Forum Index : Microcontroller and PC projects : Another Mouse Interface
Seems like 'mites with mice is popular. Here is the version I have been working on: Youtube video Mine is based on a PIC16F18313 microcontroller which translates the PS2 interface to serial. I chose 38400 baud for my prototype but maybe I'll add that as a changeable config. Some mice with USB plugs work in PS2 mode also so that is the physical interface I chose. Might I encourage the keepers of the new Maximite2 standard to consider adding this valuable interface? My microcontroller based version only requires 2 open drain bi-direction pins to communicate with the mouse and less than 1000 bytes of (very poorly compiled) object code to perform the translation. Those two pins might need to be 5 volt tolerant too. This is also why I requested serial interrupts to fire when a particular character is received, a feature available in the Micromite and Micromite+. The Armmite source code in the above video appears below. The mouse pointer is implemented with a custom font, which includes the pointer, a hand and an hourglass wait character. The display trickery involves blitting the region of the screen where the mouse pointer is to appear into a buffer and then "printing" the custom mouse character into the screen. Moving the mouse involves blitting the saved portion back to the screen to erase the mouse, performing any required screen updates and then repeating at the new location. (An apparent bug in the 'TEXT' command prevents the mouse pointer character from sliding off the bottom of the screen.) ' Micromite Mouse Demo Program ' written by vegipete ' ' External hardware based on a PIC16F18313 microcontroller ' is used to convert PS2 mouse data to serial data. ' The external hardware can recognize a standard wheel mouse. ' Mouse data is ONLY sent when the mouse changes, to a ' maximum of 20 updates per second. ' The data format is an ASCII string of 16 characters: ' "LMR+000+000+000<\r>" ' L, M & R are the buttons, 1 when pressed, 0 when not ' +000 is the position change for each of x, y and z ' (z is the scroll wheel) ' Depending on the mouse, the displacement could range from ' +255 to -255 ' On a mouse with no scroll wheel, those fields are zero. ' ' Note that SOME USB mice work in PS2 mode too and work ' just fine with the external hardware. CLS Dim integer mx, my, mz, newmouse Dim integer mbl, mbm, mbr Dim mxold, myold As integer Dim dx, dy As float Open "com4: 38400,256,mouseint,16" As #2 On error skip ' allow error on next line Blit close 1 ' ensure blit buffer is free Text 150,15, "A Mouse and", "CT", 4 Text 150,40, "A Micromite", "CT", 4 Text 10,70, "With a special bit of",,2 Text 10,90, "interface hardware,",,2 Text 10,110, "both work together",,2 mx = 40 : my = 12 Text mx,130, "S",,2,,RGB(RED) : mx = mx + my Text mx,130, "P",,2,,RGB(yellow) : mx = mx + my Text mx,130, "E",,2,,RGB(cyan) : mx = mx + my Text mx,130, "C",,2,,RGB(blue) : mx = mx + my Text mx,130, "T",,2,,RGB(magenta) : mx = mx + my Text mx,130, "A",,2,,RGB(green) : mx = mx + my Text mx,130, "C",,2,,RGB(brown) : mx = mx + my Text mx,130, "U",,2,,RGB(green) : mx = mx + my Text mx,130, "L",,2,,RGB(magenta) : mx = mx + my Text mx,130, "A",,2,,RGB(blue) : mx = mx + my Text mx,130, "R",,2,,RGB(cyan) : mx = mx + my Text mx,130, "L",,2,,RGB(yellow) : mx = mx + my Text mx,130, "Y",,2,,RGB(RED) : mx = mx + my mx = MM.HRes/2 my = MM.VRes/2 mz = 33 newmouse = 0 GUI BARGAUGE #1, 300,20,10,200,RGB(GREEN),0,0,200 CtrlVal(#1) = mz GUI LED #2, "", 110,175,10,RGB(RED) Text 110,190, "Left", "CT", 1 CtrlVal(#2) = mbl GUI LED #3, "", 160,175,10,RGB(BLUE) Text 160,190, "Middle", "CT", 1 CtrlVal(#3) = mbm GUI LED #4, "", 210,175,10,RGB(GREEN) Text 210,190, "Right", "CT", 1 CtrlVal(#4) = mbr CursorOn Do If newmouse Then 'The screen should not be updated while the cursor is displayed CursorOff CtrlVal(#1) = mz CtrlVal(#2) = mbl CtrlVal(#3) = mbm CtrlVal(#4) = mbr CursorOn newmouse = 0 EndIf Pause 25 Loop End ' Routine called when a new data string is received from the mouse Sub mouseint Local dx,dy,dz Local string dm$ length 32 mbl = Val(Input$(1,#2)) ' left button mbm = Val(Input$(1,#2)) ' middle button mbr = Val(Input$(1,#2)) ' right button dx = Val(Input$(4,#2)) ' x movement dy = Val(Input$(4,#2)) ' y movement dz = Val(Input$(4,#2)) ' z (wheel) movement dm$ = Input$(8,#2) ' read any left over junk mx = mx + dx If mx < 0 Then mx = 0 If mx > MM.HRes-2 Then mx = MM.HRes-2 my = my - dy If my < 0 Then my = 0 If my > MM.VRes-24 Then my = MM.VRes-24 'Note: can't go to bottom of screen because of bug in text command mz = mz + dz If mz < 0 Then mz = 0 If mz > 200 Then mz = 200 newmouse = 1 End Sub ' Move cursor to (new) mx,my Sub CursorMove CursorOff CursorOn End Sub ' Save screen and paint cursor at mx,my Sub CursorOn Blit read 1,mx,my,14,20 ' save background mxold = mx : myold = my ' save location of saved background Text mx,my," ",,10,,,-1 ' paint the cursor End Sub ' Remove the cursor from the screen and restore screen Sub CursorOff Blit write 1,mxold,myold,14,20 ' restore background On error skip ' allow error on next line Blit close 1 ' free up the blit buffer for next time End Sub ' CursorFont20x24 DefineFont #10 04201814 00040000 05006000 00480000 42004004 00100400 04048040 04204000 08400001 44800F04 00A40480 12064052 00200100 0000000C 00000000 00000000 30000000 00800400 80040048 04004800 C04900E0 49009304 44927428 004424C0 10040042 04004100 80400008 80000408 01020840 03102000 000000FF FF070000 070140F0 0220F0FF 20200002 202A0202 88004411 00100480 10040022 10808800 20000204 2A024221 07522520 0140F0FF 00F0FF07 00000000 FF070000 070140F0 0220F0FF 20200002 202A0202 88004411 00100480 10040022 10808800 20000204 2A024221 07522520 0140F0FF 00F0FF07 00000000 00000000 End DefineFont > Enjoy! Visit Vegipete's *Mite Library for cool programs. |
TassyJim![]() Guru Joined: 07/08/2011 Location: AustraliaPosts: 6624 |
It's good to see another version. With all the different mice running around, there is sure to one version that woks with each mouse. Jim VK7JH MMedit |
| Amnesie Guru Joined: 30/06/2020 Location: GermanyPosts: 763 |
Ahh... I know I am ressurrecting an old post, but the whole mouse topic won't let me sleep. I am wondering if it is possible to use this approach with the picoMite VGA. I have lots of PS/2 mice flying around and all the hardware for an PS/2 to Serial adaptor which translates PS/2 code to serial. With that via a level shifter to some picoMite Serial ports it should be no problem, or I am missing something? Since we got all the good stuff Peter is working on (now an even better colour edit mode) I feel what's really left is the option of a mouse. Is is perfectly fine if it is not possible via "native" PS/2 .. but with this workaround? Let me know your thoughts Greetings Daniel |
Could I use my non vga picomite with touch screen to communicate fast x,y info to vga picomite please? Just to see. seems an idea. glcd buttons would be useful. serial? |
| JohnS Guru Joined: 18/11/2011 Location: United KingdomPosts: 4386 |
Yes just connect them to each other and send the data across. John |
| Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 9185 |
What you can't do is run a LCD and/or touch display and a VGA display on the same PicoMite. Also, bear in mind the graphics limitations of the PicoMite VGA implementation if you want to use a cursor. Only Mode 2 has true colour capability. Edited 2023-02-18 08:09 by Mixtel90 Mick Zilog Inside! nascom.info for Nascom & Gemini |
I meant a lcd picomite connected to another vga picomite.I got a touch lcd on vero and a breadboard vga. What do the 3 pads at the end do? What serial comm would be easiest/best i2c? It's just a thought. picomite is cheap enough to use 2 for a hobby idea. picomite glcd touch is accurate and could be a keypad control for a vga display but only thinking of games. I got a 2 pot x/y joystick that I could use a-d to read but again can't really think of a use... missile command? |
The three end pads are debug connectors - low level stuff that's not supported in MMBasic. You can link two (or more) PicoMites but there are no standards. You could use I2C, SPI or (easier than either) a COM port. The protocol and what data is sent is your design! You could write a program that simulates a PS/2 keyboard. That way you can send any characters you like in response to button presses or whatever and it's already decoded by a standard PicoMite. Don't ask me how though. :) It's a lot easier to simply get a PicoGAME set up and use joysticks (digital or analogue) or game pads though. After all, I designed it as a VGA games platform. :) Tom and Volhout have done some hard work in getting joystick and game pad handling sorted out for it. You can even put your little darling in a posh case after. :) Mick Zilog Inside! nascom.info for Nascom & Gemini |
is this picoGAME? http://www.picogame.com |
Nope. Similar name (but not logo) and no relation. :) They don't do hardware. Follow the "my PCB designs in my sig Mixtel90'sPCBs / PicoGAME 20 Construction Pack.zip Everything is in there, including gerber files. Edited 2023-02-19 03:02 by Mixtel90 Mick Zilog Inside! nascom.info for Nascom & Gemini |
*Push...* |
Why not try it? You'll need a PS/2 to serial converter of some sort then you can watch the COM port with a PicoMite. Mick Zilog Inside! nascom.info for Nascom & Gemini |
If you want to use a mouse for editing, saving, running mmbasic then the mmedit for win is sorted already. Getting a non win mouse to work with the picomite inbuilt editor.. how to integrate it? Using a mouse with own program different job. |
