Forum Index : Microcontroller and PC projects : CMM2: Dimming The Display
| Andrew_G Guru Joined: 18/10/2016 Location: AustraliaPosts: 883 |
Hi All, Is is possible to dim the VGA display (similarly to PWM on LCD's)? Yes, you can do it on the monitor's controls but I am thinking of using a Light Dependent Resistor, as I do on my LCDs, or via an IR command (as well as keyboard etc). Cheers, Andrew (I don't have a CMM2 yet) |
Depending on the display mode you are in, You could use the MAP command to change the colour intensity. You would need a number of sets of colour, one for each of the different light levels. Jim VK7JH MMedit |
Thanks Jim. Andrew |
