Forum Index : Microcontroller and PC projects : CMM2 demo programs
TassyJim![]() Guru Joined: 07/08/2011 Location: AustraliaPosts: 6543 |
This is one I converted a while ago. Comparing speeds with my PC, computing Pi to 500 places, on the PC Total computation time: 94 mS Time to format and print: 31 mS at 14:30:49 on the CMM2 Total computation time: 611 mS Time to format and print: 17 mS at 14:30:27 slower to think but faster to talk... ' ported by TassyJim from a post on PureBasic forum by Jeff88 ' his comments follow ' ';Many years ago when I used Quickbasic, I came across a program to calc pi. Of course this has no practical ';purpose, but just to fight winter boredom I modified the program (see comments included below) to run ';under Purebasic, now can use 10 digits per word instead of 4. Also added a bit of assembly to avoid calculating ';the remainder, this only makes a slight difference since most of time is taken by dividing. ';Using threads sped up by a factor of 3. Note calc atan(1/5) takes about twice as long as atan(1/239). ';Programmed by Jeff Wyatt, Highlands Ranch, Colorado (1/2019). ' ';On my Athelon II X4 635 the program can calculate 100,000 digits in about 8 secs with debugging off. ' '; >>>>>>>>>>>>>>>>>>>>>>>COMPILE With THREAD SAFE BOX CHECKED<<<<<<<<<<<<<<<<<<<<<<<<<<<< ' ';Based upon Machin's (1706) formula: pi/4=arctan(1)=4*arctan(1/5)-arctan(1/239), he did 100 digits by hand ';which would take about 8 usec with this program. Time is prop. to digits^2 so need to use another method ';for very large number of digits. Good way to test your computer's integer arithmatic. ';See https://www.angio.net/pi/ for further info and searchable listing of pi. ';I used it to check that my program worked correctly for the first 2,000,000 digits. ' ';Previous comments from authors 20 years ago ' ';Program To calculate pi, version 4.8 ';A major rewrite of version 4.2, this uses only two arrays instead of ';three, and includes a host of speedups based on a similar C program. ';A sampler: all the carries are reserved until the end, the divide and ';add routines are combined, two terms are added at a time, and the number ';of function calls is minimized. It's a big change for a small gain, since ';the compiled version requires 28.6 seconds for 5000 digits on my 486 66 MHz ';computer, a 10 gain over version 4.2; like before, it's capable of about ';150,000 digits of pi. '; ';This program has come a long way from version 1.0; thanks are due to ';Larry Shultis, Randall Williams, Bob Farrington and Adrian Umpleby. ';One final note for speed freaks: this program will run about 6 times faster ';if written in C using an optimizing compiler. Likewise, if you can figure ';out a way to do integer division and use both the quotient and remainder, ';this program can easily be sped up by 25. -jasonp@isr.umd.edu OPTION EXPLICIT DIM INTEGER words, big, Digits, DigitsperWord, x, i, quotient DIM INTEGER ctime, stime DigitsperWord=10 big=1 FOR i=1 TO DigitsperWord '1 followed by 10 zeros, note if you use 14 digits/word big=big*10 'arctan(1/5) will overflow about digit 64,760 NEXT 'when 1.4*digits*big~denom*big >9e18 INPUT "how many digits? ",Digits words = Digits / DigitsperWord+2 DIM INTEGER sum(words + 2),sum1(words+2),sum2(words+2) stime = TIMER print "Started at "+time$ '--------------- -4*atan(1/239) x = atan239() '------------ 16*atan(1/5) PRINT STR$(TIMER - stime)+"mS so far" x = atan51() PRINT STR$(TIMER - stime)+"mS so far" x = atan52() PRINT STR$(TIMER - stime)+"mS so far" sum1(2)=sum1(2)-big/5 FOR x=2 TO words sum(x)=sum(x)+sum1(x)+sum2(x) NEXT FOR x = words TO 2 STEP -1 'finish up IF sum(x) < 0 THEN 'release borrows quotient = sum(x) \ big sum(x) = sum(x) - (quotient - 1) * big sum(x - 1) = sum(x - 1) + quotient - 1 ENDIF IF sum(x) >= big THEN 'and carries quotient = sum(x) \ big sum(x) = sum(x) - quotient * big sum(x - 1) = sum(x - 1) + quotient ENDIF NEXT ctime = TIMER - stime x = PrintOut() END FUNCTION atan239() 'arctan(x) = x-x^3/3+x^5/5-x^7 .... LOCAL INTEGER mainder, mainder1, mainder2, dividend, denom, temp, firstword, x LOCAL INTEGER term(words +2), lastword mainder=4 FOR x = 2 TO words dividend = mainder * big 'crunch out 1st term term(x) = dividend \ 239 mainder = dividend - term(x) * 239 sum2(x) = sum2(x) - term(x) 'subtract as we want -atan(1/239) NEXT x denom=3:firstword=2 DO 'do two more terms, add first, subtract second mainder1=0 mainder2=0 FOR x = firstword TO words temp = term(x) dividend = mainder1 * big + temp temp = dividend \ 57121 mainder1 = dividend - temp * 57121 term(x) = temp dividend = mainder2 * big + temp temp = dividend \ denom mainder2 = dividend - temp * denom sum2(x) = sum2(x) + temp NEXT IF term(firstword) = 0 THEN firstword = firstword + 1 ENDIF denom = denom + 2 mainder1 = 0: mainder2 = 0 FOR x = firstword TO words temp = term(x) dividend = mainder1 * big + temp temp = dividend \ 57121 mainder1 = dividend - temp * 57121 term(x) = temp dividend = mainder2 * big + temp temp = dividend \ denom mainder2 = dividend - temp * denom sum2(x) = sum2(x) - temp NEXT x IF term(firstword) = 0 THEN firstword = firstword + 1 ENDIF denom = denom + 2 LOOP UNTIL firstword >=words END FUNCTION '------------------------------------------------------------------- FUNCTION atan51() ' atan(1/5) one half of calc terms 1/5, 1/9, 1/13 ...... LOCAL INTEGER mainder, mainder1, mainder2, dividend, denom, temp, firstword, x LOCAL INTEGER term(words +2), lastword denom = 5: firstword = 1: lastword =3 sum(1) = 3: term(1) = 3: sum(2) = big/5: term(2) = sum(2) DO mainder1=0 mainder2=0 FOR x = firstword TO lastword + 1 temp = term(x) dividend = mainder1 * big + temp temp = dividend \ 625 ' 625 = 5^4 mainder1 = dividend - temp * 625 term(x) = temp dividend = mainder2 * big + temp temp = dividend \ denom mainder2 = dividend - temp * denom sum(x) = sum(x) + temp NEXT FOR x = lastword + 2 TO words dividend = mainder2 * big temp = dividend \ denom mainder2 = dividend - temp * denom sum(x) = sum(x) + temp NEXT IF term(lastword + 1) > 0 AND lastword < words THEN lastword = lastword + 1 ENDIF IF term(firstword) = 0 THEN firstword = firstword + 1 ENDIF denom = denom + 4 LOOP UNTIL firstword >= words END FUNCTION FUNCTION atan52() ' atan(1/5) other half of calc terms 1/3, 1/7, 1/11 .... LOCAL INTEGER mainder, mainder1, mainder2, dividend, denom, temp, firstword, x LOCAL INTEGER term(words +2), lastword denom = 3: firstword = 1: lastword =3 sum1(1) = 3: term(1) = 3: sum1(2) = big/5: term(2) = sum1(2) print "starting atan52()" 'DEBUG mainder1=0 mainder2=0 FOR x = firstword TO lastword + 1 'term 1/3 temp = term(x) dividend = mainder1 * big + temp temp = dividend \ 25 mainder1 = dividend - temp * 25 term(x) = temp dividend = mainder2 * big + temp temp = dividend \ denom mainder2 = dividend - temp * denom sum1(x) = sum1(x) - temp NEXT print "atan52() step 2" 'DEBUG FOR x = lastword + 2 TO words dividend = mainder2 * big temp = dividend \ denom mainder2 = dividend - temp * denom sum1(x) = sum1(x) - temp NEXT IF term(lastword + 1) > 0 AND lastword < words THEN lastword = lastword + 1 ENDIF IF term(firstword) = 0 THEN firstword = firstword + 1 ENDIF denom = denom + 4 print "atan52() step 3" 'DEBUG DO 'do the rest if firstword mod 100 = 0 then print firstword 'DEBUG mainder1 = 0: mainder2 = 0 FOR x = firstword TO lastword + 1 temp = term(x) dividend = mainder1 * big + temp temp = dividend \ 625 mainder1 = dividend - temp * 625 term(x) = temp dividend = mainder2 * big + temp 'eventually this will overflow >9e18 temp = dividend \ denom mainder2 = dividend - temp * denom sum1(x) = sum1(x) - temp NEXT x FOR x = lastword + 2 TO words dividend = mainder2 * big temp = dividend \ denom mainder2 = dividend - temp * denom sum1(x) = sum1(x) -temp NEXT x IF term(lastword + 1) > 0 AND lastword < words THEN lastword = lastword + 1 ENDIF IF term(firstword) = 0 THEN firstword = firstword + 1 ENDIF denom = denom + 4 LOOP UNTIL firstword >= words END FUNCTION FUNCTION PrintOut() LOCAL p$, i AS INTEGER, j AS INTEGER, ptime AS INTEGER PRINT "" p$="pi = 3." i=2 DO FOR j=i TO i+4 IF j>words THEN p$=p$+SPACE$(11) ELSE p$=p$+STR$(sum(j),10,0,"0")+" " ENDIF NEXT p$=p$+STR$(10*i+30,7) PRINT p$ p$=" " i=i+5 LOOP UNTIL i>=words ptime = TIMER - stime - ctime PRINT "" PRINT " Total computation time: "+STR$(ctime)+" mS" PRINT " Time to format and print: "+STR$(ptime)+" mS at "+time$ END FUNCTION Jim VK7JH MMedit |
goc30![]() Guru Joined: 12/04/2017 Location: FrancePosts: 435 |
hi all YESSS my CMM2 is working. i have upgraded my graphical tests for CMM2 test all graphics functions testgraf.zip test fonts test_fonts_cmm2.zip Edited 2020-07-31 12:06 by goc30 |
| capsikin Guru Joined: 30/06/2020 Location: AustraliaPosts: 342 |
And you did. I think I found the demo code here: https://github.com/mauroxavierneto/psgmini_cmm2 (psgdemo.bas is the file to run) It was great! |
| MauroXavier Guru Joined: 06/03/2016 Location: BrazilPosts: 307 |
Thanks for your comment, capsikin. My GitHub repository doesn´t have half of my source codes because I need to fix some of them to not cause rage in the users because there are a LOT OF BUGS ![]() I have a bad habit to make a lot of experiences thinking about my satisfaction, as programming on CMM2 is a hobby. With a growing community, I must think about a better code indentation, comments and running with a minimum bug count, then now I guess it's better to fix my sources to a bare minimum quality before hosting them. |
I could only find Manic Miner for the old CMM, I don't think it's been ported to the CMM2. Version I found: https://www.thebackshed.com/forum/ViewTopic.php?TID=11691&PID=140143#140143 I also liked Jet Pac, and Joust (which reminded me of it because of gravity, flying, platforms, and single screen levels) |
I have updated the display test card program to cater for the ever increasing number of diplay modes. I have changed things to make it easier to navigate (I hope) UP/DOWN arrows to change display resolution LEFT/RIGHT arrows to change colour depth +- keys to change circle aspect ratio P to save a BMP image of the screen. Q to quit ' test card for CMM2 ' TassyJim August 2020 OPTION EXPLICIT OPTION DEFAULT NONE DIM INTEGER wd, ht, wbox, sh, x, w, n, nn, m, cd, maxMode, keepMode DIM FLOAT a, defaultMode DIM k$, imgtitle$, fname$, imgRes$ DIM INTEGER c(8) c(0) = RGB(BLACK) c(1) = RGB(YELLOW) c(2) = RGB(CYAN) c(3) = RGB(GREEN) c(4) = RGB(MAGENTA) c(5) = RGB(RED) c(6) = RGB(BLUE) c(7) = RGB(WHITE) c(8) = RGB(64,64,64) maxMode = 9 cd = 8 a = 1 defaultMode = MM.INFO(MODE) CLS DO IF m = 0 THEN MODE 1,8 CLS TEXT 400,100, "Video mode test",cm,5,1 TEXT 400,180, "Ratio = aspect ratio used in the circle command",cm,1,1 TEXT 400,220, "Q to quit, P to save page as a BMP",cm,3,1 TEXT 400,260, "Up Down arrow to change resolution",cm,3,1 TEXT 400,300, "Left Right arrow to change colour depth",cm,3,1 TEXT 400,340, "+ - to change circle aspect ratio",cm,3,1 ELSE IF keepmode THEN ' only change resolution if needed keepmode = 0 ELSE MODE m,cd ENDIF wd = MM.HRES : ht = MM.VRES nn = INT(wd/80) imgtitle$ =" MODE "+STR$(MM.INFO(MODE))+" Ratio "+STR$(a,1,3)+" " imgRes$ = " "+STR$(MM.HRES)+" x "+STR$(MM.VRES)+" " wbox = wd / 8 PAGE WRITE 1 ' no flicker during write CLS ' primary colours FOR x = 0 TO 7 BOX x*wbox,ht/4,wbox,ht/2,0,c(x), c(x) NEXT x ' full gradient for each primary colour and greyscale FOR x = 0 TO wd-1 sh = 255*x/wd LINE x,0,x,ht/12,1,RGB(sh,0,0) LINE x,ht/12,x,ht/6,1,RGB(0,sh,0) LINE x,ht/6,x,ht/4,1,RGB(0,0,sh) LINE x,ht*9/12,x,ht*10/12,1,RGB(0,sh,sh) LINE x,ht*10/12,x,ht*11/12,1,RGB(sh,0,sh) LINE x,ht*11/12,x,ht,1,RGB(sh,sh,0) LINE x,ht/2,x,ht*3/4,1,RGB(sh,sh,sh) ' greyscale NEXT x ' circle to check aspect ratio CIRCLE wd/2,ht/2, ht*15/32,3,a,c(7) sh = 0 x = wd/2 - 55*nn/2 ' black white bars to check monitor bandwidth FOR w = 10 TO 1 STEP -1 FOR n = 1 TO nn sh = 255 - sh LINE x,ht*3/8,x,ht*5/8,w,RGB(sh,sh,sh) x = x + w NEXT n NEXT w ' white and red border to check that image fits on monitor BOX 0,0,wd,ht,3,c(7) BOX 1,1,wd-2,ht-2,1,c(5) ' title IF wd > 600 THEN TEXT wd/2,ht/2, imgtitle$,cm,4,1 TEXT wd/2,ht/2+25, imgRes$,cm,4,1 ELSE TEXT wd/2,ht/2, imgtitle$,cm,1,1 TEXT wd/2,ht/2+25, imgRes$,cm,1,1 ENDIF ' show the new image PAGE COPY 1 TO 0 ,B ENDIF ' wait for keypress DO k$ = INKEY$ LOOP UNTIL k$<>"" ' SELECT CASE k$ CASE "Q","q" EXIT DO CASE "P","p" fname$ = MID$(imgtitle$,2)+".bmp" TIMER = 0 SAVE IMAGE fname$ PAGE WRITE 0 TEXT wd/2,ht/2,"Saved as "+fname$+" in "+STR$(TIMER/1000,3,2)+" Sec" ,cm,1,1 DO k$ = INKEY$ LOOP UNTIL k$<>"" CASE CHR$(128) ' up arrow m = m - 1 IF m < 1 THEN m = maxMode CASE CHR$(129) ' down arrow m = m + 1 IF m > maxMode THEN m = 1 CASE CHR$(131) ' right arrow res up cd = cd + 4 IF cd > 16 THEN cd = 8 IF m = 9 AND cd = 12 THEN cd = 16 ' skip 12 bit for mode 9 CASE CHR$(130) ' left arrow res down cd = cd - 4 IF cd < 8 THEN cd = 16 IF m = 9 AND cd = 12 THEN cd = 8 ' skip 12 bit for mode 9 CASE "+" ' ratio plus IF a < 1.4 THEN a = a + 0.01 keepmode = 1 CASE "-" ' ratio minus IF a > 0.75 THEN a = a - 0.01 keepmode = 1 CASE ELSE ' same as down arrow m = m + 1 IF m > maxMode THEN m = 1 END SELECT LOOP setmode defaultMode ' restore original mode before ending program PAGE WRITE 0 CLS END SUB setmode dotMode AS FLOAT LOCAL INTEGER mm, md ' use float returned by mm.info(mode) to set MODE mm = INT(dotmode) md = (dotmode - mm)*100 IF md > 20 THEN md = md/10 MODE mm, md END SUB Jim VK7JH MMedit |
| thwill Guru Joined: 16/09/2019 Location: United KingdomPosts: 4370 |
Jim, Do you think (or want) your test card program to be included on the "Welcome Tape" ? Best wishes, Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
| Sasquatch Guru Joined: 08/05/2020 Location: United StatesPosts: 385 |
Let me do some work on the Mandelbrot, I plan to make it interactive so you can pan and zoom using the Keyboard or Nunchuk. What about VegiPete's excellent Falfus2 puzzle game? https://www.thebackshed.com/forum/ViewTopic.php?TID=12248&PID=148788#148788 -Carl |
Do you think (or want) your test card program to be included on the "Welcome Tape" ? Best wishes, Tom OK by me. But change the maxModes to 10 first. Jim VK7JH MMedit |
| HellbentHorse Regular Member Joined: 08/07/2020 Location: AustraliaPosts: 55 |
I am super new to the world of BASIC but had fun doing this on DOS MMBasic whilst I finish my CMM2 kit :10 PRINT CHR$(47+(INT(RND()*2)*45)); : GOTO 10 Hopefully one day I shall be at the same level as you MMBasic wizards. Edited 2020-09-06 06:43 by HellbentHorse |
| mclout999 Guru Joined: 05/07/2020 Location: United StatesPosts: 510 |
:10 PRINT CHR$(47+(INT(RND()*2)*45)); : GOTO 10 Hopefully one day I shall be at the same level as you MMBasic wizards. This is an adaptation of the 8bit Guys favorite 1 line programs of the C64, Nice. I want to know if there are any fonts that have the \/ characters that go the whole-cell top to bottom like the C64's dose so there are not breaks in the sudo maze? If not maybe I can make a custom font and load it. I tried all the built in fonts on each of the 10 screens resolutions. Screen 1 and font 1 work the best so that is good but still a gape at every intersection. They call me Shai-Hulud (The maker) |
| vegipete Guru Joined: 29/01/2013 Location: CanadaPosts: 1182 |
Try this: font 8 do : print CHR$(48+(INT(RND*2))); : pause 25 : loop DefineFont #8 03301010 02000100 08000400 20001000 80004000 00020001 00080004 00200010 00800040 00400080 00100020 00040008 00010002 40008000 10002000 04000800 01000200 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 End DefineFont It's not a one liner anymore but it performs as required. Adjust the pause as required. Without it, it's way too fast. Visit Vegipete's *Mite Library for cool programs. |
This is an adaptation of the 8bit Guys favorite 1 line programs of the C64, Nice. I want to know if there are any fonts that have the \/ characters that go the whole-cell top to bottom like the C64's dose so there are not breaks in the sudo maze? If not maybe I can make a custom font and load it. I tried all the built in fonts on each of the 10 screens resolutions. Screen 1 and font 1 work the best so that is good but still a gape at every intersection. This was my only bug bear only using MMBasic on DOS at present, no support for custom fonts but it was on my to do list to revisit once I get to programming on my actual CMM2. Shouldn't be long now, just need to finish putting in the resistors and doing a final joints check. |
The standard fonts deliberately have blank rows to have somewhere for the underline to go and make them readable. If you want 'full' fonts, you will have to roll your own. Jim VK7JH MMedit |
The standard fonts deliberately have blank rows to have somewhere for the underline to go and make them readable. If you want 'full' fonts, you will have to roll your own. Jim Good info, thanks. That does make sense. Now I get to figure out how to do custom fonts. Would it be kosher to just copy, say font 1 and edit the two characters I want? If that is not cool then can you just make a 2 character font? I think I saw a program that had just a few characters in the define area. EDIT: I did not see the response above. People here are so fast to help and that is why this has been one of the best projects I have ever seen. That and the amazing work by the developers that are shockingly fast at implementing tweaks and imaginative improvements. Thanks all. Edited 2020-09-07 13:48 by mclout999 They call me Shai-Hulud (The maker) |
font 8 do : print CHR$(48+(INT(RND*2))); : pause 25 : loop DefineFont #8 03301010 02000100 08000400 20001000 80004000 00020001 00080004 00200010 00800040 00400080 00100020 00040008 00010002 40008000 10002000 04000800 01000200 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 End DefineFont It's not a one liner anymore but it performs as required. Adjust the pause as required. Without it, it's way too fast. Nice, here I was thinking I would have to learn how to do this and Now I know how. Awsome. Thanks. I do still need to figure out how defineFont works but now I have an example. I tried it and it works in all modes. Very nice. Edited 2020-09-07 14:27 by mclout999 They call me Shai-Hulud (The maker) |
Updated test card program to include the new modes 10,11 and 12 colourBars.zip edited with small update to show max page number in each mode Jim Edited 2020-09-20 10:39 by TassyJim VK7JH MMedit |
