Forum Index : Microcontroller and PC projects : Micromite 4.5E help
goc30![]() Guru Joined: 12/04/2017 Location: FrancePosts: 435 |
hi I want to use an expander chip MCP23017 to control some buttons and leds for that i have to use an small pic32mx250 and micromite v4.5E to verify all I put on Diy this 2 chips and make a little prog 'test mcp23017 'TRON Dim vport As integer Dim vport1 As integer Dim vport2 As integer Dim txport As string SetPin 6,DIN 'INTH,irqporta SetPin 25,dout vport=0 vport1=-1 vport2=0 I2C open 100,1000 Dim adr_mcp1=&h20 I2C write &h20,0,5,0,0,&hff,0,&hFF 'portA=output direct, portb=input inv Pause(100) I2C write &h20,0,2,&h0D,&hff 'pull up intB 'I2C close Pause(500) Print "begin prog" Do 'I2C open 100,1000 I2C write &h20,0,2,&h12,&h55 Pin(25)=1 Pause(500) I2C write &h20,0,2,&h12,&hAA Pin(25)=0 Pause(500) I2C write &h20,0,1,&h13 I2C read &h20,0,1,vport 'Print Hex$(vport) If vport <> vport1 Then vport1=vport Print "scan rec:";Hex$(vport) End if 'I2C close Loop End but when I run, I have error [35] End if Error: Unexpected text if I erase lines 32 to 35, I have no error and it run corectly (blink is ok) I Have read micromit's manual and I have no see that function "if/endif" is forbiden :-) |
I have same bug with smaller prog without I2C functions 'test mcp23017 'TRON Dim vport As integer Dim vport1 As integer SetPin 30,DIN 'INTH,irqporta SetPin 31,dout vport=0 vport1=-1 Pause(500) Print "begin prog" Do Pin(31)=1 Pause(500) Pin(31)=0 Pause(500) If vport <> vport1 Then vport1=vport Print "scan rec:";Hex$(vport) End if Loop End |
Try ENDIF as one word. If that works, then END IF as two words is broken. Micromites and Maximites! - Beginning Maximite |
yes with "ENDIF" it work correctly and with "END IF" it bug! |
In version 4.6 changelog: so the change came in just after your version. Jim VK7JH MMedit |
| Turbo46 Guru Joined: 24/12/2017 Location: AustraliaPosts: 1693 |
END IF does not work on the Maximite at the moment you must use ENDIF. It can be a bit confusing. Bill Keep safe. Live long and prosper. |
Here I always thought END IF was allowed, but TassyJim is right - it appeared in 4.6. Micromites and Maximites! - Beginning Maximite |
I don't see v4.6 for pic32mx250 (or pic32mx150) where can I download?? |
I'm guessing that you have the latest version of MMBasic for that chip. I you want to use a later version I think you need to go to the MX170. Bill Keep safe. Live long and prosper. |
4.5E is the last version for the PIC32MX150F128 chip. Micromites and Maximites! - Beginning Maximite |
I used this circuit because first I have several in my boxs and especially I wanted to test and understand the function of mcp23017 in "interrupt" mode, and it is not very simple after when all is ok, I put the chip on my proto (with mx470) for info, this is my final prog 'test mcp23017 Dim vport As integer dim vportA as integer 'port for output LEDS Dim vport1 As integer Dim vport2 As integer SetPin 11,INTL,irqportb SetPin 13,dout vport=0 vport1=-1 vport2=0 vportA=0 I2C open 100,1000 Dim adr_mcp1=&h20 'I2C write &h20,0,11,0,0,&hff,0,&hff,0,&hff ,0,&hff,0,&hff ',0,&hFF,0,&hFF I2C write &h20,0,3,0,0,&hff 'IODIR portA=output, portB=input I2C write &h20,0,3,2,0,&hff 'IPOL portA=sorties directes, portB=entrees inversees I2C write &h20,0,3,4,0,&hff 'GPINTEN portA=disable interupt on input, portB=enable int sur entrees I2C write &h20,0,2,7,&h00 'DEFVAL portB=compare I2C write &h20,0,2,9,&h00 'INTCON portB= I2C write &h20,0,3,&h0a,0,&h20 'IOCON portA=no int, portB=MIRROR+ODR+INTPOL I2C write &h20,0,3,&h0c,0,&hFF 'GPPU portA=no pullup, portB=pullup I2C write &h20,0,3,&h0e,0,&hff 'INTF portA=no int, portB=int I2C write &h20,0,1,&h11 'read INTCAPB I2C read &h20,0,1,vport 'init interrupt Pause(500) 'i2c close Print "begin prog" I2C write &h20,0,1,&h13 'init GPIOB I2C read &h20,0,1,vport1 pause(100) Do 'I2C open 100,1000 vportA=(vportA xor 1) 'blink led ecrportA Pin(13)=1 'just to see if pic-prog run Pause(500) vportA=(vportA xor 1) ecrportA Pin(13)=0 Pause(500) 'i2c close Loop End sub ecrporta 'I2C open 100,1000 I2C write &h20,0,2,&h12,vportA 'send to port A of mcp23017 I2C read &h20,0,1,vport1 'must read to valid int (why??) 'I2C close end sub Sub irqportb 'I2C open 100,1000 I2C write &h20,0,1,&h11 'read INTCAPB I2C read &h20,0,1,vport2 'print vport2 if vport2<>0 then if vport2=1 then vportA = (vportA or 2) if vport2=2 then vportA = (vportA and &hFD) ecrporta 'Print "irq rec: ";Hex$(vport2) ';" intcap:";hex$(vport1) end if I2C write &h20,0,1,&h13 'READ GPIO to init int I2C read &h20,0,1,vport1 'I2C close End Sub |
