Forum Index : Microcontroller and PC projects : MMBasic on PicoCalc - using sprites ?
| DigitalDreams Regular Member Joined: 03/05/2025 Location: United KingdomPosts: 65 |
Heading into sprite handling on PicoCalc and hitting issues straight away. Whether I load a bmp to the screen and ‘sprite read’ from it OR ‘sprite load bmp’ from the bmp file itself I get the error “not available on physical display” ?? I find it hard to accept or believe it's not possible on this device as other emulators are handling them fine. |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11499 |
Sprites on LCD displays only work on memory framebuffers. LCD displays, and particularly SPI connected displays are too slow to be usable. Also many SPI LCD displays do not connect MISO and without that you can't read the data from display. Have a look at the code for Petscii Robots to see what can be done with a slow SPI display |
Yes it seems I'm stuck with the task of writing my own sprite functions that utilise the framebuffer commands. There's also 'GUI BITMAP' ?. Might seem like a slow lcd yet saw a post recently where someone had managed to get a game emulator running at 40fps on a PicoCalc |
Sprites are already fully implemented using a framebuffer. The emulator is almost certainly doing the same thing. Build the image in memory and then just copy areas that have changed to the display. |
I'd love to see a short and simple working example of the sprite commands using a framebuffer on LCD to create a simple sprite and move it... Early days for me so forgive the newbie image I portray.. |
Option console serial FRAMEBUFFER create FRAMEBUFFER write f CLS 'brownian motion demo using sprites Dim integer x(32),y(32),c(32) Dim float direction(32) Dim integer i,j,k, collision=0 Dim string q$ For i=1 To 32 direction(i)=Rnd*360 'establish the _ starting direction for each atom c(i)=RGB(Rnd*255,Rnd*255,Rnd*255) _ 'give each atom a colour Circle 9,9,9,1,,RGB(white),c(i) 'draw _ the atom Sprite read i,0,0,19,19 'read it in _ as a sprite Next i CLS RGB(myrtle) Box 1,1,MM.HRES-2,MM.VRES-2 k=1 For i=MM.HRES\9 To MM.HRES\9*8 Step _ MM.HRES\9 For j=MM.VRES\9 To MM.VRES\9*8 Step _ MM.VRES\5 Sprite show k,i,j,1 x(k)=i y(k)=j vector k,direction(k), 0, x(k), _ y(k) 'load up the vector move k=k+1 Next j Next i ' Do For i=1 To 32 vector i, direction(i), 1, x(i), _ y(i) Sprite show i,x(i),y(i),1 If sprite(S,i)<>-1 Then break_collision i EndIf Next i FRAMEBUFFER copy f,n Print Timer:Timer =0 Loop ' Sub vector(myobj As integer, angle As _ float, distance As float, x_new As _ integer, y_new As integer) Static float y_move(32), x_move(32) Static float x_last(32), y_last(32) Static float last_angle(32) If distance=0 Then x_last(myobj)=x_new y_last(myobj)=y_new EndIf If angle<>last_angle(myobj) Then y_move(myobj)=-Cos(Rad(angle)) x_move(myobj)=Sin(Rad(angle)) last_angle(myobj)=angle EndIf x_last(myobj) = x_last(myobj) + _ distance * x_move(myobj) y_last(myobj) = y_last(myobj) + _ distance * y_move(myobj) x_new=Cint(x_last(myobj)) y_new=Cint(y_last(myobj)) Return ' keep doing stuff until we break the _ collisions Sub break_collision(atom As integer) Local integer j=1 Local float _ current_angle=direction(atom) 'start by a simple bounce to break _ the collision If sprite(e,atom)=1 Then 'collision with left of screen current_angle=360-current_angle ElseIf sprite(e,atom)=2 Then 'collision with top of screen _ current_angle=((540-current_angle) Mod _ 360) ElseIf sprite(e,atom)=4 Then 'collision with right of screen current_angle=360-current_angle ElseIf sprite(e,atom)=8 Then 'collision with bottom of screen current_angle=((540-current_angle) _ Mod 360) Else 'collision with another sprite or _ with a corner current_angle = current_angle+180 EndIf direction(atom)=current_angle vector atom,direction(atom),j,x(atom),_ y(atom) 'break the collision Sprite show atom,x(atom),y(atom),1 'if the simple bounce didn't work try _ a random bounce Do While (sprite(t,atom) Or sprite(e,_ atom)) And j<10 Do direction(atom)= Rnd*360 vector atom,direction(atom),j,_ x(atom),y(atom) 'break the collision j=j+1 Loop Until x(atom)>=0 And _ x(atom)<=MM.HRES-sprite(w,atom) And _ y(atom)>=0 And _ y(atom)<=MM.VRES-sprite(h,atom) Sprite show atom,x(atom),y(atom),1 Loop ' if that didn't work then place the _ atom randomly Do While (sprite(t,atom) Or sprite(e,_ atom)) direction(atom)= Rnd*360 x(atom)=Rnd*(MM.HRES-sprite(w,_ atom)) y(atom)=Rnd*(MM.VRES-sprite(h,_ atom)) vector atom,direction(atom),0,_ x(atom),y(atom) 'break the collision Sprite show atom,x(atom),y(atom),1 Loop End Sub |
| lizby Guru Joined: 17/05/2016 Location: United StatesPosts: 3782 |
When I try this sprite test it chokes on the line continuation: > run [12] starting direction For each atom Error : Unknown command > option list PicoMite MMBasic RP2040 Edition V6.00.02RC21 OPTION SYSTEM SPI GP18,GP19,GP16 OPTION CPUSPEED (KHz) 200000 OPTION DISPLAY 50, 120 OPTION LCDPANEL ILI9341, RLANDSCAPE,GP21,GP20,GP17 OPTION SDCARD GP2 OPTION MODBUFF ENABLE > I did a clear_flash and downloaded V6.00.02RC21 again to make sure I hadn't flashed an older version. What am I doing wrong? EDIT: Answer--using wrong firmware; downloaded PicoMiteRP2040V6.00.02RC20e and all works. Brilliant. ~ Edited 2025-05-06 00:01 by lizby PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
| dddns Guru Joined: 20/09/2024 Location: GermanyPosts: 841 |
If you don't need to detect collisions: I could realize 1,3s of video sequence on a ili9143. Using blit could be an alternative..early work of mine moving a blit looks much better on a highres colour lcd because its in full colour and flicker free and fast for a square like 50x50 which can also be done with a RP2040. Copy away the area and redraw it for restoring the background is not visible to the eye a size of a mouse cursor can be moved almost as fast as on PC on my ssd1963(on a photo as background) You can also do your first tries and move a triangle by using TRIANGLE SAVE. It would be wonderful if this would exist for POLYGON I have to get that right: read and restoring the background can be done with a blit. the object which should be drawn cannot be a blit but any graphical command can be used including pixel. The object needs to be drawn exactly with its outline as I couldn't find a way for transparent color with blit especially not for BLIT LOAD A mouse cursor e.g. can be a polygon and is drawn like in a millisecond.. Amazing complex objects can be realized with polygon and are all drawn in one step e.g. a complete outline of a building. it only needs fantasy Edited 2025-05-06 03:16 by dddns |
