Forum Index : Microcontroller and PC projects : 9341 white line
I bought an ili9341 lcd (backpack type). Connected to the MX170 it works, touch also, but the display has a flaw The display is 320x240 There is a white line (vertical at X=318 from top to bottom). I assume it is a flaw in the display, since whatever I do this line stays white. (first I though it was backlight bleeding through the edge of the active area, but experiemnts pointed out it was IN the active area at location 318). Software MMbasic 5.04.10 beta 9 (but same in 5.04.09 release). I assume this is not a software bug in MMbasic, but realy a display fault. Volhout PicomiteVGA PETSCII ROBOTS |
Yes - this is a display issue and not an MMBASIC issue. I have had a few TFTs arrive like this. The first time I tried fixing it the thin glass got cracked. Next couple of TFTs I created even more damage. So I now test everything when they arrive and immediately report back to the supplier if I have damaged units. My only suggestion to try is to slightly (i.e. gently) push down over different parts of the TFT glass to see if the line disappears. This probably won't fix your issue, but you may get lucky! ![]() If you order a replacement from the likes of eBay then can I suggest you order at least two - they are cheap enough to do this, and will overcome the common issue of something not working as you can try the 'others' to help pinpoint things such as this. |
