Local Time 18:14 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM: How can you capture text Printed from BASIC
Posted: 05:34pm 22 Oct 2019
Hi there,
Is there a mechanism to capture text output by the Print command in a file?
Posted: 06:03pm 22 Oct 2019
I've decided my initial post was too terse.
The background is that I am writing a Z-machine interpreter for the CMM, or at least attempting to. I think it is a race as to what will kill the project: poor performance or insufficient memory.
I need to share debugging output with a domain expert who doesn't have access to a CMM, hence the need to capture the output in a file.
Posted: 06:07pm 22 Oct 2019
I assume it's the same as the MM+, with an SD card?
You can OPEN filename$ FOR OUTPUT AS [filenumber]
then you can
PRINT #[filenumber], whatever you want to print (don't forget the comma)
CLOSE [filenumber]
That will write the text or whatever to the file. I don't know of any way to use the normal PRINT statement to do that. Perhaps someone else does?
Posted: 06:22pm 22 Oct 2019
Thanks, but what I'm really hoping to do is capture/redirect the output from the normal Print command.
Otherwise I'll need to write a wrapper subroutine around Print.
Posted: 06:25pm 22 Oct 2019
If you are connected to a computer just use the log function in teraterm
Posted: 06:34pm 22 Oct 2019
  matherp said  If you are connected to a computer just use the log function in teraterm
Right, I was just browsing the manual and discovering the same whilst you were replying. For masochistic reasons (and so it seems less like my day job) I have been trying to avoid using my 21st century computer on this project, but possibly this is a case of "needs must".
Thanks.
