Forum Index : Microcontroller and PC projects : Limits of variable names
karjo238
Posted: 04:13am 13 Jul 2019
Hey there! I've recently purchased a Micromite Extreme 144 to give all my MMBasic projects a bit more pep, but I'm running up against problems with variable names, and can't find a clear answer in the manual.
I am running MMBasic version 5.0502, and am trying to run a program with variable names of X and X1, J and J2 and so on. These worked on my old Colour Maximite, but now don't seem to be any more.
So, what I need to ask is: What are the rules for creating variables in this version of MMBasic? Can you only have a total of 26 variables, i.e. one per letter, or can you have more and I'm just programming it wrong?
Any help that can be provided would be most appreciated.
Cheers,
Joseph.
seco61
Posted: 04:49am 13 Jul 2019
Hi Joseph.
As per the Micromite manual, variables can be up to 32 characters in length:
  Quote  Naming Conventions
Command names, function names, labels, variable names, etc are not case sensitive, so that "Run" and "RUN" are equivalent and "dOO" and "Doo" refer to the same variable.
The type of a variable can be specified in the DIM command or by adding a suffix to the end of the variable's name. For example the suffix for an integer is '%' so if a variable called nbr% is automatically created it will be an integer. There are three types of variables:
1. Floating point. These can store a number with a decimal point and fraction (eg, 45.386) and also very large numbers. However, they will lose accuracy when more than seven significant digits are stored or manipulated. The suffix is '!' and floating point is the default when a variable is created without a suffix
2. 64-bit integer. These can store numbers with up to 19 decimal digits without losing accuracy but they cannot store fractions (ie, the part following the decimal point). The suffix for an integer is '%'
3. Strings. These will store a string of characters (eg, "Tom"). The suffix for a string is the '$' symbol (eg, name$, s$, etc) Strings can be up to 255 characters long.
Variable names and labels can start with an alphabetic character or underscore and can contain any alphabetic or numeric character, the period (.) and the underscore (_). They may be up to 32 characters long. A variable name or a label must not be the same as a command or a function or one of the following keywords: THEN, ELSE, TO, STEP, FOR, WHILE, UNTIL, MOD, NOT, AND, OR, XOR, AS. Eg, step = 5 is illegal.
Gerard (vk3cg/vk3grs)
disco4now
Posted: 04:50am 13 Jul 2019
Not sure where I copied it from but see below. Your X,X1,J and J2 should be OK, but you can use variable names up to 32 characters. As many as you need until you run out of memory for them. Type the MEMORY command to see how much you have used.
I think what may be different in Micromite is you can't use j$,j%,j together once j is used for a string or integer it cant be used again, so if you have X$,X1$ etc as well then you would have a problem.
Maximum length of a variable name or a label is 32 characters.
Maximum number of dimensions to an array is 8.
Gerry
F4 H7FotSF4xGT
CaptainBoing
Posted: 05:11am 13 Jul 2019
Morning Joseph.
Doesn't sound like you are doing anything wrong and single character/26 variables is definitely not the case.
can you post a bit of your code for us to see?
h
karjo238
Posted: 05:13am 13 Jul 2019
I probably need to clarify what's happening here. This line:
X1=C(C1,1)+(C(C1+1,1)-C(C1,1))*(C1-Int(C1)):X=S1:Y=S2
Throws an error "X already declared". X has been declared earlier in the program, and X1 is the new declaration. They are both integers, so *in theory* they should both work.
I think.
Can anyone shed a light on this?
karjo238
Posted: 05:59am 13 Jul 2019
  CaptainBoing said
Morning Joseph.
h
The problem is I can't really. All I did in the first case was take this code:
http://vintage-basic.net/bcg/superstartrek.bas
and make a few modifications to make it work on MMBasic 4.5.
Now that there is more specific type-checking, I'm going to have to go down the route of rewriting the code from scratch, which won't be too much of a drama as I have already done a version in Python 3 which has SUBs, FUNCTIONs, etc, and all I really need to do is change the program structures from Python to BASIC.
Many thanks for your guidance anyhow,
Joseph.
Turbo46
Posted: 07:49am 13 Jul 2019
Hi karjo238,
Line 440 of the original program says:
440 P=10:P0=P:S9=200:S=0:B9=2:K9=0:X$="":X0$=" IS "
So X is already declared as X$. As disco4now said if you use X$ you cannot use X%. Using X without declaring the type of variable will default to a floating point anyway (X!).
All you need to do is change all occurrences of X$ to XA$ (for example) and do the same for other variable names that cause the same problem.
You may want to change all X variables to X% and similar to make them integers rather than floating point variables (after you have the program working). The program should then run faster.
Bill
twofingers
Posted: 10:38am 13 Jul 2019
  Turbo46 said  ... to make them integers rather than floating point variables ...
Bill
Yes, it should. But it does not!
A short test on a ARMmite MMBasic Version 5.04.33:
Dim i,a As integer
Dim j,b As float
Timer=0
For i = 1 To 50000:a = i + i:Next i
For i = 1 To 50000:a = i * i:Next i
Print Timer
Timer=0
For j = 1 To 50000:b = j + j:Next j
For j = 1 To 50000:b = j * j:Next j
Print Timer
End
Result:
  Quote   891
854
On a MM2 the same relation - float is faster than integer -, but slower.
In general, I do not think it's a good idea to use integers to get faster.
Maybe Geoff has an idea why ...?
Michael
Posted: 12:02pm 13 Jul 2019
Bill
Hmmm ... Interesting indeed. Integers are a third slower than floats with MMBasic DOS: 62 & 47
Turbo46
Posted: 12:28pm 13 Jul 2019
Thanks Michael and Lizby,
That's what happens when you assume. I am surprised and disappointed. Integers was one reason that I was waiting for MMBasic for the Maximite!
Can somebody please explain?
Bill
Posted: 01:00pm 13 Jul 2019
  Quote  Yes, it should. But it does not!
It does if you get your test code correct
Dim i,a As integer
sets i as a float and a as an integer
try
dim integer i,a
or
Dim i as integer,a As integer
or
OPTION DEFAULT INTEGER
DIM i,a
DIM FLOAT j,b
etc.
Edited by matherp 2019-07-14
Turbo46
Posted: 01:32pm 13 Jul 2019
Thank you Peter,
So each time around in the loop the integer is converted to a float to add the two numbers. That's what causes the longer time for the 'integer' part of the test to execute.
Timings on my DOS MMBasic with the corrected program.were:
78
94
My faith is restored.
Bill
twofingers
Posted: 02:37pm 13 Jul 2019
oops! SORRY!
Thanks Peter!
New results for
Dim integer i,a
Dim float j,b
... and the code above
  Quote   829
854
But the difference seems very small.
Dim integer i,a
Dim float j,b
Timer=0
For i = 1 To 50000:a = i - i:Next i
For i = 1 To 50000:a = i / i:Next i
Print "Integer ="Timer"ms"
Timer=0
For j = 1 To 50000:b = j - j:Next j
For j = 1 To 50000:b = j / j:Next j
Print "Float ="Timer"ms"
End
gives
[code]Integer = 884ms
Float = 855ms[/code]
twofingers
Posted: 02:56pm 13 Jul 2019
I think it's time to see at the details:
Dim integer i,a
Dim float j,b
Timer=0
Print "+ Integer ="Timer"ms"
Timer=0
Print "* Integer ="Timer"ms"
Timer=0
Print "- Integer ="Timer"ms"
Timer=0
Print "/ Integer ="Timer"ms"
Print
Timer=0
Print "+ Float ="Timer"ms"
Timer=0
Print "* Float ="Timer"ms"
Timer=0
Print "- Float ="Timer"ms"
Timer=0
Print "/ Float ="Timer"ms"
End
Result:
+ Integer = 418ms
* Integer = 411ms
- Integer = 416ms
/ Integer = 468ms
+ Float = 429ms
* Float = 426ms
- Float = 424ms
/ Float = 431ms
Posted: 02:57pm 13 Jul 2019
  Quote  But the difference seems very small.
That is because most of the time is taken in parsing the commands. Just the reality of a Basic Interpreter I'm afraid.
Note the comparatively slow integer divide. This is because the FPU supports double floating division but there is no H/W support for 64-bit integer divideEdited by matherp 2019-07-15
twofingers
Posted: 03:25pm 13 Jul 2019
But there is something else weird:
If I exchange positions of the Dim's
Dim integer i,a
Dim float j,b
to
Dim float j,b
Dim integer i,a
then the integers are slower than floats again:
+ Integer = 429ms
* Integer = 422ms
- Integer = 426ms
/ Integer = 480ms
+ Float = 418ms
* Float = 416ms
- Float = 414ms
/ Float = 420ms
Posted: 03:51pm 13 Jul 2019
  Quote  then the integers are slower than floats again:
Yes, but this is again due to parsing. The integer variables are now after the float ones in the variable table so the parser takes longer to find them.
The variable table is just a sequential list in the order created and the parser searches from the top until it finds a match to the variable name.
To accurately see the difference between float and integers you need to do it both ways and average the results.
twofingers
Posted: 04:24pm 13 Jul 2019
  matherp said   ... To accurately see the difference between float and integers you need to do it both ways and average the results.
Okay!
Dim integer i,a
Dim float j,b
Timer=0
Timer=0
End
Result:
Integer = 1712ms
Float = 1709ms
vs
Integer = 1756ms
Float = 1664ms
ie
sum for integers = 1712+1756=3465ms
sum for floats = 1709+1664=3372ms
On an ArmMite H7!
Posted: 06:00pm 13 Jul 2019
Remove the divide and you will see integer slightly faster. Floating point divide is supported by hardware. 64 bit integer divide isn't.
However, speed isn't really the issue. The key point is that integer arithmetic is exact whereas, even with double precision you will see rounding errors with FP
Dim float i,a
For i=1 To 10000*7
a=a+1/7
Next i
Print Str$(a,5,15)
End
=9999.999999991743607
twofingers
Posted: 06:42pm 13 Jul 2019
Hi Peter!
  Quote  Remove the divide and you will see integer slightly faster. Floating point divide is supported by hardware. 64 bit integer divide isn't.
I totally agree!
I was just trying to say - and prove - something against the myth that (MMBasic) integers are in any case significant faster. I think that is important for us users.
