Local Time 18:20 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Highest value in an array
viscomjim
Posted: 07:35pm 20 Sep 2018
I can't seem to see the forest fore the trees moment...
I have a simple 10 element array Score(1) thru Score(10). Each element has a different number in it. I am trying to do two things, first find which element has the highest number in it and then which elements are the same as the highest number.
I have tried this...
For Zz = 1 to 9
If Score(Zz) > Score(Zz + 1) Then
WinTemp = Zz
Else
WinTemp = Zz + 1
End If
Next Zz
Print "High Score = ";Score(WinTemp)
Big fat fail. Any ideas on finding the high score and then which elements are tied with the high score?
viscomjim
Posted: 08:36pm 20 Sep 2018
Ok played a bit more... found highest value, now to find ties... need to untie my brain a bit.
Dim Score(10) = (140, 13, 99, 2, 22, 210, 37, 20, 120, 40)
Max = 0
For Zz = 1 to 10
If Score(Zz) > Max Then
Max = Score(Zz)
MaxLoc = Zz
End If
Next Zz
Print "max = ";Max;" in location ";MaxLoc
Posted: 10:32pm 20 Sep 2018
This is one way
  Quote   DIM Score(10) = (140, 13, 99, 2, 22, 210, 37, 20, 120, 40, 210)' needed extra value for location zero
Max = 0
Maxes =
0
FOR Zz = 1 TO 10
IF Score(Zz) > Max THEN
Max = Score(Zz)
'MaxLoc = Zz
END IF
NEXT Zz
PRINT "max = ";Max
FOR Zz = 1 TO 10
IF Max = Score(Zz) THEN
PRINT "In location ";Zz
Maxes = Maxes +
1
ENDIF
NEXT Zz
PRINT "Total sharing max = ";Maxes
I had to put an extra value in the array initialization line to fill location Score(0)
That would depend on what OPTION BASE you have set.
I often find that doing a 'sort' on the array lets you pull the various rankings out easily. It depends on what the goal is.
> RUN
max = 210
In location 5
In location 10
Total sharing max = 2
viscomjim
Posted: 05:36am 22 Sep 2018
Excellent, thank you TassyJim!
