Local Time 18:11 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : BMP085
palcal
Posted: 03:33am 31 Mar 2018
I am trying to use TassyJim's BMP085 code for my new E-Ink display weather station but I get an error code
  Quote  > run
[80] Function Calibrate()
Error: Variable type not specified
Any ideas Jim.
Paul.
Edit. also I have downloaded the latest version of MMEdit but can't transfer files from MM to PC ?Edited by palcal 2018-04-01
Posted: 04:00am 31 Mar 2018
I guess you are using OPTION DEFAULT NONE but haven't declared what type the function returns.
The usual problem with communicating with micromites is, you haven't selected the correct syntax file. MMMEdit uses the syntax file to determine what sort of device it's talking to. Use V5.3 'cos I have been too slack to put out a V5.4 syntax yet.
palcal
Posted: 04:31am 31 Mar 2018
Thanks Jim changed it to 'Function Calibrate() as integer'
that is now OK but when it gets to the pressure I get.
  Quote  > run
[117] Function pressure(oss) As integer
what is the difference ?
Paul.
Posted: 04:43am 31 Mar 2018
In that one, you also need to declare the oss variable type.
It doesn't matter if it's a FLOAT or INTEGER, as long as you declare it.
Function pressure(oss as integer) As integer
It's a bugger being forced to do things properly, but it will be worth it eventually.
palcal
Posted: 04:53am 31 Mar 2018
Thanks Jim this is just a step above my programming level at the moment. Basic has become so advanced.
I've been at it nearly all day, time to go to a BBQ and have a beer.
Paul.
