Forum Index : Microcontroller and PC projects : CP2102 or FDTI
| Maniccyberdog Newbie Joined: 19/02/2018 Location: United KingdomPosts: 13 |
Hi everyone, Just finished my MaxiMite! I’m now playing with Micromite, I have tried connecting an ebay cp2102 to a programmed mx170 28 pin, and get some funny results First windows returned a code 10 error, until I added a power switch on the 3.3v line, now I get some serial output, with 40% of it bad transmission. Should I ditch the cp2102 in favour of a FTDI? I would like to power the pic from the USB port. Any ideas welcome Andy |
| hitsware Guru Joined: 23/11/2012 Location: United StatesPosts: 535 |
These work well I think either FTDI or CP**** will work (though not exactly interchangeable) |
Most USB serial adapters only have limited 3.3V available. I would suggest taking the 5V and using your own 3.3V regulator. There were (and probably still is) a lot of fake FTDI chips in circulation. Jim VK7JH MMedit |
This one works for me ......... 3.45V and all ........ The only advantage I ever saw (for FTDI ) was one may program to invert ...... Thus negate the need for the PicAxe cable .... :) |
| cs41 Newbie Joined: 08/08/2016 Location: AustraliaPosts: 28 |
I find the Freetronics units very reliable. have been using them for a few years now. Maybe not the cheapest but always work for me. Also has a 3.3 / 5 volt switch to output either voltage from it's Vcc out pin to use if you need it. https://www.freetronics.com.au/products/usb-serial-adapter#.WsH0_XVuZNA cs |
go on ebay and snag yourself a baggie of CH340G like these work really well (for me) and you can switch 5V or 3.3V levels with a jumper. I have binned off FTDI and Prolific devices now due to driver glitches (Prolific by far the worst and last one was changed out this very evening!). |
