Forum Index : Microcontroller and PC projects : Inverter Software on rPi
Just wondering if anyone here can tell me if this software will run on a rPi. Posted this in the Solar forum, but no response yet. Even better, but a big ask is if someone could confirm it will at least load. Phil Edit:- I see there are different OS's here and should of mentioned mine (3) is running the default Raspian install from Noobs |
A bit odd... the link in the other forum is to a Windows executable and nothing else - so no. Yet there is mention of a manual that lists various Linux versions. Provide more info / URLs? Or use some open source (MPPT?) software and be done with the hassle of proprietary (is it?)? John |
Opps, Wrong thing in the clipboard when I posed the link. The other thread is just over on the Solar Forum here. The link the manufacturers provided for software etc is this. Just a directory listing to download from. Has both 32 & 64 bit Linux version, which I did manage to fire up on a Ubuntu box I have, but following a similar process didn't work on the rPi. That's where I'm wondering if I need a different distribution, but don't know enough of the Linux world to go any further. Have also notices that there is a Ubuntu Dist for the Pi too. Phil |
You will probably have to compile for the source to run it on a RPi I expect all the precompiled ones are for x86, not ARM processors Jim VK7JH MMedit |
I think the link is here And looks x86 so would at least need a recompile. John |
I expect all the precompiled ones are for x86, not ARM processors Thanks Jim & John, That's probably what I should have asked, whether a different compile was required for rPi. Partially had things like CumulusMX in my head that run on multiple platforms. Completely different beast though. Phil. |
