Local Time 18:10 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMedit is adding lines to a file.
Paul_L
Posted: 05:43pm 07 Aug 2018
I am using NP++ to write a program, and MMedit to format it and therefore confirm that I haven't screwed up one of the structures.
The first line is a remark with the program name.
' A.BAS 8/7/2018 =============
The last line is also a remark.
' EOF ================
I write and save A.BAS in NP++.
I start MMedit and it automatically reloads the newly saved A.BAS. (MMedit had A.BAS loaded the last time I shut it down.)
I then hit Alt+P, then O to format, then Alt+F then S to save, then Alt+F4 to close MMedit.
Windows changes the focus back to NP++ which still has the old A.BAS loaded.
NP++ complains that another program has modified A.BAS so I let it reload A.BAS.
NP++ now shows that A.BAS has two additional blank lines added after the old end. This happens every time.
NP++ also now sometimes shows that the first line of A.BAS has been duplicated.
Huh! What the ... moleijnn;lolasdf ;a; oma;omadf ....
Paul in NYEdited by Paul_L 2018-08-09
Posted: 10:03pm 07 Aug 2018
Doing some of the formatting and checking procedures when the file doesn't have a final CRLF was causing problems so some of the procedures will add a CRLF 'to be sure'
I have only ever seen one blank line added.
I can't think of any reason for one duplicated line being added to the start of the file.
I will do some testing with NP++
What version of NP++ are you running. I am using 32bit V7.5.8
Paul_L
Posted: 11:48pm 07 Aug 2018
Hi Jim,
V 3.7.5 OS Ver 10
Paul in NY
Paul_L
Posted: 12:59am 08 Aug 2018
Hi Jim,
It always seems to add two CRLFs at the end resulting in two blank lines.
The next time around it doesn't add any more, it's satisfied with the two.
Paul in NY
Posted: 05:01am 08 Aug 2018
I don't know how many times I have told programmers that they need a trailing semicolon to suppress the addition of a newline in their file.
  Quote   PRINT #f, txt$;
Guess what I had left out.
The reason for the second newline was a bit more complicated.
I don't think I have broken anything else during the fix.
Try this updated TKN file
2018-08-08_145646_MMedit.zip
I do get very nervous about files without a newline on the last line.
Paul_L
Posted: 10:45am 08 Aug 2018
Hi Jim,
The last line of my files do not normally have a trailing newline. The new .tkn no longer adds any lines after the last line even without a newline at the end.
Are you saying that a trailing semicolon on the last line of the file will suppress the addition of a new line to the file, even though there is no trailing newline, like this?
EOF: '=======================================================;
Paul in NY
Azure
Posted: 10:51am 08 Aug 2018
I think he was referring to an oops he did in his program source code for MMEdit
Posted: 09:45pm 08 Aug 2018
  Azure said   I think he was referring to an oops he did in his program source code for MMEdit
Correct.
I made one of the silly mistakes that I should have known better about.
It didn't matter normally because MMEdit does some cleaning up of the file endings when the file is opened. This hid the issue from me.
Paul_L
Posted: 07:04pm 09 Aug 2018
I'm older than you .... therefore I have made more silly mistakes in my time.
I'm glad I could help uncover this one and you could shoot the bug.
Paul in NY
