andreas Senior Member Joined: 07/12/2020 Location: GermanyPosts: 226
Posted: 08:54am 03 Dec 2024
Hi,
when using OPTION BASE 1 I get an error when writing dim a(1).
[3] Dim a(n) Error : Dimensions
OPTION BASE 1 n=1 DIM a(n)
If n>1 everything is fine.
I understand that the lowest index in an array is 0 when using OPTION BASE 0 and 1 when using OPTION BASE 1, but why do I need 2 values when using OPTION BASE 1?
I get the problem when reading the value of 'n' from a DATA statement by READ. The program has a DATA statement holding application data and n=1 could be a possible value for 'n'.
WebMite MMBasic RP2350A Edition V6.00.01RC1
-andreas Edited 2024-12-03 18:57 by andreas
matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12176
Posted: 09:19am 03 Dec 2024
MMBasic doesn't allow single element arrays. I wish it did for reasons such as array multiplication but it doesn't. I don't think this is something that could be easily changed as it is fundamental to the way the variable table is built
