Forum Index : Microcontroller and PC projects : Armmite-H7 5.04.32, ADC tuning
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11830 |
An optional parameter on SETPIN can now be used to select how many bits of resolution should be used for ADC conversions. Valid values are 8, 10, 12, 14, and 16. The more bits the slower the conversion. A single conversion takes between 0.127mSec (8-bit, 4x oversampling) to 0.6mSec (16-bit, 64x oversampling). 2018-09-30_033822_Armmite1.3.zip 2018-09-30_033911_Armmite_H7_Manual.pdf |
TassyJim![]() Guru Joined: 07/08/2011 Location: AustraliaPosts: 6602 |
Thanks Peter, That works well. I can now do some experimenting with data acquisition and mains power monitoring. I plan on taking a reading every mS with plenty of time do do other things with the data as it arrives. Jim VK7JH MMedit |
