Local Time 18:08 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Size of data files in DOS MMBasic
karjo238
Posted: 04:21am 09 Mar 2019
Hello there!
In among all the messing about I'm doing with MMBasic, I find myself needing to read text from a file that is about 2,600 lines long.
In the documentation, I couldn't find mention of any specific file size restriction, but I have overlooked such details before, so thought it best to doublecheck first.
Can you read from a text file that's probably not that big in terms of file size - just a bit lengthy?
Many thanks,
Joseph.
Posted: 05:50am 09 Mar 2019
The maximum string length is 255 bytes so as long as your lines are less than 255 bytes, you can read a line at a time and process as you go.
If lines are longer than 255 bytes, you can still work in small chunks.
2600 lines is a small file as far as the file system is concerned.
The actual file size limit will depend on the version of MMBasic.
karjo238
Posted: 11:30pm 09 Mar 2019
Jim -
I suspected something like this would be the case, but I didn't want to assume and make an ass out of u and me, as my old boss used to say.
Many thanks,
Joseph
