Local Time 13:05 21 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Json$ parsing help
Doktorn
Posted: 02:35pm 02 Nov 2025
Hi
I have a Json$ file with multiple instances of a label ”SEK_per_kWh”.
On another system I can use  print Json$(x$,”SEK_per_kWh[6]”) for
instance nbr 6. I have tried with Print Json$(inp%(),”SEK_per_kWh”)
witch correctly give me the first post but Print Json$(inp%(),”SEK_per_kWh[6]”)
gives nothing.
Can’t get it to work in MM RP2040 V6.00.01.RC6.
My question, how can I parse a Json file with multiple  instances of
the same label.
/Lasse
Posted: 02:43pm 02 Nov 2025
Post your entire json string.
Doktorn
Posted: 02:50pm 02 Nov 2025
Hi
The file is large, 13620 bytes.
It's  this times 96
{"SEK_per_kWh":0.27497,"EUR_per_kWh":0.02498,"EXR":11.007546,"time_start":"2025-11-02T00:00:00+01:00","time_end":"2025-11-02T00:15:00+01:00"}
/Lasse
Pluto
Posted: 03:43pm 02 Nov 2025
Hi Lasse,
It seems that we are working with very similar topics! You are parsing swedish and myself finnish electricity prices.
Starting from the long Json$ string (stoted in a longsting buffer) I first search for the first "{" and remove everything up to that point. Then search for the keywords in the Json$. Save data in arrays.
Then again remove the "used" part of the Json$ (LONGSTRING TRIM buff%(),1) and the starting over again.
Here is short part of my code:
WEB open TCP CLIENT url$,80
 WEB TCP CLIENT REQUEST Query$,buff%(),15000
 WEB close TCP CLIENT
 print "TCP time:",timer,"ms"
 'a%: position of first "{" in buff%().
 print "LLEN(buff%() Part 1:";LLEN(buff%())
 a%=LinStr(buff%(),"{")-1: if deb then print "a%=";a%
 If a% <> -1 Then
   'LongString trim buff%(),a% 'tar bort a% tecken fr?n b?rjan av buff%()
   if deb then Print "buff%()=",
   if deb then LongString print buff%()
   for i=1 to 48
     a%=LinStr(buff%(),"{")-1 'find position of first {
     LongString trim buff%(),a% 'remove all before {
     PriceQuart(i)=CINT(val(Json$(buff%(),"hinta"))*1.255*100)/100 'incl 25.5% VAT
     ClockQuart$(i)=right$(Json$(buff%(),"aikaleima_suomi"),5)
     a%=a%+1
     LongString trim buff%(),1 'remove first char left in buff().(should be "{")
   next i
For some unknown reason I was not able to get all 96 datapoints reliably received at once; hence i=1 to 48. (And later a similar sequence for i=49 to 96)
Short dictionary:
hinta: price
aikaleima_suomi: timelabel_finland
My code is based on what others have published on thebackshed. You will probably find better explanations by others in this forum.
Lycka till!
Pluto
Doktorn
Posted: 08:32pm 02 Nov 2025
This is the entire json string.
[{"SEK_per_kWh":0.27497,"EUR_per_kWh":0.02498,"EXR":11.007546,"time_start":"2025-11-02T00:00:00+01:00","time_end":"2025-11-02T00:15:00+01:00"},{"SEK_per_kWh":0.22081,"EUR_per_kWh":0.02006,"EXR":11.007546,"time_start":"2025-11-02T00:15:00+01:00","time_end":"2025-11-02T00:30:00+01:00"},{"SEK_per_kWh":0.23897,"EUR_per_kWh":0.02171,"EXR":11.007546,"time_start":"2025-11-02T00:30:00+01:00","time_end":"2025-11-02T00:45:00+01:00"},{"SEK_per_kWh":0.21388,"EUR_per_kWh":0.01943,"EXR":11.007546,"time_start":"2025-11-02T00:45:00+01:00","time_end":"2025-11-02T01:00:00+01:00"},{"SEK_per_kWh":0.2797,"EUR_per_kWh":0.02541,"EXR":11.007546,"time_start":"2025-11-02T01:00:00+01:00","time_end":"2025-11-02T01:15:00+01:00"},{"SEK_per_kWh":0.25538,"EUR_per_kWh":0.0232,"EXR":11.007546,"time_start":"2025-11-02T01:15:00+01:00","time_end":"2025-11-02T01:30:00+01:00"},{"SEK_per_kWh":0.22048,"EUR_per_kWh":0.02003,"EXR":11.007546,"time_start":"2025-11-02T01:30:00+01:00","time_end":"2025-11-02T01:45:00+01:00"},{"SEK_per_kWh":0.20441,"EUR_per_kWh":0.01857,"EXR":11.007546,"time_start":"2025-11-02T01:45:00+01:00","time_end":"2025-11-02T02:00:00+01:00"},{"SEK_per_kWh":0.23237,"EUR_per_kWh":0.02111,"EXR":11.007546,"time_start":"2025-11-02T02:00:00+01:00","time_end":"2025-11-02T02:15:00+01:00"},{"SEK_per_kWh":0.24151,"EUR_per_kWh":0.02194,"EXR":11.007546,"time_start":"2025-11-02T02:15:00+01:00","time_end":"2025-11-02T02:30:00+01:00"},{"SEK_per_kWh":0.24954,"EUR_per_kWh":0.02267,"EXR":11.007546,"time_start":"2025-11-02T02:30:00+01:00","time_end":"2025-11-02T02:45:00+01:00"},{"SEK_per_kWh":0.23391,"EUR_per_kWh":0.02125,"EXR":11.007546,"time_start":"2025-11-02T02:45:00+01:00","time_end":"2025-11-02T03:00:00+01:00"},{"SEK_per_kWh":0.30931,"EUR_per_kWh":0.0281,"EXR":11.007546,"time_start":"2025-11-02T03:00:00+01:00","time_end":"2025-11-02T03:15:00+01:00"},{"SEK_per_kWh":0.31052,"EUR_per_kWh":0.02821,"EXR":11.007546,"time_start":"2025-11-02T03:15:00+01:00","time_end":"2025-11-02T03:30:00+01:00"},{"SEK_per_kWh":0.30854,"EUR_per_kWh":0.02803,"EXR":11.007546,"time_start":"2025-11-02T03:30:00+01:00","time_end":"2025-11-02T03:45:00+01:00"},{"SEK_per_kWh":0.27915,"EUR_per_kWh":0.02536,"EXR":11.007546,"time_start":"2025-11-02T03:45:00+01:00","time_end":"2025-11-02T04:00:00+01:00"},{"SEK_per_kWh":0.31041,"EUR_per_kWh":0.0282,"EXR":11.007546,"time_start":"2025-11-02T04:00:00+01:00","time_end":"2025-11-02T04:15:00+01:00"},{"SEK_per_kWh":0.30931,"EUR_per_kWh":0.0281,"EXR":11.007546,"time_start":"2025-11-02T04:15:00+01:00","time_end":"2025-11-02T04:30:00+01:00"},{"SEK_per_kWh":0.30997,"EUR_per_kWh":0.02816,"EXR":11.007546,"time_start":"2025-11-02T04:30:00+01:00","time_end":"2025-11-02T04:45:00+01:00"},{"SEK_per_kWh":0.30062,"EUR_per_kWh":0.02731,"EXR":11.007546,"time_start":"2025-11-02T04:45:00+01:00","time_end":"2025-11-02T05:00:00+01:00"},{"SEK_per_kWh":0.31383,"EUR_per_kWh":0.02851,"EXR":11.007546,"time_start":"2025-11-02T05:00:00+01:00","time_end":"2025-11-02T05:15:00+01:00"},{"SEK_per_kWh":0.31691,"EUR_per_kWh":0.02879,"EXR":11.007546,"time_start":"2025-11-02T05:15:00+01:00","time_end":"2025-11-02T05:30:00+01:00"},{"SEK_per_kWh":0.31955,"EUR_per_kWh":0.02903,"EXR":11.007546,"time_start":"2025-11-02T05:30:00+01:00","time_end":"2025-11-02T05:45:00+01:00"},{"SEK_per_kWh":0.33166,"EUR_per_kWh":0.03013,"EXR":11.007546,"time_start":"2025-11-02T05:45:00+01:00","time_end":"2025-11-02T06:00:00+01:00"},{"SEK_per_kWh":0.33342,"EUR_per_kWh":0.03029,"EXR":11.007546,"time_start":"2025-11-02T06:00:00+01:00","time_end":"2025-11-02T06:15:00+01:00"},{"SEK_per_kWh":0.33716,"EUR_per_kWh":0.03063,"EXR":11.007546,"time_start":"2025-11-02T06:15:00+01:00","time_end":"2025-11-02T06:30:00+01:00"},{"SEK_per_kWh":0.35158,"EUR_per_kWh":0.03194,"EXR":11.007546,"time_start":"2025-11-02T06:30:00+01:00","time_end":"2025-11-02T06:45:00+01:00"},{"SEK_per_kWh":0.35874,"EUR_per_kWh":0.03259,"EXR":11.007546,"time_start":"2025-11-02T06:45:00+01:00","time_end":"2025-11-02T07:00:00+01:00"},{"SEK_per_kWh":0.36182,"EUR_per_kWh":0.03287,"EXR":11.007546,"time_start":"2025-11-02T07:00:00+01:00","time_end":"2025-11-02T07:15:00+01:00"},{"SEK_per_kWh":0.37194,"EUR_per_kWh":0.03379,"EXR":11.007546,"time_start":"2025-11-02T07:15:00+01:00","time_end":"2025-11-02T07:30:00+01:00"},{"SEK_per_kWh":0.37811,"EUR_per_kWh":0.03435,"EXR":11.007546,"time_start":"2025-11-02T07:30:00+01:00","time_end":"2025-11-02T07:45:00+01:00"},{"SEK_per_kWh":0.38372,"EUR_per_kWh":0.03486,"EXR":11.007546,"time_start":"2025-11-02T07:45:00+01:00","time_end":"2025-11-02T08:00:00+01:00"},{"SEK_per_kWh":0.38548,"EUR_per_kWh":0.03502,"EXR":11.007546,"time_start":"2025-11-02T08:00:00+01:00","time_end":"2025-11-02T08:15:00+01:00"},{"SEK_per_kWh":0.38791,"EUR_per_kWh":0.03524,"EXR":11.007546,"time_start":"2025-11-02T08:15:00+01:00","time_end":"2025-11-02T08:30:00+01:00"},{"SEK_per_kWh":0.39121,"EUR_per_kWh":0.03554,"EXR":11.007546,"time_start":"2025-11-02T08:30:00+01:00","time_end":"2025-11-02T08:45:00+01:00"},{"SEK_per_kWh":0.39418,"EUR_per_kWh":0.03581,"EXR":11.007546,"time_start":"2025-11-02T08:45:00+01:00","time_end":"2025-11-02T09:00:00+01:00"},{"SEK_per_kWh":0.40409,"EUR_per_kWh":0.03671,"EXR":11.007546,"time_start":"2025-11-02T09:00:00+01:00","time_end":"2025-11-02T09:15:00+01:00"},{"SEK_per_kWh":0.40574,"EUR_per_kWh":0.03686,"EXR":11.007546,"time_start":"2025-11-02T09:15:00+01:00","time_end":"2025-11-02T09:30:00+01:00"},{"SEK_per_kWh":0.40244,"EUR_per_kWh":0.03656,"EXR":11.007546,"time_start":"2025-11-02T09:30:00+01:00","time_end":"2025-11-02T09:45:00+01:00"},{"SEK_per_kWh":0.40134,"EUR_per_kWh":0.03646,"EXR":11.007546,"time_start":"2025-11-02T09:45:00+01:00","time_end":"2025-11-02T10:00:00+01:00"},{"SEK_per_kWh":0.4141,"EUR_per_kWh":0.03762,"EXR":11.007546,"time_start":"2025-11-02T10:00:00+01:00","time_end":"2025-11-02T10:15:00+01:00"},{"SEK_per_kWh":0.41091,"EUR_per_kWh":0.03733,"EXR":11.007546,"time_start":"2025-11-02T10:15:00+01:00","time_end":"2025-11-02T10:30:00+01:00"},{"SEK_per_kWh":0.40519,"EUR_per_kWh":0.03681,"EXR":11.007546,"time_start":"2025-11-02T10:30:00+01:00","time_end":"2025-11-02T10:45:00+01:00"},{"SEK_per_kWh":0.40067,"EUR_per_kWh":0.0364,"EXR":11.007546,"time_start":"2025-11-02T10:45:00+01:00","time_end":"2025-11-02T11:00:00+01:00"},{"SEK_per_kWh":0.41102,"EUR_per_kWh":0.03734,"EXR":11.007546,"time_start":"2025-11-02T11:00:00+01:00","time_end":"2025-11-02T11:15:00+01:00"},{"SEK_per_kWh":0.41421,"EUR_per_kWh":0.03763,"EXR":11.007546,"time_start":"2025-11-02T11:15:00+01:00","time_end":"2025-11-02T11:30:00+01:00"},{"SEK_per_kWh":0.41223,"EUR_per_kWh":0.03745,"EXR":11.007546,"time_start":"2025-11-02T11:30:00+01:00","time_end":"2025-11-02T11:45:00+01:00"},{"SEK_per_kWh":0.41256,"EUR_per_kWh":0.03748,"EXR":11.007546,"time_start":"2025-11-02T11:45:00+01:00","time_end":"2025-11-02T12:00:00+01:00"},{"SEK_per_kWh":0.41598,"EUR_per_kWh":0.03779,"EXR":11.007546,"time_start":"2025-11-02T12:00:00+01:00","time_end":"2025-11-02T12:15:00+01:00"},{"SEK_per_kWh":0.50536,"EUR_per_kWh":0.04591,"EXR":11.007546,"time_start":"2025-11-02T12:15:00+01:00","time_end":"2025-11-02T12:30:00+01:00"},{"SEK_per_kWh":0.64603,"EUR_per_kWh":0.05869,"EXR":11.007546,"time_start":"2025-11-02T12:30:00+01:00","time_end":"2025-11-02T12:45:00+01:00"},{"SEK_per_kWh":0.70481,"EUR_per_kWh":0.06403,"EXR":11.007546,"time_start":"2025-11-02T12:45:00+01:00","time_end":"2025-11-02T13:00:00+01:00"},{"SEK_per_kWh":0.65957,"EUR_per_kWh":0.05992,"EXR":11.007546,"time_start":"2025-11-02T13:00:00+01:00","time_end":"2025-11-02T13:15:00+01:00"},{"SEK_per_kWh":0.66959,"EUR_per_kWh":0.06083,"EXR":11.007546,"time_start":"2025-11-02T13:15:00+01:00","time_end":"2025-11-02T13:30:00+01:00"},{"SEK_per_kWh":0.72441,"EUR_per_kWh":0.06581,"EXR":11.007546,"time_start":"2025-11-02T13:30:00+01:00","time_end":"2025-11-02T13:45:00+01:00"},{"SEK_per_kWh":0.72551,"EUR_per_kWh":0.06591,"EXR":11.007546,"time_start":"2025-11-02T13:45:00+01:00","time_end":"2025-11-02T14:00:00+01:00"},{"SEK_per_kWh":0.74345,"EUR_per_kWh":0.06754,"EXR":11.007546,"time_start":"2025-11-02T14:00:00+01:00","time_end":"2025-11-02T14:15:00+01:00"},{"SEK_per_kWh":0.7516,"EUR_per_kWh":0.06828,"EXR":11.007546,"time_start":"2025-11-02T14:15:00+01:00","time_end":"2025-11-02T14:30:00+01:00"},{"SEK_per_kWh":0.75479,"EUR_per_kWh":0.06857,"EXR":11.007546,"time_start":"2025-11-02T14:30:00+01:00","time_end":"2025-11-02T14:45:00+01:00"},{"SEK_per_kWh":0.75336,"EUR_per_kWh":0.06844,"EXR":11.007546,"time_start":"2025-11-02T14:45:00+01:00","time_end":"2025-11-02T15:00:00+01:00"},{"SEK_per_kWh":0.76877,"EUR_per_kWh":0.06984,"EXR":11.007546,"time_start":"2025-11-02T15:00:00+01:00","time_end":"2025-11-02T15:15:00+01:00"},{"SEK_per_kWh":0.79023,"EUR_per_kWh":0.07179,"EXR":11.007546,"time_start":"2025-11-02T15:15:00+01:00","time_end":"2025-11-02T15:30:00+01:00"},{"SEK_per_kWh":0.79067,"EUR_per_kWh":0.07183,"EXR":11.007546,"time_start":"2025-11-02T15:30:00+01:00","time_end":"2025-11-02T15:45:00+01:00"},{"SEK_per_kWh":0.84868,"EUR_per_kWh":0.0771,"EXR":11.007546,"time_start":"2025-11-02T15:45:00+01:00","time_end":"2025-11-02T16:00:00+01:00"},{"SEK_per_kWh":0.87004,"EUR_per_kWh":0.07904,"EXR":11.007546,"time_start":"2025-11-02T16:00:00+01:00","time_end":"2025-11-02T16:15:00+01:00"},{"SEK_per_kWh":0.88236,"EUR_per_kWh":0.08016,"EXR":11.007546,"time_start":"2025-11-02T16:15:00+01:00","time_end":"2025-11-02T16:30:00+01:00"},{"SEK_per_kWh":0.89656,"EUR_per_kWh":0.08145,"EXR":11.007546,"time_start":"2025-11-02T16:30:00+01:00","time_end":"2025-11-02T16:45:00+01:00"},{"SEK_per_kWh":0.90251,"EUR_per_kWh":0.08199,"EXR":11.007546,"time_start":"2025-11-02T16:45:00+01:00","time_end":"2025-11-02T17:00:00+01:00"},{"SEK_per_kWh":0.91429,"EUR_per_kWh":0.08306,"EXR":11.007546,"time_start":"2025-11-02T17:00:00+01:00","time_end":"2025-11-02T17:15:00+01:00"},{"SEK_per_kWh":0.94059,"EUR_per_kWh":0.08545,"EXR":11.007546,"time_start":"2025-11-02T17:15:00+01:00","time_end":"2025-11-02T17:30:00+01:00"},{"SEK_per_kWh":0.94467,"EUR_per_kWh":0.08582,"EXR":11.007546,"time_start":"2025-11-02T17:30:00+01:00","time_end":"2025-11-02T17:45:00+01:00"},{"SEK_per_kWh":0.98231,"EUR_per_kWh":0.08924,"EXR":11.007546,"time_start":"2025-11-02T17:45:00+01:00","time_end":"2025-11-02T18:00:00+01:00"},{"SEK_per_kWh":0.92496,"EUR_per_kWh":0.08403,"EXR":11.007546,"time_start":"2025-11-02T18:00:00+01:00","time_end":"2025-11-02T18:15:00+01:00"},{"SEK_per_kWh":0.95083,"EUR_per_kWh":0.08638,"EXR":11.007546,"time_start":"2025-11-02T18:15:00+01:00","time_end":"2025-11-02T18:30:00+01:00"},{"SEK_per_kWh":0.94797,"EUR_per_kWh":0.08612,"EXR":11.007546,"time_start":"2025-11-02T18:30:00+01:00","time_end":"2025-11-02T18:45:00+01:00"},{"SEK_per_kWh":0.8991,"EUR_per_kWh":0.08168,"EXR":11.007546,"time_start":"2025-11-02T18:45:00+01:00","time_end":"2025-11-02T19:00:00+01:00"},{"SEK_per_kWh":0.89921,"EUR_per_kWh":0.08169,"EXR":11.007546,"time_start":"2025-11-02T19:00:00+01:00","time_end":"2025-11-02T19:15:00+01:00"},{"SEK_per_kWh":0.88424,"EUR_per_kWh":0.08033,"EXR":11.007546,"time_start":"2025-11-02T19:15:00+01:00","time_end":"2025-11-02T19:30:00+01:00"},{"SEK_per_kWh":0.87928,"EUR_per_kWh":0.07988,"EXR":11.007546,"time_start":"2025-11-02T19:30:00+01:00","time_end":"2025-11-02T19:45:00+01:00"},{"SEK_per_kWh":0.85925,"EUR_per_kWh":0.07806,"EXR":11.007546,"time_start":"2025-11-02T19:45:00+01:00","time_end":"2025-11-02T20:00:00+01:00"},{"SEK_per_kWh":0.87631,"EUR_per_kWh":0.07961,"EXR":11.007546,"time_start":"2025-11-02T20:00:00+01:00","time_end":"2025-11-02T20:15:00+01:00"},{"SEK_per_kWh":0.86244,"EUR_per_kWh":0.07835,"EXR":11.007546,"time_start":"2025-11-02T20:15:00+01:00","time_end":"2025-11-02T20:30:00+01:00"},{"SEK_per_kWh":0.85804,"EUR_per_kWh":0.07795,"EXR":11.007546,"time_start":"2025-11-02T20:30:00+01:00","time_end":"2025-11-02T20:45:00+01:00"},{"SEK_per_kWh":0.85463,"EUR_per_kWh":0.07764,"EXR":11.007546,"time_start":"2025-11-02T20:45:00+01:00","time_end":"2025-11-02T21:00:00+01:00"},{"SEK_per_kWh":0.75864,"EUR_per_kWh":0.06892,"EXR":11.007546,"time_start":"2025-11-02T21:00:00+01:00","time_end":"2025-11-02T21:15:00+01:00"},{"SEK_per_kWh":0.65693,"EUR_per_kWh":0.05968,"EXR":11.007546,"time_start":"2025-11-02T21:15:00+01:00","time_end":"2025-11-02T21:30:00+01:00"},{"SEK_per_kWh":0.60707,"EUR_per_kWh":0.05515,"EXR":11.007546,"time_start":"2025-11-02T21:30:00+01:00","time_end":"2025-11-02T21:45:00+01:00"},{"SEK_per_kWh":0.55302,"EUR_per_kWh":0.05024,"EXR":11.007546,"time_start":"2025-11-02T21:45:00+01:00","time_end":"2025-11-02T22:00:00+01:00"},{"SEK_per_kWh":0.63161,"EUR_per_kWh":0.05738,"EXR":11.007546,"time_start":"2025-11-02T22:00:00+01:00","time_end":"2025-11-02T22:15:00+01:00"},{"SEK_per_kWh":0.62061,"EUR_per_kWh":0.05638,"EXR":11.007546,"time_start":"2025-11-02T22:15:00+01:00","time_end":"2025-11-02T22:30:00+01:00"},{"SEK_per_kWh":0.6053,"EUR_per_kWh":0.05499,"EXR":11.007546,"time_start":"2025-11-02T22:30:00+01:00","time_end":"2025-11-02T22:45:00+01:00"},{"SEK_per_kWh":0.55533,"EUR_per_kWh":0.05045,"EXR":11.007546,"time_start":"2025-11-02T22:45:00+01:00","time_end":"2025-11-02T23:00:00+01:00"},{"SEK_per_kWh":0.42423,"EUR_per_kWh":0.03854,"EXR":11.007546,"time_start":"2025-11-02T23:00:00+01:00","time_end":"2025-11-02T23:15:00+01:00"},{"SEK_per_kWh":0.42126,"EUR_per_kWh":0.03827,"EXR":11.007546,"time_start":"2025-11-02T23:15:00+01:00","time_end":"2025-11-02T23:30:00+01:00"},{"SEK_per_kWh":0.41851,"EUR_per_kWh":0.03802,"EXR":11.007546,"time_start":"2025-11-02T23:30:00+01:00","time_end":"2025-11-02T23:45:00+01:00"},{"SEK_per_kWh":0.41653,"EUR_per_kWh":0.03784,"EXR":11.007546,"time_start":"2025-11-02T23:45:00+01:00","time_end":"2025-11-03T00:00:00+01:00"}]
/Lasse
Doktorn
Posted: 09:08pm 02 Nov 2025
Hi Pluto
Thanks for the tip about parsing my Json$ file. I have used a similar technique when I
decoded XML price documents from the entsoe price database a couple of years ago.
I have an application on an ESP32 with Annex RDS that works well where you can use Json$
in the following way  pris$(1)=json$(le$,"SEK_per_kWh[1]”),pris$(2)=json$(le$,"SEK_per_kWh[2]”)
etc. What I was looking for was from the manual's description of the JSON$ parser.
From the manual.
JSON$(a%(), “weather[0].description”)  What does the number within [0] mean?
/Lasse
Pluto
Posted: 08:17am 03 Nov 2025
  Quote  JSON$(a%(), “weather[0].description”)  What does the number within [0] mean?
The data returned as "weather[0].description" is just a text-string explaining the weather, like "overcast clouds", broken clouds", "heavy snow", "rain" etc.
I have never tried e.g. weather[1].description. I assume that you can have several weather conditions at the same location, e.g. "heavy rain", "strong wind".
Pluto
Posted: 03:34pm 03 Nov 2025
I no longer have convenient a webmite with which to test, but from past posts, this is what is typically returned from api.openweathermap.org
  Quote  {"coord":{"lon":-64.7155,"lat":44.0335},"weather":[{"id":802,"main":"Clouds","description":"scattered clouds","icon":"03d"}],"base":"stations","main":{"temp":278.94,"feels_like":269.44,"temp_min":278.71,"temp_max":279.15,"pressure":1008,"humidity":56},"visibility":10000,"wind":{"speed":10.29,"deg":240,"gust":14.92},"clouds":{"all":46},"dt":1612635812,"sys":{"type":1,"id":549,"country":"CA","sunrise":1612611013,"sunset":1612647345},"timezone":-14400,"id":6057856,"name":"Liverpool","cod":200}
There is no weather[1], only a single instance of the weather values (within "[]"). (But the structure is such that there could be multiple instances.)
The problem that I see with the json string given is that there is no "name" for the multiple "value" instances to be referenced by, and I don't know if there is syntax for which that might work with the MMBasic implementation of json. I made a brief attempt with a picomite and a limited json file using ".[i].SEK_per_kWh"), but got "Error : Dimensions".
I did ask ChatGPT-5 to make a bash script to extract the value. I created a file with just the first 15 values:
  Quote  [{"SEK_per_kWh":0.27497,"EUR_per_kWh":0.02498,"EXR":11.007546,"time_start":"2025-11-02T00:00:00+01:00","time_end":"2025-11-02T00:15:00+01:00"},
Here's the Linux command line, and the results (run on a Seagate Dockstar flashed with openWrt):
  Quote  cat Sw_kwh.json | jq -r '.[] | .SEK_per_kWh'
0.27497
0.22081
0.23897
0.21388
0.2797
0.25538
0.22048
0.20441
0.23237
0.24151
0.24954
0.23391
0.30931
0.31052
0.30854
In that command the "." in ".[]" implies the entire json string.
I don't know if there is magic which would make a MMBasic json query work with this particular json string.
Edited 2025-11-04 01:45 by lizby
Posted: 03:53pm 03 Nov 2025
The json listed doesn't conform to the norm. There should be an outer name and then you could access as an array
 "users": [
   { "name": "Alice", "age": 30 },
   { "name": "Bob", "age": 25 }
users[1].name
Try appending a name at the beginning and a close bracket at the end as in my example and see if the json$ function then works
Pluto
Posted: 05:02pm 03 Nov 2025
Lasse,
your data seems to have the same structure as my data so it should be possible to extract your data with the same procedure as I have used. link to earlier post
[{"aikaleima_suomi":"2025-11-03T00:00","aikaleima_utc":"2025-11-02T22:00","hinta":1.544},{"aikaleima_suomi":"2025-11-03T00:15","aikaleima_utc":"2025-11-02T22:15","hinta":1.508},{"aikaleima_suomi":"2025-11-03T00:30","aikaleima_utc":"2025-11-02T22:30","hinta":1.468},{"aikaleima_suomi":"2025-11-03T00:45","aikaleima_utc":"2025-11-02T22:45","hinta":1.448},{"aikaleima_suomi":"2025-11-03T01:00","aikaleima_utc":"2025-11-02T23:00","hinta":1.307},{"aikaleima_suomi":"2025-11-03T01:15","aikaleima_utc":"2025-11-02T23:15","hinta":0.749},......]
(Full day 96 points, but I had to make two TCP requests á 48 points).
Pluto
Doktorn
Posted: 09:28pm 03 Nov 2025
Thanks everyone for the tips and suggestions.
matherp, your suggestion about adding group name to Json$ files is correct. Works as expected. But for now I will use my current design which consists of an ESP32-S3 with Annex RDS which retrieves and beautifies the Json$ file. The ESP32 then sends the result serially to the pico. It works great.
Here on a Pico with 7" SSD1963  ( the SSD1963 is not supported in Annex )
/Lasse
Doktorn
Posted: 01:25pm 04 Nov 2025
To matherp
I tested with the whole Json file. But it is apparently too big. I got the error message
*** PANIC *** Out of memoryError: Invalid address - resetting
The Json file was validated OK on a website.
/Lasse
Pluto
Posted: 05:13pm 04 Nov 2025
Just some thoughts:
-maybe you tried to put the long Json$ into a normal string?
For long strings there is a special LONGSTRING command.
Page 81 in the manual (PicoMite User Manual, MMBasic BASIC Interpreter Ver 6.00.03)
  Quote  Long Strings
Long Strings are a set of commands and functions that allow MMBasic to manipulate strings of unlimited length and are particularly useful when dealing with data sent via WiFi and the Internet. Standard strings in MMBasic are limited to a maximum length of 255 characters. Long strings duplicate these functions but will work with strings of any length limited only by the amount of available RAM.
Or maybe this is what you did and run out of memory?
Doktorn
Posted: 06:14pm 04 Nov 2025
Hi Pluto
The only way to fit that much data is to use LongString, which I did. I don't even think it's possible to use the Json$ function on regular strings.
See the manual.
  Quote  Returns a string representing a specific item out of the JSON input stored in the longstring array%(). Note that many JSON data sets are quite large and may be too big to parse with the memory available.
I think we can consider the case closed for now.
/Lasse
Edited 2025-11-05 06:32 by Doktorn
