Forum Index : Microcontroller and PC projects : MMBasic internal editor bug.
| Paul_L Guru Joined: 03/03/2016 Location: United StatesPosts: 769 |
I think I found a bug. Running MMBasic under DOS on a Windows 10 pro Dell machine with a USB keyboard the internal editor sticks a colon ":" into the code when I hit the caps lock key. Huh????? Paul in NY |
Not just in the editor. Repeatedly pressing CapsLock gives: DOS MMBasic Ver 5.04.09 Copyright 2011-2018 Geoff Graham > 80 :3038 :38333033 :33333833 :33333333 :33333333 :33333333 : Running this program: pressing "a", "s", then CapsLock gives: DOS MMBasic Ver 5.04.09 Copyright 2011-2018 Geoff Graham a 97 s 115 8 0 : 58 8 0 : 58 8 0 : 58 8 0 I tried V4.0 and V4.5 with similar problems (also Windows 10 but a HP) Jim VK7JH MMedit |
Thanks Jim, I thought something was wrong with my eyes. Your further confirmation is ingenious! Paul in NY |
Thanks. It is caused by some debug code that was left in. I will fix it in the next beta. Geoff Geoff Graham - http://geoffg.net |
Hey Geoff, note that I found it in the DOS version. It might also need the same fix in the various PIC versions. Needless to say it isn't very critical so do it after your vacation in Ireland. Have a good trip! Paul in NY |
