Forum Index : Microcontroller and PC projects : $48 Ebay Battery Monitor - Caravans?
| ion507 Newbie Joined: 05/12/2014 Location: AustraliaPosts: 14 |
I saw this posted on a camper trailer Facebook page. For the price, it may be just what someone is looking for as an easy fit for a basic 12V setup. 3 parts to it are current transformer, electronics module and the display connected by a USB cable. Obviously it won't do the job of a $500 Battery Management System. www.ebay.com.au/itm/Wireless-Voltmeter-Ammeter-DC-120V-100A-VOLTAGE-AMP-AH-SOC-Power-Battery-Tester/163091909578 Their description: Battery Status At A Glance. Charging status indicator, looks like a smartphone. Combines many functions in one, Dual display Voltage (V), Current (A), Capacity (AH) Power (W/KW), Energy (KWH) Temperature (C), Working Hours (H) By turning External device/Relay on and off, it can control external devices, such cut off Power input. Trigger external Relay (Not included) when the reading reach preset value. [OVP] Over Charge Voltage protection [LVP] Over Discharge Voltage protection [OCP] Over Discharge Current protection [NCP] Over Charge Current protection Come with a Through-hole Current transformer, it doesn't require shunt. The current sensor can be placed on the Positive or Negative side of power. Reverse polarity protection. Doesn't require isolated power, self-powered 6-80V. Nondestructive installation, it is very easy to install. |
I don't think so. It will be a hall effect sensor. Provided it can be configured for the different battery types, the price is good. Jim VK7JH MMedit |
Don't know if can be configured for different battery types, probably just set the battery capacity. Must be able to change those voltage and current protection levels too. Here's the current sensor: |
The listing mainly refers to a Hall effect sensor, so it will be :) John |
Very interesting. I don't see where it explains what about it is "Wireless". Has anyone found the "English manual"? This Aliexpress page has more info: https://www.aliexpress.com/item/DC-120v-Wireless-voltage-meter-Gauges-ammeter-Voltmeter-Battery-Charging-coulometer-capa city-Power-detector-Tester/32858623812.html?spm=2114.search0104.8.9.5b9b7b66csmh87&priceBeautifyAB=0 The wireless part refers to communication between the display and detection modules. Two relays can be controlled by settings to cut charging circuit and/or load circuit (as I read it). PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
| mikeb Senior Member Joined: 10/04/2016 Location: AustraliaPosts: 178 |
Have ordered two of them. On the slow boat though. Seller says it comes with an English manual but is probably chinglish. The website photos show a rear view which clearly shows a plugin wifi module. There are 10 kinds of people in the world. Those that understand binary and those that don't. |
| Turbo46 Guru Joined: 24/12/2017 Location: AustraliaPosts: 1693 |
This device is also available from Banggood Here - There is an Instructions pdf for download. Bill Keep safe. Live long and prosper. |
| Bill7300 Senior Member Joined: 05/08/2014 Location: AustraliaPosts: 159 |
Banggood is restocking at the moment though .... the other Bill Bill |
| Benzol Regular Member Joined: 07/01/2015 Location: AustraliaPosts: 64 |
Banggood have a couple of different units. I have this one but not installed yet. https://www.banggood.com/PZEM-031-DC-6_5-100V-20A-4-in-1-Digital-Display-LCD-Screen-Voltage-Current-Power-Energy-Meter-p -1111791.html?rmmds=myorder&cur_warehouse=CN db |
