UG=ListG(3*(BL%/4))>>14 'Upper threshold
   LB=listB(BL%/3)>>22     'Lower threshold Blue
   UB=listB(2*(BL%/3))>>22 'Upper threshold
end sub
If you can't sleep, you might as well use the time wisely.
'no comment
Posted: 11:11am 14 Oct 2025
Please don't take this the wrong way....
Here is an image on PICOMITE VGA RP2350 Mode 3 so 640x480 RGB121 standard palette
using the new command
timer=0:load dithered "b:/tiger640":?timer
As you can see it took 1.3 seconds to load and draw.
Here is the genesis of the command using CLAUDE
  Quote  write a function to read a bmp file. Assume the file fnbr is already open and you can read it using the function int IMG_FREAD(int fnbr, void *buff, int count, unsigned int *read)
buffer no more than 5 lines at a time. The maximum filesize is 1920x1080.
Write the file to the display using a dithering algorithm to optimise the visual effect. Accept as an input to the function a parameter that specifies whether the display is RGB121 or RGB332. Assume the bmp file uses standard non-compressed RGB888
  Quote  You can use the function DrawPixel(x,y,c) to write to the screen. No start or end frame calls are needed. The display size is HRes *VRes. Add parameters to indicate the x and y coordinates of the image that should map to 0,0 of the display. Ignore pixels in the image that would fall outside of the display.
DrawPixel takes an RGB888 colour so the RGB121 or RGB332 pixels should be expanded to RGB888 in order to call it.
Use (void *)GetMemory(size) to allocate buffer space and (void)FreeMemory(void *) to free it
  Quote  cast all the freememory functions to void * to avoid compiler warnings. Check for the correct bmp file format and raise an error if incorrect using the function void error(char *)
  Quote  To optimise writing you can use the function void DrawBuffer(int x1, int y1, int x2, int y2, unsigned char *p);
to output to the screen. In this case char *p is a pointer to an array of colour triplets R0,G0,B0,R1,G1,B1...Rn,Bn,Gn
  Quote  apologies it should have been colour triplets B0,G0,R0,B1,G1,R1...Bn,Gn,Rn
  Quote  Finally add parameters x_display and y_display that indicate the top left coordinates on the physical display where the image will be drawn
Total time to create the fully working new capability which will be in the next release - less than 1 hour. The world really has changed
Here is the code
// BMP structures
typedef struct __attribute__((packed))
       uint16_t bfType;
       uint32_t bfSize;
       uint16_t bfReserved1;
       uint16_t bfReserved2;
       uint32_t bfOffBits;
} BITMAPFILEHEADER;
       uint32_t biSize;
       int32_t biWidth;
       int32_t biHeight;
       uint16_t biPlanes;
       uint16_t biBitCount;
       uint32_t biCompression;
       uint32_t biSizeImage;
       int32_t biXPelsPerMeter;
       int32_t biYPelsPerMeter;
       uint32_t biClrUsed;
       uint32_t biClrImportant;
} BITMAPINFOHEADER;
// Convert RGB121 to RGB888
void rgb121_to_rgb888_components(uint8_t color, uint8_t *r, uint8_t *g, uint8_t *b)
       uint8_t r1 = (color >> 3) & 1;
       uint8_t g2 = (color >> 1) & 3;
       uint8_t b1 = color & 1;
       *r = r1 * 255;
       *g = g2 * 85; // 255/3
       *b = b1 * 255;
// Convert RGB332 to RGB888
void rgb332_to_rgb888_components(uint8_t color, uint8_t *r, uint8_t *g, uint8_t *b)
       uint8_t r3 = (color >> 5) & 7;
       uint8_t g3 = (color >> 2) & 7;
       uint8_t b2 = color & 3;
       *r = (r3 * 255) / 7;
       *g = (g3 * 255) / 7;
       *b = (b2 * 255) / 3;
// Convert RGB888 to RGB121 with dithering
uint8_t rgb888_to_rgb121_dither(int16_t r, int16_t g, int16_t b)
       // Clamp values
       r = (r < 0) ? 0 : (r > 255) ? 255
                                   : r;
       g = (g < 0) ? 0 : (g > 255) ? 255
                                   : g;
       b = (b < 0) ? 0 : (b > 255) ? 255
                                   : b;
       // Convert to RGB121 (1 bit R, 2 bits G, 1 bit B)
       uint8_t r1 = (r >= 128) ? 1 : 0;
       uint8_t g2 = (g * 3 + 127) / 255;
       uint8_t b1 = (b >= 128) ? 1 : 0;
       return (r1 << 3) | (g2 << 1) | b1;
// Convert RGB888 to RGB332 with dithering
uint8_t rgb888_to_rgb332_dither(int16_t r, int16_t g, int16_t b)
       // Clamp values
                                   : r;
                                   : g;
                                   : b;
       // Convert to RGB332 (3 bits R, 3 bits G, 2 bits B)
       uint8_t r3 = (r * 7 + 127) / 255;
       uint8_t g3 = (g * 7 + 127) / 255;
       uint8_t b2 = (b * 3 + 127) / 255;
       return (r3 << 5) | (g3 << 2) | b2;
int ReadAndDisplayBMP(int fnbr, int display_mode, int img_x_offset, int img_y_offset,
                     int x_display, int y_display)
       BITMAPFILEHEADER fileHeader;
       BITMAPINFOHEADER infoHeader;
       unsigned int bytes_read;
       int result;
       // Read file header
       result = IMG_FREAD(fnbr, &fileHeader, sizeof(BITMAPFILEHEADER), &bytes_read);
       if (result != 0 || bytes_read != sizeof(BITMAPFILEHEADER))
               error("BMP: Failed to read file header");
               return -1;
       // Verify BMP signature
       if (fileHeader.bfType != 0x4D42)
       { // "BM"
               error("BMP: Invalid file signature (not a BMP file)");
               return -2;
       // Read info header
       result = IMG_FREAD(fnbr, &infoHeader, sizeof(BITMAPINFOHEADER), &bytes_read);
       if (result != 0 || bytes_read != sizeof(BITMAPINFOHEADER))
               error("BMP: Failed to read info header");
               return -3;
       // Verify format - must be 24-bit RGB
       if (infoHeader.biBitCount != 24)
               error("BMP: Must be 24-bit RGB888 format");
               return -4;
       // Verify no compression
       if (infoHeader.biCompression != 0)
               error("BMP: Compressed format not supported");
               return -5;
       // Verify biPlanes is 1 (standard requirement)
       if (infoHeader.biPlanes != 1)
               error("BMP: Invalid planes value (must be 1)");
               return -6;
       int width = infoHeader.biWidth;
       int height = infoHeader.biHeight;
       int is_bottom_up = (height > 0);
       if (height < 0)
               height = -height;
       // Check size limits
       if (width > 1920 || height > 1080 || width <= 0 || height <= 0)
               error("BMP: Image dimensions invalid or exceed 1920x1080");
               return -7;
       // Calculate row size (rows are padded to 4-byte boundary)
       int row_size = ((width * 3 + 3) / 4) * 4;
       // Allocate buffers for Floyd-Steinberg dithering
       // We need to store error values for current and next line
       int16_t *error_buffer_r = (int16_t *)GetMemory(width * 2 * sizeof(int16_t));
       int16_t *error_buffer_g = (int16_t *)GetMemory(width * 2 * sizeof(int16_t));
       int16_t *error_buffer_b = (int16_t *)GetMemory(width * 2 * sizeof(int16_t));
       if (!error_buffer_r || !error_buffer_g || !error_buffer_b)
               if (error_buffer_r)
                       FreeMemory((void *)error_buffer_r);
               if (error_buffer_g)
                       FreeMemory((void *)error_buffer_g);
               if (error_buffer_b)
                       FreeMemory((void *)error_buffer_b);
               error("BMP: Failed to allocate error buffers");
               return -8;
       // Initialize error buffers to zero
       for (int i = 0; i < width * 2; i++)
               error_buffer_r[i] = 0;
               error_buffer_g[i] = 0;
               error_buffer_b[i] = 0;
       int16_t *curr_error_r = error_buffer_r;
       int16_t *next_error_r = error_buffer_r + width;
       int16_t *curr_error_g = error_buffer_g;
       int16_t *next_error_g = error_buffer_g + width;
       int16_t *curr_error_b = error_buffer_b;
       int16_t *next_error_b = error_buffer_b + width;
       // Buffer for reading pixel data (5 lines max)
       int lines_per_buffer = 5;
       uint8_t *line_buffer = (uint8_t *)GetMemory(row_size * lines_per_buffer);
       if (!line_buffer)
               error("BMP: Failed to allocate line buffer");
               return -9;
       // Buffer for output BGR triplets (maximum width for visible portion)
       int max_visible_width = (HRes < width) ? HRes : width;
       uint8_t *output_buffer = (uint8_t *)GetMemory(max_visible_width * 3);
       if (!output_buffer)
               FreeMemory((void *)line_buffer);
               error("BMP: Failed to allocate output buffer");
               return -10;
       // Process image line by line
       for (int y = 0; y < height; y += lines_per_buffer)
               int lines_to_read = (y + lines_per_buffer > height) ? (height - y) : lines_per_buffer;
               int bytes_to_read = row_size * lines_to_read;
               // Read lines
               result = IMG_FREAD(fnbr, line_buffer, bytes_to_read, &bytes_read);
               if (result != 0 || bytes_read != bytes_to_read)
                       FreeMemory((void *)output_buffer);
                       error("BMP: Failed to read image data");
                       return -11;
               // Process each line in the buffer
               for (int line = 0; line < lines_to_read; line++)
                       int current_y = y + line;
                       int img_y = is_bottom_up ? (height - 1 - current_y) : current_y;
                       int screen_y = img_y - img_y_offset + y_display;
                       // Skip if line is outside display bounds
                       if (screen_y < 0 || screen_y >= VRes)
                               continue;
                       // Clear next line error buffer
                       for (int i = 0; i < width; i++)
                               next_error_r[i] = 0;
                               next_error_g[i] = 0;
                               next_error_b[i] = 0;
                       // Track visible pixels
                       int visible_pixels = 0;
                       int first_screen_x = -1;
                       // Process each pixel in the line
                       for (int x = 0; x < width; x++)
                               int pixel_offset = line * row_size + x * 3;
                               uint8_t b = line_buffer[pixel_offset];
                               uint8_t g = line_buffer[pixel_offset + 1];
                               uint8_t r = line_buffer[pixel_offset + 2];
                               // Apply accumulated error from previous pixels
                               int16_t old_r = r + curr_error_r[x];
                               int16_t old_g = g + curr_error_g[x];
                               int16_t old_b = b + curr_error_b[x];
                               // Convert to display format
                               uint8_t display_color;
                               uint8_t new_r, new_g, new_b;
                               if (display_mode == DISPLAY_RGB121)
                                       display_color = rgb888_to_rgb121_dither(old_r, old_g, old_b);
                                       rgb121_to_rgb888_components(display_color, &new_r, &new_g, &new_b);
                               else
                               { // DISPLAY_RGB332
                                       display_color = rgb888_to_rgb332_dither(old_r, old_g, old_b);
                                       rgb332_to_rgb888_components(display_color, &new_r, &new_g, &new_b);
                               // Clamp old values for error calculation
                               old_r = (old_r < 0) ? 0 : (old_r > 255) ? 255
        : old_r;
                               old_g = (old_g < 0) ? 0 : (old_g > 255) ? 255
        : old_g;
                               old_b = (old_b < 0) ? 0 : (old_b > 255) ? 255
        : old_b;
                               // Calculate error
                               int16_t err_r = old_r - new_r;
                               int16_t err_g = old_g - new_g;
                               int16_t err_b = old_b - new_b;
                               // Distribute error using Floyd-Steinberg dithering
                               if (x + 1 < width)
                                       curr_error_r[x + 1] += (err_r * 7) / 16;
                                       curr_error_g[x + 1] += (err_g * 7) / 16;
                                       curr_error_b[x + 1] += (err_b * 7) / 16;
                               if (x > 0)
                                       next_error_r[x - 1] += (err_r * 3) / 16;
                                       next_error_g[x - 1] += (err_g * 3) / 16;
                                       next_error_b[x - 1] += (err_b * 3) / 16;
                               next_error_r[x] += (err_r * 5) / 16;
                               next_error_g[x] += (err_g * 5) / 16;
                               next_error_b[x] += (err_b * 5) / 16;
                               if (x + 1 < width)
                                       next_error_r[x + 1] += (err_r * 1) / 16;
                                       next_error_g[x + 1] += (err_g * 1) / 16;
                                       next_error_b[x + 1] += (err_b * 1) / 16;
                               // Calculate screen position
                               int screen_x = x - img_x_offset + x_display;
                               // Store pixel if it's visible on screen
                               if (screen_x >= 0 && screen_x < HRes)
                                       if (first_screen_x == -1)
                                               first_screen_x = screen_x;
                                       // Store as BGR triplets
                                       output_buffer[visible_pixels * 3] = new_b;
                                       output_buffer[visible_pixels * 3 + 1] = new_g;
                                       output_buffer[visible_pixels * 3 + 2] = new_r;
                                       visible_pixels++;
                       // Draw the line if any pixels are visible
                       if (visible_pixels > 0)
                               int last_screen_x = first_screen_x + visible_pixels - 1;
                               DrawBuffer(first_screen_x, screen_y, last_screen_x, screen_y, output_buffer);
                       // Swap error buffers
                       int16_t *temp;
                       temp = curr_error_r;
                       curr_error_r = next_error_r;
                       next_error_r = temp;
                       temp = curr_error_g;
                       curr_error_g = next_error_g;
                       next_error_g = temp;
                       temp = curr_error_b;
                       curr_error_b = next_error_b;
                       next_error_b = temp;
       // Cleanup
       return 0;
Edited 2025-10-14 21:26 by matherp
Martin H.
Posted: 07:12pm 14 Oct 2025
Atkinson Dithering
During the mid-1980’s, dithering became increasingly popular as computer hardware advanced to support more powerful video drivers and displays. One of the best dithering algorithms from this era was developed by Bill Atkinson, a Apple employee who worked on everything from MacPaint (which he wrote from scratch for the original Macintosh) to HyperCard and QuickDraw.
Atkinson’s formula is a bit different from others, because it only propagates a fraction of the error instead of the full amount. This technique is sometimes offered by modern graphics applications as a “reduced color bleed” option. By only propagating part of the error, speckling is reduced, but contiguous dark or bright sections of an image may become washed out.
https://tannerhelland.com/2012/12/28/dithering-eleven-algorithms-source-code.html
FN$="testapple"
' Atkinson Dithering v 0.94 - Korrigierte Randbehandlung
' Converts PNG Source Files to RGB121 BMP
' by Martin H. 2025 (with the help of the AI assistant)
Mode 1
' Read PNG header to determine image size
dim integer w, h
s$ = INPUT$(24, #1)
' Read width
w=ASC(MID$(s$,17,1))*16777216
inc w,(ASC(MID$(s$,18,1))*65536)
inc w,(ASC(MID$(s$,19,1))*256)
inc w,ASC(MID$(s$,20,1))
' Read height
h=ASC(MID$(s$,21,1))*16777216
inc h,(ASC(MID$(s$,22,1))*65536)
inc h,(ASC(MID$(s$,23,1))*256)
inc h,ASC(MID$(s$,24,1))
close #1
dim integer BL%=(h*w)/64
Dim integer listR(BL%),listG(BL%),listB(BL%)
cls
' Load source image
load png FN$+".png"
' Atkinson ring buffer (starts at index 0, goes up to W+3 for safety)
Dim integer RLine(W+3,3),BLine(W+3,3),GLine(W+3,3)
' START SCAN
for Ypos=0 to H-1
for Xpos=0 to W-1
n=Pixel(Xpos,Ypos)AND &HFFFFFF
R=(N AND 255):G=((N >> 8)AND 255):B=((N >> 16) AND 255)
' 1.GREEN (2 bits: 0, 85, 170, 255)
GV = G + GLine(Xpos, 1)
' Clipping (Zwischenwert)
if GV > 255 then GV = 255
if GV < 0 then GV = 0
' Quantization to 4 values (step size 85)
Index = INT(GV / 85 + 0.5)
' Palettenwert berechnen
CG = Index * 85
' Since the index is at most 3 (3*85 = 255), no additional clipping is necessary,
' but for robustness we leave it in:
if CG > 255 then CG = 255
GE = GV - CG ' Error is calculated from GV (intermediate value) - CG (pallet value)      GE = GV - CG ' Fehler wird aus GV (Zwischenwert) - CG (Palettenwert) berechnet
' 2.  RED (1 bit: 0 or 255)
RV=R+RLine(Xpos,1)
CR=0
if RV>128 then
RE=RV-255:CR=255 ' Error is negative, palette value is 255
else
RE=RV:CR=0 ' Error is positive, pallet value is 0
end if
' 3. BLUE (1 bit: 0 or 255)
BV=B+BLine(Xpos,1)
CB=0
if BV>128 then
BE=BV-255:CB=255
else
BE=BV:CB=0
end if
'Plot output pixel
Pixel Xpos,Ypos+h,RGB(CR,CG,CB)
' Prepare errors for distribution (1/8 share for all channels)
RE_EIGHT = RE/8
BE_EIGHT = BE/8
GE_EIGHT = GE/8
' ERROR DISTRIBUTION (Atkinson 1/8 kernel)
' 1. CURRENT LINE (Y) / RLine(F,1)
if Xpos < W-1 then ' (X+1, Y)
inc GLine(Xpos+1,1),GE_EIGHT:inc BLine(Xpos+1,1),BE_EIGHT:inc RLine(Xpos+1,1),RE_EIGHT
end if
if Xpos < W-2 then ' (X+2, Y)
inc GLine(Xpos+2,1),GE_EIGHT:inc BLine(Xpos+2,1),BE_EIGHT:inc RLine(Xpos+2,1),RE_EIGHT
end if
' 2. NEXT LINE (Y+1) / RLine(F,2)
if Ypos < H-1 then ' Only distribute if there is a next line
if Xpos > 0 then ' (X-1, Y+1) - Randprüfung für Index 0
inc GLine(Xpos-1,2),GE_EIGHT:inc BLine(Xpos-1,2),BE_EIGHT:inc RLine(Xpos-1,2),RE_EIGHT
end if
' (X, Y+1)
inc GLine(Xpos,2),GE_EIGHT:inc BLine(Xpos,2),BE_EIGHT:inc RLine(Xpos,2),RE_EIGHT
if Xpos < W-1 then ' (X+1, Y+1)
inc GLine(Xpos+1,2),GE_EIGHT:inc BLine(Xpos+1,2),BE_EIGHT:inc RLine(Xpos+1,2),RE_EIGHT
end if
' 3. NEXT LINE (Y+2) / RLine(F,3)
if Ypos < H-2 then ' Only distribute if there is a line after the next one
' (X, Y+2)
inc GLine(Xpos,3),GE_EIGHT:inc BLine(Xpos,3),BE_EIGHT:inc RLine(Xpos,3),RE_EIGHT
end if
end if
Next
' Next line, scrolling the ring buffer
for f=0 to W+3
RLine(F,1)=RLine(F,2):RLine(F,2)=RLine(F,3):RLine(F,3)=0
BLine(F,1)=BLine(F,2):BLine(F,2)=BLine(F,3):BLine(F,3)=0
GLine(F,1)=GLine(F,2):GLine(F,2)=GLine(F,3):GLine(F,3)=0
Next
Next
save image FN$+".bmp",0,h,w,h
Heureka
  Martin
Edited 2025-10-16 01:25 by Martin H.
'no comment
Martin H.
Posted: 05:45pm 25 Oct 2025
in case anyone's interested
Further improved version, green is now also dithered in 7 steps
g≤LG    Fixed color 0    Level 1: Black
LG<g≤LG_MID    Dither between 0 and G1    Level 2: Very dark green
LG_MID<g≤MG    Fixed color G1    Level 3: Dark green
MG<g≤MG_MID Dither between G1 and G2    Level 4: Medium green-dark
MG_MID<g≤UG    Fixed color G2    Level 5: Medium green
UG<g≤UG_MID    Dither between G2 and G3    Level 6: Light green
g>UG_MID    Fixed color G3    Level 7: Full green
' V2.1
FN$="london"
Mode 1
dim w, h as integer
s$ = INPUT$(24, #1) 'Get first 24 bytes (until end of IHDR header)
' Width from bytes 17-20
'Height from bytes 21–24
close #1
BL%=(h*w)/64
cls
load png FN$+".png"
Prescan
Scan
ui
end
sub Scan
' Constants for the fixed green values
G1 = &H4000 ' Dark green (equivalent to LG)
G2 = &H8000 ' Medium green (equivalent to MG)
G3 = &HFF00 'Full green (corresponds to UG)
' Define thresholds for dithering zones (midpoints between thresholds)
LG_MID = (LG + MG) / 2
MG_MID = (MG + UG) / 2
UG_MID = (UG + 255) / 2
for y=0 to h-1
  for x=0 to w-1
      cl%=0
      ' --> Red channel
      r=n AND &HFF
       ' Dithering A: (0,0)=255, (0,1)=0, (1,0)=0, (1,1)=255
       if (y mod 2)then:R=255*not (x mod 2):else:R=255*(x mod 2):end if
       inc cl%,R
      else
       inc cl%,255*(r>UR)
      end if
      n=int(n/256) '  Prepare the next color
      ' -->Green channel (7-STEP LOGIC)
      g=n AND &HFF
       ' Determine the dithering pattern for the green channel (complementary to red)
' If y is odd , the pattern is 0, 1, 0, 1...
       ' If y is even, the pattern is 1, 0, 1, 0...
       IF (y mod 2) THEN
           DITHER_BIT = (x mod 2)      ' 0 oder 1
       ELSE
           DITHER_BIT = NOT (x mod 2)  ' 1 oder 0
       END IF
      select case g
       ' Stage 7: Full green (G3)
      case >UG_MID
       inc cl%, G3
       ' Stage 6: Dither G3 with G2
      case >UG
       inc cl%, G2 * DITHER_BIT + G3 * (1-DITHER_BIT)
       ' Stage 5: Mittelgrün (G2)
      case >MG_MID
       inc cl%, G2
       ' Stage 4: Dither G2 with G1
      case >MG
       inc cl%, G1 * DITHER_BIT + G2 * (1-DITHER_BIT)
       ' Stage 3: Darkgreen  (G1)
      case >LG_MID
       inc cl%, G1
       ' Stage 2: Dither G1 with 0
      case >LG
       inc cl%, 0 * DITHER_BIT + G1 * (1-DITHER_BIT)
        ' Stage 1: Black (0)
      case else
       inc cl%, 0
      end select
      ' --> Blue channel
      n=int(n/256)
      b=n AND &HFF
      if b>LB and b<UB then
       ' Dithering B: Inverted to red (pattern A)
       if (y mod 2)then:B=255*(x mod 2):else:B=255*not (x mod 2):end if
       inc cl%,B*65536
      else
      end if
      pixel x,y,cl%
  next
next
End sub
sub ui
Font 2
px=w+6
do
Print@(px,0);  " threshold values"
Print@(px,16); "      RED"
Print@(px,32); "   Q ";make$(LR);" W"
Print@(px,48); "   A ";make$(UR);" S"
Print@(px,64); "     GREEN"
Print@(px,80); "   E ";make$(LG);" R "
Print@(px,96); "   D ";make$(MG);" F"
Print@(px,112);"   C ";make$(UG);" V"
Print@(px,128); "    Blue"
PRINT@(px,144);"   O ";make$(LB);" P"
Print@(px,160);"   K ";make$(UB);" L"
Print@(PX,176);" SPACE = Repaint"
Print@(PX,192);" Enter = Save&Exit"
Print@(PX,208);"   ESC = Exit without Save"
k$=Ucase$(k$)
select case k$
case "Q"
case "W"
case "E"
case "R"
case "O"
case "P"
case "A"
case "S"
 case "K"
case "L"
  case "C"
case "V"
    case "D"
case "F"
case " "
load png FN$+".png"
 Scan
 Exit SUB
case chr$(27)
 End
end select
loop
end sub
make$=STR$(Value)
make$="0"+make$
loop
end Function
sub Prescan
      FOR dy = y TO y+7
        FOR dx = x TO x+7
        NEXT
      NEXT
      inc blockIndex
    NEXT
  NEXT
end sub
cheers
  Martin
'no comment
Turbo46
Posted: 05:08am 26 Oct 2025
Thanks Martin, I am still interested but I have been unable to play for a while. I may be able to try it out tomorrow in mode 9 to process larger images.
Bill
Posted: 09:51am 26 Oct 2025
Hi Martin,
That last picture you posted looks "darker" than earlier dithering examples.
Any reason why ?
Posted: 10:19am 26 Oct 2025
@Martin,
I have a problem when transfering the pictures back to the PC when saved with PicoMiteVGA (colors/brightness change, maybe similar to your above darker picture).
But I will try to put them here anyway. However you should try it yourself on 6.01.00RC7
LOAD DITHERED "london.bmp",,,2
london_bmp.zip
The result (again, try on picomite + monitor, it looks much better that this).
Atkinson gives better result on smaller screens than Floyd. On a larger screen Floyd may be better.
Edited 2025-10-26 20:23 by Volhout
Martin H.
Posted: 10:58am 26 Oct 2025
Hi Volhout
  Volhout said  I have a problem when transfering the pictures back to the PC when saved with PicoMiteVGA (colors/brightness change, maybe similar to your above darker picture).
The prescan sub attempts to determine the average value for red, green, and blue. First, it adds the values from 8x8 pixel squares, then sorts the determined values and uses them to determine the threshold values. In other words, it uses the median.
If the result appears too dark, too light, or the wrong color, you can use the keys to adjust the threshold values.TIf i Like to avoid dithering, I set both values directly next to each other, i.e., the upper and lower thresholds to the same value.
However, it always depends on the source material which you work on.
For photos, I would prefer Atkinson, but for other images, such as graphics, I would prefer direct conversion with possible dithering, as with the conversion of PetsciRobots tiles and sprites.
Martin
Edited 2025-10-26 21:03 by Martin H.
'no comment
Posted: 11:33am 26 Oct 2025
Hi Martin,
I just mentioned the option, so you could technically provide all graphics for cca in raw (24 bit bmp) format. And let the pico do the dithering. Advantage is that HDMI 2350 platforms can enjoy the graphics in 8bit (mode 3 RGB332) format and VGA users in RGB121 format. Without you having to do all the hard work twice (RGB332) when you feel to it.
How is cca progressing by the way ?
P.S. you would have guessed : I used a different "london" picture. With individual leaves on the trees, so you could see how that works out.
Edited 2025-10-26 21:34 by Volhout
Posted: 01:07pm 26 Oct 2025
Volhout - see the rc thread for a test VGA version dithering jpg direct to screen
     Page 2 of 3
