Forum Index : Microcontroller and PC projects : PICAXE chips for sale....
Hello all. ![]() As I have pretty much standardised all my stuff now on the Micromite, I have a collection of PICAXE chips I no longer want or need. 08M2 x 10 in DIL 08M2 x 11 in SOIC 14M2 x 27 in DIL 14M2 x 04 in SOIC 18M2+ x 32 in DIL (six of which have been recycled and 'Cleared') 18M2+ x 14 in SOIC 20X2 x 05 in DIL 28X2 x 02 in DIL 04MHz 3-leg resonator x 08 08MHz 3-leg resonator x 04 16MHz 3-leg resonator x 05 08M2 and 14M2 chips US $1 each. 18M2 chips US $2 each. 20X2 chips US $3 each. 28X2 chips US $4 each. Resonators US fifty cents each. If anyone is interested in some or all of these, please send me a PM. First in, first served. Smoke makes things work. When the smoke gets out, it stops! |
Quazee137![]() Guru Joined: 07/08/2016 Location: United StatesPosts: 603 |
I'll get 10 of 08M2's and 5 0f 14M2's This is GREAT as I was going to order a few to play with. Thanks |
OK, done. ![]() I have PM'd you. The 08M2's and 14M2's are brand new, and never used. EDIT: Can I assume you want the DIL ones? Edited 2019-10-17 16:26 by Grogster Smoke makes things work. When the smoke gets out, it stops! |
what is an 18M2+ ?? Volhout Edit: already found it. My 18M2's are actually also 18M2+'es Edited 2019-10-17 17:02 by Volhout PicomiteVGA PETSCII ROBOTS |
| Solar Mike Guru Joined: 08/02/2015 Location: New ZealandPosts: 1213 |
Hi Grogster I will get 5 x 20X2 and the 2 x 28X2. Plus 5 x 08M2 SOIC. Cheers Mike |
Forget to add 16MHz 3-leg resonator x 05 Thanks Mike |
I have to resist the urge to buy some of these just to have them. I know that they will sit around unused... Micromites and Maximites! - Beginning Maximite |
@ CG: Yeah, I bought up heaps of these PICAXE chips when I was using them for all my projects, but as the years went merrily by, I found myself porting all designs and code across to the Micromite as it got better and better. This is why I now how have all these to spare, as I simply don't use them. ![]() The current availability is now: 08M2 x 11 in SOIC 14M2 x 22 in DIL 14M2 x 04 in SOIC 18M2+ x 32 in DIL (six of which have been recycled and 'Cleared') 18M2+ x 14 in SOIC 04MHz 3-leg resonator x 08 08MHz 3-leg resonator x 04 Smoke makes things work. When the smoke gets out, it stops! |
