Forum Index : Microcontroller and PC projects : Help with MMBackPack V3 Diodes
| Andrew_G Guru Joined: 18/10/2016 Location: AustraliaPosts: 883 |
Hi, I am assembling my new MMBackPack V3 from Silicon Chip. In the SC article/circuit diagram/parts list they list: Q1 as a 2N7002 N-channel Mosfet, and Q2 as a IRML2244TRPBF P-channel Mosfet (both SOT-23 packages) What the have supplied (both SOT-23) as listed on their packing slip is: - a 2N7002P, it has "LWW 58" marked on it (I assume this is a P channel and not an N), and - a DMP2215L-7, it has "22P-D8" marked on it. Are they equivalents and which one is which? (I would normally ask SC but it is a long weekend in Melbourne - some horse race on Tuesday) Many thanks, Andrew |
The 2N7002P has a rating of 360mA while the 2N7002 is 300 mA so no problems there. I can't find a datasheet for the IRML2244 and don't have the SC circuit but the DMP2215L-7 is a P-channel device so I assume is a suitable substitute, Jim VK7JH MMedit |
| PeterB Guru Joined: 05/02/2015 Location: AustraliaPosts: 669 |
G'Day Andrew using google gives 2N7002N is N chan 2N7002P is N chan IRML2244 etc is P chan DMP2215L-7 is P chan Somebody will come back and say "no, the other way round" Peter |
Thanks Peter and Jim, If I understand it correctly, I am OK to use: - the 2N7002P instead of the 2N7002N as Q1 - because they are BOTH N channel - the DMP2215L-7 as Q2 - because it is a P channel What would happen if it is the other way round - smoke or just not working? Thanks, Andrew |
It would depend on the circuit about which I know nothing. Give it a try. The shops will be open again on Wednesday. Only joking Peter |
both N channel AND all other specs are more or less equivalent. The 2N7002P is an upgrade. I can't compare spec for the other pair because I don't have a datasheet or the circuit. I made a hopefully intelligent guess that all will be well. VK7JH MMedit |
Thanks Jim and Peter, Fingers crossed - I'm trying it out now - no smoke yet. But I haven't connected the LCD yet. I can't get a ">" prompt back from a known programmed MM yet, LED flashes. (Of course I'm using MMEdit . . .) I'll keep looking for faults. Cheers, Andrew |
I guess a 28 pin MM socket does better with more than 2 pins soldered . . . Andrew |
Thanks Jim and Peter (et al), All good with no smoke! The 3.5" is a beautiful display, well supported by Peter Mather's driver and documentation. With all the right connections made (eventually) it worked "almost out of the box". (and the PWM brightness control works a treat) Cheers, Andrew |
| erbp Senior Member Joined: 03/05/2016 Location: AustraliaPosts: 195 |
Hi, The SC Micromite Backpack V2 (May 2017) used 2N7002 and DMP2215L-7 Mosfets for the backlight controller and I can confirm that they work in that version of the backpack. I don't have the circuit for the V3 backpack, but I would be surprised if the backlight circuitry changed significantly, so presumably the IRML2244 is compatible with the DMP2215L-7. Cheers, Phil. |
Just for reference, Digi-Key have the IRLML2244TRPbF and there's a link to the data sheet on their page: https://www.digikey.com/product-detail/en/infineon-technologies/IRLML2244TRPBF/IRLML2244TRPBFCT-ND/2639575 The DMP2215L-7 is listed as obsolete, so it's no surprise that they've substituted something else. :) Mick Zilog Inside! nascom.info for Nascom & Gemini Preliminary MMBasic docs & my PCB designs |
