Forum Index : Microcontroller and PC projects : (MM) strange output
| wmh9 Newbie Joined: 09/12/2018 Location: AustraliaPosts: 2 |
Using my Colour Maximite to investigate the inner workings of a SDS011 air particulate sensor, I need to count using the following code but get the strange result shown. What am I doing wrong? count = 2.5 do while count < 9 count = count + 0.1 print count loop 2.6 2.7 2.8 2.9 3 3.1 3.2 3.3 3.4 3.5 3.6 3.7 3.8 3.9 4 4.1 4.2 4.3 4.4 4.5 4.6 4.7 4.8 4.9 5 5.1 5.2 5.3 5.4 5.5 5.6 5.7 5.8 5.9 6 6.1 6.2 6.3 6.4 6.5 6.6 6.7 6.8 6.9 7 7.1 7.2 7.3 7.4 7.5 7.59999 7.69999 7.79999 7.89999 7.99999 8.09999 8.19999 8.3 8.4 8.5 8.6 8.7 8.8 8.9 9 9.1 |
| Turbo46 Guru Joined: 24/12/2017 Location: AustraliaPosts: 1693 |
Hi wmh9, I don't think you are doing anything wrong. I suspect it's a feature of the floating point maths. I'd suggest using the STR$() function but, looking at the manuals, it doesn't seem that the Maximite has the same full featured STR$() function that the Micromite does. Some clever formatting is needed I think. Do you need fixed decimal points for calculation or display? Bill Keep safe. Live long and prosper. |
Chopperp![]() Guru Joined: 03/01/2018 Location: AustraliaPosts: 1126 |
Hi wmh9 & welcome to the forums Try this: count = 2.5 do while count < 9 count = count + 0.1 count$ = format$(count, "%01.1f") print count$ loop See the FORMAT$ function of the CMM manual Brian Edit. My CMM gives the same results BTW Edit 2. Code correction (oops) ChopperP |
Hello wmh9 welcome to the shed. The answers above are correct. It is the way floating point numbers are stored internally, they are only ever a very close approximation - in the above examples that are "wrong" they are only 10 millionths of a digit out. Take a look at this thread from a little while back - it will provide you all the info you could want on this phenomenon http://www.thebackshed.com/forum/forum_posts.asp?TID=10856 |
Thanks everybody for the fixes. I suppose I am just too used to assembler. |
this has caught thousands of programmers over the years and is what the IEEE descibes as "well-meaning ignorance among programmers". If you want to approach it from the assembler angle, you could mutiply everything by 10 (in your case this is enough) - this is called "fixed point". You'll be familiar with that from assembler. This way it is just your output routines that need to remember to format the output before use, but using INTEGERs instead of FLOATs would provide exact x.1 s just as they would in assembler. Below code is a little rough round the edges but you get the idea; your formatting is used just at the output but the maths works as you expect... count = 25 do while count < 90 count = count + 1 print count\10;".";count mod 10 loop If you ever use a floating point maths pack in assembler, you would still encounter the problem of approximation because the FP_Pack is written in or compiled to machine code just as it is with a micromite - The FP routines are inherited from the C compiler (from Microchip) and the C library code ends up in the object code (MMBasic). even in major commercial products it is a pain - google for "Excel rounding error" There are methods to reduce these problems with different algorithms, but they only shunt the problems elsewhere and it is impossible to get rid entirely. To really kick this to death, read this article. https://en.wikipedia.org/wiki/Floating_point_error_mitigation and this https://en.wikipedia.org/wiki/Floating-point_arithmetic |
I wrote uFormat$() back in the Maximite days. It still works the same with more recent MMBasics Jim edit. It fails for some conditions with mmbasic V4.5 due to reverting to scientific notation. VK7JH MMedit |
wmh9, You didn't say whether you wanted the result for display or calculation but changing CaptainBoing's code a little - this will give the result you expected: count = 25 DO WHILE count < 90 count = count + 1 cnt = count/10 PRINT cnt LOOP I'm not sure if it works over a wider range of numbers but it does over the range of numbers you have chosen. Bill Keep safe. Live long and prosper. |
