Local Time 18:33 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Bright Display
palcal
Posted: 12:22am 06 Nov 2018
Is there a display that is easier to see outside in the sunlight (not direct). The ILI9341 has to be well shaded so as it can be seen easily. I use the boat computer and it is so hard to see. I seem to remember some one mentioning it but a search proved fruitless.
ryanm
Posted: 06:51am 06 Nov 2018
You might be better off with an e-Ink display. There's quite a few cheap ones out there now. It works on reflected light not a backlight so it's got perfect visibility in full sunlight.
palcal
Posted: 08:49am 06 Nov 2018
Yes, Peter Mather wrote some code to use them with the Micromite, I tried one and they are just too slow to use for anything that updates quickly. I ended up using it for a little weather station.Edited by palcal 2018-11-07
CaptainBoing
Posted: 11:10am 06 Nov 2018
try a bog-standard LCD black/white panel. A Nokia 5110/original LCD watch display has great full-sun visibility, although a bit small. If you could find a bigger one that would be nice...
128x64 seems possible, something like this:
https://www.ebay.co.uk/itm/12864-Character-LCD-Display-Module-128x64-Dots-Graphic-Matrix-for-esr-meter-LED/171663936688? hash=item27f7f7ccb0:g:EqEAAOSwzrxUzU0x:rk:33:pf:0
or this (dead easy interface )
https://www.ebay.co.uk/itm/LCD-Display-LM6029A-128-x-64-Graphic-3-3-volt-Z895/292065105896?epid=701960553&hash=item44006 fd7e8:g:cfUAAOxyZqhRg5A8:rk:49:pf:0
or this
https://www.ebay.co.uk/itm/ST7920-128x64-12864-LCD-Display-Blue-Backlight-Parallel-Serial-for-Arduino-5V/302309454831?ha sh=item46630c33ef:g:LLMAAOSw42dZDZel:rk:19:pf:0
Edited by CaptainBoing 2018-11-07
palcal
Posted: 08:52pm 06 Nov 2018
It would have to have Touch capability.
CaptainBoing
Posted: 10:24pm 06 Nov 2018
ah. that might be a problem.
Posted: 08:38am 07 Nov 2018
  Quote  It would have to have Touch capability.
Available from other places, needs an XPT2046 to I/F
Posted: 09:28am 07 Nov 2018
LCD's (and other displays) that can be read in direct sunlight are a special art.
There are several approaches to achieve what you need
1/ increase the brightness of the backlight (in other words, remove the plastic part behind the glass, and make a high power LED (alu) frame that can get rid of the heat generated by the LED's. This is what they do in cash machines.
2/ use transflective displays (especially in combination with a light sensor this works well) in darkness the standard backlight is ON the display works in transparent mode, when brightness is good, the backlight is switched off, and the display is used reflective mode. For monochrome LCD's this is possible, I am not sure about color.
edit: apparently that can be done:
color lcd direct sunlinght readable
3/ other methods (non LCD) such as LED matrix displays or E-ink. Also here: brightness comes at a cost, since cooling the LED's is essential.
4/ depending on what you need to display, the more recent 7 segment displays can sometimes be used. There are versions that can be read in sunlight. Since you talked about "touch" I assume option 1 or maybe 2 should be exploited.
Edited by Volhout 2018-11-08
