Local Time 12:19 22 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : FONT 4 characters 220, 221 and 223 are borked
Posted: 11:04am 16 Jun 2025
... and probably always have been.
As found by new user @RAM26 here:
   https://www.thebackshed.com/forum/ViewTopic.php?FID=16&TID=16401&LastEntry=Y#240947
Peter/Geoff here are some corrections for file "Fnt_10x16.h":
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, // Chr$(220)
0xF8,0x3E,0x0F,0x83,0xE0,0xF8,0x3E,0x0F,0x83,0xE0,0xF8,0x3E,0x0F,0x83,0xE0,0xF8,0x3E,0x0F,0x83,0xE0, // Chr$(221)
0x07,0xC1,0xF0,0x7C,0x1F,0x07,0xC1,0xF0,0x7C,0x1F,0x07,0xC1,0xF0,0x7C,0x1F,0x07,0xC1,0xF0,0x7C,0x1F, // Chr$(222)
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // Chr$(223)
Edited 2025-06-16 21:05 by thwill
RAM26
Posted: 10:46pm 17 Jun 2025
Tom and Jim,
Thanks very much for the great responses to my request.
Tom, you hit the nail on the head when you mentioned all 3 characters were not right.
Jim, thanks for providing a solution that's so easy to implement.
Now, I wonder - can I make this change to the font permanent?  If so, how?
Jim, where can I find the FontTweak utility?  Is it still available?
Also, with MMEdit, is there a way to map that into the system editor F4-F2 cycle?
Please advise on all.  Thank you.
Posted: 11:11pm 17 Jun 2025
I expect that the changes to the font will be incorporated in the next MMBasic update.
FontTweak.zip
I will include it in the MMEdit ZIP one day.
I have never tried to integrate MMEdit with the inbuilt editor and not likely to do so.
Sending a 'list' on your device to MMEdit is simple and sending MMEdit code to the device is just as easy.
RAM26
Posted: 12:12am 18 Jun 2025
Thanks again Jim.  You rule.
My goal is to hack Font #3 (16x24) to display the upper 96 characters of the old IBM ASCII codes.  I think these tools will help get me there.
Unless...maybe you've done it already?
Posted: 06:55am 18 Jun 2025
Two 16x24 fonts
PS2thin1_16x24.zip
That should be a start
