| circuit Guru Joined: 10/01/2016 Location: United KingdomPosts: 309 |
Let us not forget the very excellent full syntax help system that is available in the help menu of MMEdit. It is a substantial reference, always to hand. |
| bfwolf Senior Member Joined: 03/01/2025 Location: GermanyPosts: 258 |
Nice idea! What about giving the possibility to specify the helpfile_path$ ? E.g. by OPTION HELPFILE ? Cos the drive A: could be too small for a larger helpfile - and B: (SDCARD) would offer "nearly unlimited" storage.. |
| Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 9212 |
Compress the file & put it on A:. :) There's no guarantee that there will be a B: present, especially on minimal systems. Text will compress remarkably well without major effort, especially when the vocabulary is fairly limited. Even if you simply use 2 bytes for words over 3 characters long you can shrink text a lot. Only the bit after the colon needs to be compressed so the file is still searchable as a normal text file using the ~ and :. Mind you, it's a bit more work. :) Mick Zilog Inside! nascom.info for Nascom & Gemini |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12017 |
I made an offer. Accept it or don't, but don't change it. |
| k2backhoe Regular Member Joined: 04/12/2021 Location: United StatesPosts: 47 |
ERROR? setting the araw configuration on the RP2350B grounds the analog input pin It appears that using the setpin gpxx,araw command on the RP2350B version sets the input pin to output a digital zero I am trying to read the ADC channels on a RP2350B (Weact Studio RP2350B Core Board from AliExpress) I have a 10k pot set up as a voltage divider from 3.3V to GND, wiper is connected to the ADC pin indicated Using a conventional (original) Pi Pico with RP2040 and V6.00.02RC15 > setpin gp26,ain > ?pin(gp26) 1.595604396 Voltmeter on gp26 reads 1.599v > setpin gp26,araw > ?pin(gp26) 1982 Voltmeter on gp26 reads 1.598v. 3.3 / 1.598 * 1982 = 4101 (~4095, as expected) So far, so good. All works as expected. Using a Weact Studio RP2350B Core Board Voltmeter on gp26 reads 1.552v Still as expected > setpin gp41,ain > ? pin(gp41) 1.534358974 Voltmeter on gp26 reads 1.552v Still as expected > setpin gp41,araw %%%%%% As soon as this command executed, gp41 drops to 0.078 volts using external voltmeter > ? pin(gp41) 95 %%%%%%%% Should be ~ 2000 Voltmeter on gp26 reads 0.078v %%%%% should be ~ 1.55 V > setpin gp41,ain Voltmeter on gp26 goes back up to 1.556v N.B. the arithmetic is correct, 3.3 / 0.078 * 95 = 4019 (~4095, as expected) It looks like the software routine for the command [setpin gp41,araw] causes the pin GP41 to output a logical 0 PS: On page 136 of the manual Ver 6.00.01 "ARAW Fast analog input returning a value between 0 and 1023." should be "ARAW Fast analog input returning a value between 0 and 4095." |
| electricat Senior Member Joined: 30/11/2020 Location: LithuaniaPosts: 299 |
I aiming this to comunity, as Peter made offer. Discusion could be moved to another thread too, as there is no any rush with current release: What I like about Peter`s offer is: -one small help.TXT file which extends LIST COMMANDS, LIST FUNCTIONS. - It could be fast drop - in solution suitable to check syntax and command optionals WITH OPTIONAL multiline notes for USER to fill in himself. Not for absolute newbies, while still helpful. Flash firmware, drop file via terminal and you have some better helper. - As it would be proper command integrated in firmware, prompt enters is stored in lastcmd buffer. Sometimes it is handy. How this can be ruined ? - Help needs to be easy updatable, or corrected if there is no 'official' update but user found error. Or if user wants to add some note , then he EDITs file, makes additions. Means help.txt should be simple TXT file - big, fat, one file with everything. TXT databases were created for reason ant flash is not that fast. I would volunteer if comunity needs just: ~command:command param,[optional param] With multiline left empty for user to fill, if he needs it :multi-line if required I am not the most accurate person and not native english speaker. Maybe another person would be better to volunteer instead P.S. I already created help system which could be stored in B: and could grow as large as user would want. I created it with idea to be helpful if user does not know exactly what he is searching or dont know EXACT keywoard. I created it to be usefull for newbie like myeself and handy for experenced user if he does not need full info. I created it for somebody who wants less dependence of main PC I will make improvements and updates on it time to time, to make it better. As it really is only V0.1 experimental stage. Edited 2025-04-18 15:21 by electricat My MMBasic 'sand box' |
Thanks for the report - found and fixed NB: I will be removing OPTION FAST TRIG from the next release. The fault in GUI GAUGE also manifests itself in trig functions using single precision. All other trig in MMBasic is double precision so there are no other commands affected by what appears to be a bug in the Pico sdk for the RP2350 UPDATE: posted on the Pico forum and this is an issue that is apparently been seen by someone else so will definitely sticking to double precision Edited 2025-04-18 19:55 by matherp |
Just an idea... If one was *really clever* there could be 2 help files. File1 - lives on A: and has no comments, just a record number where they would be This keeps the size down. One line per command or function with the minimal info. File2 - lives on B: and contains just the comments. This is searched by record number. This allows the use of, for example, record 1 which is just "No comments stored", which would be the initial setup. Both files would be ordinary text files, so easily edited. The user could simply add lines to File2 and put that line (record) number into File1 as the comment. Is this over-complicated? . Edited 2025-04-18 19:58 by Mixtel90 Mick Zilog Inside! nascom.info for Nascom & Gemini |
| JohnS Guru Joined: 18/11/2011 Location: United KingdomPosts: 4386 |
. Probably. Especially when there's no B: John |
I made an offer. Accept it or don't, but don't change it. Yes, of course I do accept. It's your work and effort.. I really appreciate what you're doing! Just was an idea.. You inspired me.. An other idea: The 1st line in the "help.txt" could be a "link" (path) to a bigger helpfile e.g. on "B:" - perhaps easier to implement and less work? But as I just said: I don't want to cause you unnecessary work or "put down" your ideas/offers. Especially since revision 6.0.2 is "one minute to 12 o'clock", so you want to do a release and your focus is on bug fixes? bfwolf |
@JohnS But at least it's usable without B:. A single large file with comments may not fit on A:, in which case you have nothing. Compression is the other way but that's even more complicated. Peter's offer looks good to me. It's unlikely that anyone is going to need a full help file. Even I've got past needing help entries for a lot of the commands. :) I see this more of a case of having an on-line mid-range reminder, after all we have LIST COMMANDS and LIST FUNCTIONS to see a lot of what's available and the manual for anything more in-depth. Mick Zilog Inside! nascom.info for Nascom & Gemini |
I've change the filespec slightly. Filename is "help.txt" - lowercase. Everything should be on different lines. Below is my test file and the result. ![]() COLOR fore [, back] Sets the default color for commands (PRINT, etc) that display on the on the attached LCD panel. 'fore' is the foreground colour, 'back' is the background colour. The background is optional and if not specified will default to black. ~COLOUR COLOUR fore [, back] Sets the default colour for commands (PRINT, etc) that display on the on the attached LCD panel. 'fore' is the foreground colour, 'back' is the background colour. The background is optional and if not specified will default to black. ~COLOUR MAP COLOUR MAP inarray%(),outarray%() [,colourmap%()] This command generates RGB888 colours in outarray% from colour codes (0-15) in inarray%. If the optional colourmap% parameter is used this must be 16 elements long). In this case the values in inarray% are mapped to the colours for that index value in colourmap% ~DO DO <statements> LOOP Loops while Loops while 'expression' is true (this is equivalent to the older WHILE-WEND loop).If, at the start, the expression is false the statements in the loop will not be executed, not even once. ~DO WHILE DO WHILE expression <statements> LOOP Loops until the expression following UNTIL is true. Because the test is made at the end of the loop the statements inside the loop will be executed at least be executed, not even once. |
| homa Guru Joined: 05/11/2021 Location: GermanyPosts: 708 |
thx Peter!When can we expect the final release? Matthias |
V6.00.02RC16 is available on https://geoffg.net/Downloads/picomite/PicoMite_Beta.zip Fixes bug in GUI GAUGE Fixes bug in SETPIN n,ARAW Removes OPTION FAST TRIG ON/OFF as there is a bug in the Pico implementation of the C functions cosf and sinf so this is not reliable Implements HELP [search_pattern$] command. See above. HELP without a parameter just outputs the text: "Enter help and the name of the command or function Use * for multicharacter wildcard or ? for single character wildcard" This looks for a file on the A: drive named "help.txt" This must be formatted as follows: ~searchable_string text line - recommend this is the command syntax e.g. COLOUR fore [, back] text line .... text line ~next_searchable_string text line .... etc. There can be one or many text lines for each searchable_string. It is highly recommended that text lines do not exceed 80 characters in length in the "search_pattern" use * for multicharacter wildcard or ? for single character wildcard The command will output all sections (between the matching searchable string and the next searchable string) where the search_pattern matches the searchable_string Edited 2025-04-19 01:23 by matherp |
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 6175 |
Peter, What scroll mechanism is in help? When there is more text than 1 screen? Same as with LIST? Volhout Edited 2025-04-19 01:55 by Volhout PicomiteVGA PETSCII ROBOTS |
None. The assumption is that a typical search will return less than a page of output. If anyone is creating help that returns more than that they will probably use all the A: drive first Edited 2025-04-19 01:59 by matherp |
All three of the 64-pin PCBs I had had trouble with worked with V6.00.02RC16. Surprising to me, the one on which I had soldered the PSRAM which when OPTION PSRAM PIN GP0 was entered, went into forever presenting the "D:" drive instead of a serial port, now shows the PSRAM available after that option was provided. I had thought it would perhaps not find it but not care. Thanks always, Peter, for your outstanding work. PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
Implements HELP [search_pattern$] command. See above. This looks for a file on the A: drive named "help.txt" This must be formatted as follows: Draft help.txt 'build' here help.txt.zip ![]() Edited 2025-04-19 03:47 by electricat My MMBasic 'sand box' |
Some errors corrected Added better PEEK, POKE, FORMAT$ explanationes etc (Changes may be seen with any text comparing tool) Anyone wishes test it, can download help.txt here help.txt.zip I think it has now all universal notes for public use. And All other help notes would be by personal 'taste' to add . Your opinions, comunity? Using/sharing this help.txt file BETA key might be added ultra easy, so by entering >HELP "*BETA*" you might list then all current BETA addons!!! (did not included in this upload yet) All latest @Pater`s commands and functions added, needs to be collected. Maybe somebody collected in one place? @Mick ? (This I used this BETA for myeself in my own help system but with braoder explanations. ) My MMBasic 'sand box' |
I originally didn't do this because the list mechanism is very basic and splits lines in the middle of words and fails when the last line to be displayed is too long. In which case, the "press any key" happens after the first line has already scrolled off, or, even worse, on a display with no scroll, after the whole screen has been wiped. To fix this I needed a mechanism to split the line only on word boundaries. Not too hard but the sort of thing that would take several iterations to get right. Lets see what AI can do (Cortana). My instruction followed by The AI wrote #include <stdio.h> #include <string.h> void printWrappedText(const char *text, int screenWidth) { int length = strlen(text); int start = 0; // Start index of the current line while (start < length) { int end = start + screenWidth; // Calculate the end index for the current line if (end >= length) { // If end is beyond the text length, just print the remaining text printf("%s\n", text + start); break; } // Find the last space within the current screen width int lastSpace = -1; for (int i = start; i < end; i++) { if (text[i] == ' ') { lastSpace = i; } } if (lastSpace != -1) { // If a space is found, break at the space printf("%.*s\n", lastSpace - start, text + start); start = lastSpace + 1; // Skip the space } else { // If no space is found, truncate at screen width printf("%.*s\n", screenWidth, text + start); start += screenWidth; } } } int main() { const char *text = "Thisisaverylongstringwithnospacesthatneedstobetruncatedproperly."; int screenWidth = 20; // Example screen width printWrappedText(text, screenWidth); return 0; } I then tested this with different strings on https://www.programiz.com/c-programming/online-compiler/ which is a great resource for fast testing of C code The program worked perfectly so with a bit of modification to fit into MMBasic this will be in the next release. |
