Forum Index : Microcontroller and PC projects : CMM2 Manual Errata
Page 3 of 6 | |||||
Thanks again. I have updated the downloadable manuals. Geoff Geoff Graham - http://geoffg.net |
robert.rozee Guru Joined: 31/12/2012 Location: New ZealandPosts: 2286 |
following on from a discussion in the "CMM2: Bug reports" thread... page 62 of the CMM2 manual explains single line if-then-else thus: [single paragraph split into three numbered sentences by me] this explanation is the same as in the micromite mk2 manual, and presumably all others. the first sentence should be edited to read "Evaluates the expression ‘expr' and performs the list of statements following the THEN keyword if it is true, or skips to the next line if false". the second sentence then becomes redundant and can be removed. the portion of the third sentence reading "...statement(s) following it will be executed if 'expr' resolved to be false" is incorrect for the case of multiple statements following the ELSE, as demonstrated by this example: For i=0 To 1 Print "example " i+5 If i Then Print ,, "jam on "; Else Print ,, "french ";: Print "toast" Next i > RUN example 5 french toast example 6 jam on toast > the third sentence should be replaced with something along the lines of, "The ELSE keyword is optional, but if used only ONE statement can be present between THEN and ELSE, and if 'expr' evaluates to true then only the FIRST statement following ELSE will be skipped - further statements on the line will ALWAYS be executed, no matter what 'expr' resolved to". (i think i've got the wording right!) cheers, rob :-) Edited 2020-06-12 01:53 by robert.rozee |
Could the user manual be fiddled with a bit so that the section describing the External I/O Connector is all on one page? Currently, it is spread across pages 8 and 9 which makes printing just that part slightly less convenient than it could be. Visit Vegipete's *Mite Library for cool programs. |
matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 8578 |
Looks like a cut-and-paste from the wrong source. Should be an identical entry to the MM2 |
it IS identical to the entry in the MM2 manual, which is itself also wrong. cheers, rob :-) Edited 2020-06-12 03:38 by robert.rozee |
That's interesting: I was looking at the manual for 5.4 and in that it is single statement. Just checked the release notes for the MM2 and can't see any reason for the change in documentation - definitely one for Geoff |
The STR$ function doesn't appear in the bookmark list. It should be between SQR and STRING$ ("String string" made me chuckle...) Visit Vegipete's *Mite Library for cool programs. |
Be careful when closing the Nunchuk: You don't want to lose your Nunchuk! Visit Vegipete's *Mite Library for cool programs. |
KeepIS Guru Joined: 13/10/2014 Location: AustraliaPosts: 1356 |
Geoff Hi Geoff, I just downloaded the Zip from MMBasic Zip and although the manuals are different in size, some of the errors mentioned are still in the manuals. Like the last two at the bottom of the previous page. I also cleared my Cache just in case. . . Edited 2020-06-12 15:35 by KeepIS It's all too hard. Mike. |
Chopperp Guru Joined: 03/01/2018 Location: AustraliaPosts: 1032 |
Under TIMING P14 OPTION CLOCKTRIM should be OPTION RTC CALIBRATE ±n Thanks TJ Brian ChopperP |
Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 3519 |
Hi Geoff, The audio outputs range from 0V to 3.3V. That is 3.3V peak to peak. In the manual is stated that that equals 1.95Vrms, should be 1.15Vrms. Just a small technical typo... PicomiteVGA PETSCII ROBOTS |
The following statement appears a number of times in the Commands of the User manual, but be buggered if I can find the actual chapter. ......Refer to the chapter "Using the I/O pins" for a general description of the Maximite's input/output capabilities..... There is a chapter on External Input/output in the Introduction to Programming Manual. Brian ChopperP |
In the description for the circle command, the line "It can be omitted or set to -1 in which case the box will not be filled." appears. This should refer to 'circle' instead. Visit Vegipete's *Mite Library for cool programs. |
Page 48 Programming with the CMM2. The colours that you can specify this way are red, green, blue, yellow, cyan, purple, brown, gray, white and black. purple should be magenta. As TassyJim noted in the CMM2 bug thread, purple is a throw over from the CMM1 and has been replaced by magenta, using purple will give an error. It's all too hard. Mike. |
Thanks guys. All the above changes have found their way into the manuals. My Colour Maximite 2 web pages are now live and you can download the latest version of the manuals and firmware from there: http://geoffg.net/maximite.html Geoff Geoff Graham - http://geoffg.net |
From OPERATORS NOT INV NOIT will invert the logical value on the right. Should NOIT be NOT? Edit Under Special Device Support, circuit drawings refer to the Micromite. May confuse new users Brian Edited 2020-06-25 10:47 by Chopperp ChopperP |
page 36: Micromite should be Maximite. Bill Keep safe. Live long and prosper. |
Andrew_G Guru Joined: 18/10/2016 Location: AustraliaPosts: 840 |
Hello all, Do my aged eyes deceive me or does FONT 7 CHR$(123) represent a DegC symbol? Possibly worth stating this in the manual, say on page 29? Cheers, Andrew (PS: beaut fonts!) |
Andrew, I'm not sure what version of the manual you are looking at but on page 28 of the latest manual I have just under the table listing the fonts it says: hex or 96 decimal) has been replaced with the degree symbol (º). Bill Keep safe. Live long and prosper. |
Thanks Bill, I was looking at 5.05.02 but the page number was not the point I was trying to make. Load up Font No7, CHR$(123) and tell me what you see. (but in the other fonts the deg symbol is CHR$(96)) If you look at this you will see how I spotted it. Cheers, Andrew Edited 2020-06-29 16:56 by Andrew_G |
Page 3 of 6 |
