Forum Index : Microcontroller and PC projects : PicoMite with XP?
| PhenixRising Guru Joined: 07/11/2023 Location: United KingdomPosts: 2098 |
I have downloaded MMEdit (portable) for my XP machine but I have never used the Pico on XP. Device manager just shows "Pico ?" |
"Is Windows XP still usable in 2024? Yes, in fact, they are. According to StatCounter, as of March 2024, 0.39% of desktops are still running Windows XP. Let's do a little math. Microsoft claims there are 1.4 billion Windows PCs in the world, so that means we still have not quite 5.5 million XP computers up and running somewhere" |
I use a Panasonic Toughbook CF18 on the plant-floor and it has been rock-solid for years. Very low-powered and I didn't wanna risk trying to install W7. |
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 6187 |
Hi Phenix, I see you have a new job, building pico CNC controllers. Great action to prove they where wrong. Volhout PicomiteVGA PETSCII ROBOTS |
TassyJim![]() Guru Joined: 07/08/2011 Location: AustraliaPosts: 6626 |
You have to install drivers for the pico USB https://forums.raspberrypi.com/viewtopic.php?t=300053 or use a USB-TTL that has XP drivers and configure a serial console port on the pico. You won't be able to update MMMBasic firmware but your code updates are OK through the console oprt. Jim VK7JH MMedit |
Grogster![]() Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10072 |
When I had my low-power FM radio station, I used XP to play all the music. It was perfect for that, and rock-solid. It was standalone - never connected to the network or the internet, but as a standalone music player just running that software and nothing else, it was pretty much bulletproof. Ran 24/7/365 for the several years I had that radio station on-air, and never gave any trouble. So, still useful for certain things! ![]() Smoke makes things work. When the smoke gets out, it stops! |
to answer Michael's initial question, download Zadig XP version 2.2 from here: https://zadig.akeo.ie/downloads/ and then follow these slides: ![]() ![]() ![]() ![]() note in the second slide to select USB Serial (CDC) in the dropdown. cheers, rob :-) Edited 2024-10-25 12:49 by robert.rozee |
OMG....that must've taken all of two minutes ![]() Many, many thanks, Rob |
