Forum Index : Microcontroller and PC projects : CMM2: Maze Generating Program
vegipete
Posted: 12:33am 09 Jun 2020
After more than a month of forced waiting, a shiny new Colour Maximite 2 from Circuit Gizmos finally, FINALLY arrived in the post. Thanks Circuit Gizmos! Two thumbs up!
It started fine. I briefly bricked it with the wrong firmware but now it is up to date and working marvelously.
Here is my first CMM2 program to share. I have implemented Eller's algorithm to generate mazes. I wrote the program last month for the original Colour Maximite and just finished porting and embellishing it for the CMM2.
Give it a try, let me know if you break it, bugs, whatever.
Enjoy!
' Random Maze Generator
' Implementation of Eller's Algorithm
' Written by Vegipete (vegipete@gmail.com)
' June 2020
' Eller's algorithm generates pure simply connected mazes
' of arbitrary length.
' By introducing a deliberate 'bug', mazes with loops can
' be generated.
dim integer WIDTH,LENGTH
cls
text 400,20, "Maze Maker", "CT",5,2,&HFFAF1F
text 400,70, "by vegipete, June 2020", "CT",2,1,&HFFAF1F
font 1
colour rgb(white)
'WIDTH = 100
do
 print @(10,100) "                           ";
 input "Enter width: (4-100) ", WIDTH
 if WIDTH > 4 and WIDTH < 101 then exit do
loop
'LENGTH = 100
do
 print @(10,120) "                           ";
 input "Enter length: (4-100) ", LENGTH
 if LENGTH > 4 and LENGTH < 101 then exit do
loop
' Horizontal/Vertical bias: .5 = even, lower = more horizontal
'BIAS = 0.5
print @(10,140) "The maze can be biased horizontally or vertically. 50=even bias, lower=more horizontal.";
do
 print @(10,160) "                           ";
 input "Enter bias: (1-99) ", BIAS
 if BIAS > 0 and BIAS < 100 then exit do
loop
BIAS = BIAS / 100
' Allow loops. 0 = NO loops, 1 = loops permited
print @(10,180) "Loops can be allowed in the maze, although not guaranteed."
LOOPS = 0
do
 print @(10,200) "                           ";
 input "Allow loops: (y/n) "; loopyn$
 if loopyn$="Y" or loopyn$="y" or loopyn$="N" or loopyn$="n" then exit do
loop
if loopyn$="Y" or loopyn$="y" then LOOPS = 1
Cls
colour rgb(white), rgb(black)
Print : Print
Dim m$(2*LENGTH+1) length 2*WIDTH+1
Dim w(WIDTH)
Dim p(WIDTH)
Dim cnt(WIDTH)
DoSameAgain:
m$(1) = "#"
m$(2) = "#"
For i = 1 To WIDTH
 m$(1) = m$(1) + "##"
 m$(2) = m$(2) + " #"
Next i
m$(3) = m$(1)
For i = 4 To LENGTH*2 Step 2
 m$(i) = m$(2)
 m$(i+1) = m$(3)
Next i
show_m  'display initial all wall maze
row = 2
For i = 1 To WIDTH : w(i) = i : Next i
 ' do horizontal cell joining
 For i = 1 To WIDTH : p(i) = 0 : Next i
 ' Uncomment the following for an interesting variable bias effect
 'BIAS = row / LENGTH / 2
 For i = 2 To WIDTH
   If Rnd(1) > BIAS Then
     If w(i) <> w(i-1) Then
       ' change set
       If LOOPS Then
         w(i) = w(i-1)
       Else
         rc = w(i)
         For j = 1 To WIDTH
           If w(j) = rc Then w(j) = w(i-1)
         Next j
       EndIf
       ' update maze
       lp$ = Left$(m$(row),2*(i-1))
       rp$ = Right$(m$(row),2*WIDTH-2*(i-1))
       m$(row) = lp$ + " " + rp$
     EndIf
   EndIf
 Next i
 show_mline(row)
 ' reorder set ids and count
 For i = 1 To WIDTH : cnt(i) = 0 : w(i) = w(i) + WIDTH : Next i
 rc = 1
 For i = 1 To WIDTH
   If w(i) > WIDTH Then
     sn = w(i)
     w(i) = rc
     For j = i To WIDTH
       If w(j) = sn Then w(j) = rc
     Next j
     rc = rc + 1
   EndIf
   cnt(w(i)) = cnt(w(i)) + 1
 Next i
 row = row + 1
 ' do vertical cell joining
 For i = 1 To WIDTH
   dd = 0
   If cnt(w(i)) = 1 Then
     ' set with single element MUST open downward
     p(i) = w(i)
     dd = 1
   ElseIf cnt(w(i)) > 1 Then
     ' set with multi elements randomly opens downward
     If Rnd(1) < BIAS Then
       p(i) = w(i)
       dd = 1
     Else
       ' each set MUST have at least one downward opening
       cnt(w(i)) = cnt(w(i)) - 1
     EndIf
   EndIf
   If dd Then
     ' update maze - make vertical passages
     lp$ = Left$(m$(row),2*i-1)
     rp$ = Right$(m$(row),2*(WIDTH-i)+1)
   EndIf
 Next i
 show_mline(row)
 row = row + 1
 ' build new row from downward passages
 For i = 1 To WIDTH : w(i) = p(i) : Next i
 ' fill in new sets
 rc = WIDTH
 For i = 1 To WIDTH
   If w(i) = 0 Then
     w(i) = rc
     rc = rc - 1
   EndIf
 Next i
Loop While row < 2*LENGTH
' do final horizontal joining
For i = 2 To WIDTH
 If w(i) <> 0 Then
     ' change set
     For j = i + 1 To WIDTH
       If w(j) = w(i) Then w(j) = 0
     Next j
     w(i) = w(i-1)
     ' update maze
   EndIf
 EndIf
Next i
show_mline(row)
print @(10,530) "Width:" WIDTH "  Length:" LENGTH "  Bias:" BIAS "  Loops allowed: ";
if LOOPS then print "Yes" else print "No"
do
 print @(10,545) "                           ";
 input "Same again: (y/n) "; loopyn$
loop
if loopyn$="Y" or loopyn$="y" then goto DoSameAgain
End
' Print the whole maze
Sub show_m
 Local y
 For y = 1 To LENGTH*2+1
   show_mline(y)
 Next y
End Sub
' Print just a particular line of the maze
Sub show_mline(y)
 Local integer x,cx,cy,px,py
 cx = MM.HRes/(WIDTH*3)
 cy = MM.VRes/(LENGTH*2.8)
 py = y * cy + 0
 For x = 1 To WIDTH*2+1
   px = x * cx + 20
   If Mid$(m$(y),x,1) = " " Then
     box px,py,cx,cy,1,rgb(black),rgb(black)
   Else
     box px,py,cx,cy,1,rgb(white),rgb(white)
   EndIf
 Next x
End Sub
Posted: 03:05am 09 Jun 2020
Excellent work.
My first instinct was black is the walls.
It didn't take long to realise that the walls are white.
It needs a start and end added.
I will add my joystick/mouse reader to it to make a good dexterity trainer, something that I had been planning to do.
Posted: 03:40am 09 Jun 2020
Call this just before printing the maze:
  Quote  SUB setendpoints
LOCAL INTEGER s
DO
   s =
RND()*LENGTH*2 + 1
IF MID$(m$(s),2,1)= " " THEN EXIT DO
LOOP
 m$(s)=
" "+MID$(m$(s),2)
DO
   s =
RND()*LENGTH*2 + 1
IF MID$(m$(s),LEN(m$(s))-1,1)= " " THEN EXIT DO
LOOP
 m$(s)=
LEFT$(m$(s),LEN(m$(s))-1)+" "
END SUB
Random start and finish on each side.
Edited 2020-06-09 13:55 by TassyJim
vegipete
Posted: 05:18am 09 Jun 2020
Good modification, but I can't get it to work, partially because the maze is printed line by line as it is generated.
Try the following instead:
SUB SetEndpoints
 Local integer cx,cy,px,py
 ' Door on right side
 px = (WIDTH * 2 + 1) * cx + 20
 py = RND() * LENGTH
 py = py * 2
 mid$(m$(py),len(m$(py))) = " "
 py = py * cy
 ' Door on left side
 px = cx + 20
 py = rnd() * LENGTH
 py = py * 2
 mid$(m$(py),1) = " "
 py = py * cy
END SUB
The subroutine can be placed at the very end of the program and called just before the "print @(10,530..." line. It makes the openings left and right on screen and in the m$ array. Note there is an awesome new MID$ command!
Posted: 02:06am 10 Jun 2020
I made a small change to prevent py = 0
SUB setendpoints
 py = RND() * (LENGTH-1) + 1
 py = py * 2
 py = py * cy
 ' Door on left side
 px = cx + 20
 py = py * 2
 py = py * cy
END SUB
This is my mouse track in action:
vegipete
Posted: 02:20am 10 Jun 2020
Cool! Nice job.
I figured out the cy = 0 problem last night. It seems to be related to floating point rounding fun.
Change the rnd() lines to
py = int(RND() * LENGTH) + 1
