Local Time 18:14 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Old hang-over from Maximite?
CaptainBoing
Posted: 08:45pm 27 Sep 2019
I have a console based application that needs a bit more than simple line based output, so tonight I was just writing some screen control code that allows me to position the cursor etc just as you would on an old 80s micro using VT100 ANSI escape codes.
Strange thing is, CLS seems to be a reserved word but MMBasic doesn't complain about it. It allows me to define a SUB called CLS but it never works and with nothing in memory, typing CLS doesn't invoke an error. If I define a sub for another reserved word (in this case FOR) I do get moaned at.
See below
> ?mm.ver
5.0408
> new
> AUTOSAVE
For n=1 To 25
 Print At(n,n);str$(n)
Next
Function At(v As Integer,h As Integer) As String
 At=Chr$(27)+"["+Str$(v)+";"+Str$(h)+"H"
End Function
Sub Cls
Print Chr$(27)+"[2J";
End Sub
Sub For
End Sub
Saved 218 bytes
> RUN
[14] Sub For
Error: Invalid identifier
> cls
odd.
Edited 2019-09-28 06:47 by CaptainBoing
Posted: 09:54pm 27 Sep 2019
Do you have any display defined in OPTIONs?
I expect that if you did, MMBasic would complain.
CaptainBoing
Posted: 12:04pm 28 Sep 2019
genius!
Well done Jim. I hadn't used this mite for a while and it completely went out of my head that I had it driving a panel before.
