Forum Index : Guest Book : mmedit update problem
| jeffj Regular Member Joined: 04/02/2012 Location: AustraliaPosts: 84 |
Question for Tassy jim I have recently downloaded the latest version of mmedit MK2 V5.1 onto XP desktop The previous one worked ok when I try to load a program the Upload window comes on and displays "sending documents and settings" Blocks : 64 X modem receive Error invalid syntax. I can connect and read the maximite ok I have removed the original one so cannot go back to that but I do have a copy on my Laptop your help would be appreciated Jeff |
TassyJim![]() Guru Joined: 07/08/2011 Location: AustraliaPosts: 6626 |
This conversation would be better in the microcontrollers forum. You are lucky someone saw it and told me. I am not sure which version of MMEdit you are running. MK2 V5.1 refers to a micromite syntax file, not MMEdit version number. You have to use the correct syntax file to suit your device. The message "X modem receive Error invalid syntax." suggests that the syntax does not match your device. I just posted a new(ish) version of MMEdit onto my website but I don't think you are running that version. Jim VK7JH MMedit |
Thanks Jim I thought I had sent a post but couldn't find it.Sorry to confuse you. Jeff |
