Local Time 17:14 19 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2 and MMEdit
panky
Posted: 01:01am 21 Jun 2020
Jim, One for you perhaps?
Using MMEdit with the CMM2 -
In the latest MMEdit (13 Jun 20 build), when you do a load and run (the running man), the xmodem transfer works fine creating the temp.bas file on the sd card, however, MMEdit then invokes a LOAD "temp.bas" command which fails as this is an invalid command.
Should it perhaps be either RUN or EDIT "temp.bas" ?
Doug.
Chopperp
Posted: 02:02am 21 Jun 2020
I've been using MM File Master to move files from the PC to the A drive (& the other way) for the limited stuff I've done so far.
Brian
ChopperP
Posted: 02:41am 21 Jun 2020
Ah.
That is a change that happened during the CMM2 development and I missed it.
I usually open the terminal and do a 'load' from there. At present that does a run immediately after load.
Will fix in the next day or so.
Thanks.
Chopperp
Posted: 02:52am 21 Jun 2020
Jim, I assume there is a good reason for saving file to the A drive as "temp.bas" & not as it's true file name?
Just wondering.
Brian
ChopperP
Posted: 03:48am 21 Jun 2020
Doug,
If you have 'auto run on load' selected it should run.
It is only if 'auto run on load' is not selected that MMEdit tries to LOAD and causes problems.
To fix that, I have to address Brian's question about saving as temp instead of real name.
With the Maximite1 you had to transfer via the disk then LOAD
Micromite transfer direct to memory.
Now we have to transfer to disk but don't have the option to LOAD, just RUN so lots of variations to try and handle.
Personally, I prefer to use temp.bas so I know I am not overwriting a good program.
I intend to make it an option.
If you use MMUploader to transfer files, you do have that option and I intend to use MMUploader as a base for a new 'control centre' as part of MMEdit.
