Local Time 18:11 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM: Text cursor control
Posted: 11:49am 23 Dec 2019
Hi folks,
Two questions regarding text cursor control in MMBasic 4.5 on the CMM:
1) Is there any way of getting the current text cursor position?
2) Is there a control code to move the text cursor to the beginning of the current line?
Posted: 12:16pm 23 Dec 2019
1) MM.HPOS and MM.VPOS will give you the position in pixels.  POS will give you the current cursor position in the line in characters but I cannot think of anything that would return the line.
2) The carriage return character.  ie, PRINT CHR$(13);
Posted: 12:54pm 23 Dec 2019
Thanks Geoff,
1) I had missed POS when I read the manual :-( I didn't need the line, and as it turned out I worked out a way of not needing the column either.
2) Right, I had tried CHR$(13) and it "didn't work" - seemed to do a newline instead, but I must have done something else wrong because when I tried it again it did <shrugs shoulders/>
Thanks again.
