Forum Index : Microcontroller and PC projects : find and replace window disappearing on MMEDIT
| jeffj Regular Member Joined: 04/02/2012 Location: AustraliaPosts: 84 |
The little window that normally appears on the screen when "find/replace " is pressed flashes and then disappears but is in the corner when MMEDIT is minimised, clicking on it makes no difference. I am using win 10 I don't think this is am MMEdIT problem as I have reloaded the software and switched the computer on and off. It works ok on notepad and word programmes Any help would be appreciated Jeff |
Plse cancel my post It fixed itself jeff |
My apologies for not responding to the initial post. In cases like that, I usually recommend deleting the data folder contents while re-installing. That refreshes things like window position which can cause problems if they get corrupted. Glad it's working again for you. Jim VK7JH MMedit |
