Local Time 03:42 15 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : VAR SAVE Problem
Turbo46
Posted: 03:51am 04 Nov 2018
Hi All,
I'M having trouble with the VAR SAVE command. It appears to be corrupting messages sent to Com2 to which I have Terra Term connected. The program below will save the variables if rto% is not 1 but but will save them if it is anything else. The escape sequences in SUB CLS2 are still being transmitted in the background while the VAR SAVE command is happening. If I un-comment the line 12:
' DO: LOOP UNTIL LOF(#2) = 256: PAUSE 20 ' Wait til message sent
OR
If I comment out the line with the VAR SAVE command in it the text is displayed correctly on Terra Term. MMBasic is version 5.0405 and I'm reluctant to try a later version because the chip is on a breadboard under a birds nest of wires and difficult to remove. I see nothing in the change log that mentions this problem.
Am I missing something or is this a bug?
Bill
OPTION EXPLICIT
DIM MyAdd%=1, bd% = 2, DOPulse% = 10
DIM MyAdd2% = MyAdd%, bd2% = bd%, DOPulse2% = DOPulse% ' Temp values
DIM rto% ' Response Time Out
DIM STRING baud(3) LENGTH 5 = ("1200", "4800", "9600", "19200")
PRINT " MMBasic version "MM.VER
DO
INPUT "Enter rto value "; rto%
OPEN "com2: 9600" AS #2
CLS2
IF rto% = 1 THEN
PRINT #2, " TIMEOUT! Settings not changed."
ELSE
MyAdd% = MyAdd2%: bd% = bd2%: DOPulse% = DOPulse2% ' update the variables
VAR SAVE MyAdd%, bd%, DOPulse%
END IF
PRINT #2, " Now Running Modbus Slave..."
DO: LOOP UNTIL LOF(#2) = 256 ' Wait til message sent
PAUSE 20 ' and a bit more to be sure
CLOSE #2
LOOP
' Escape codes to clear the VT100 screen
SUB CLS2
PRINT #2, CHR$(27) "[2J" CHR$(27) "[H"
END SUB
Posted: 05:11am 04 Nov 2018
COM2 is done in firmware rather than a UART.
I expect that the VAR SAVE is interfering with the timing of COM2.
Turbo46
Posted: 05:28am 04 Nov 2018
Thanks Jim, That makes sense. I'll leave line 12 in the program.
Cheers,
Bill
Posted: 03:09am 05 Nov 2018
Good deduction Jim.
Yes, writing to the flash is one of the few times where PIC32 interrupts must be temporarily disabled and that would disrupt send/receive on COM2 which depends on a regular timer interrupt.
Something to add to the manual.
Turbo46
Posted: 05:47am 05 Nov 2018
Thanks Geoff,
I use:
DO: LOOP UNTIL LOF(#fnbr) = 256: PAUSE 20 ' Wait til message sent
elsewhere to be sure that the message has been sent before closing the Com port. The extra pause seems to be necessary because it seems that although the buffer is empty the last byte is still being sent. Closing too early results in an incomplete message transmitted.
On that subject, the Micromite manual says under the heading Reading and Writing:
  Quote  When outputting to a serial port (ie, using PRINT #n, dat) the data will be held in a memory buffer while the serial port is sending it. This means that MMBasic will continue running the program while the data is being transmitted. If you want to be sure that all the data has been sent (perhaps because you want to close the port) you should wait until the LOC() function returns zero indicating that there is nothing waiting to be sent.
Should that be: 'wait until the LOF() function returns 256 indicating...'
I plan to use the same method to implement a DE pin for RS485 without using an inverter ie:
Raise the 'DE' pin
transmit the message
wait til transmission complete (as above)
lower the DE pin
Bill
Posted: 12:36pm 05 Nov 2018
Thanks Bill, you have spotted a bug in the manual !
I will fix it in the next release.
