Local Time 02:24 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: V5.05.03 Bug Reports
     Page 1 of 4
Posted: 10:52am 22 Jun 2020
Please report any bugs in the release version of 5.05.03 here.
Current issues:
  Quote  If you draw a box or a circle that is entirely off the screen, the edge still appears on screen.
TBC:
  Quote  I believe I spotted a CMM2 Basic bug. SPRITE LOAD “spritefile.spr” appears to mangle sprites in any color mode other than 8 bits.
This bug or something like it was recently fixed - awaiting more info before investigating
Posted: 11:45am 22 Jun 2020
Sorry Peter, but is the issue with a program "RUNning" itself resolved? I didn't see anything in the 5.05.03 release notes that seemed to correspond.
Thanks for resolving the other issues I reported.
Posted: 12:03pm 22 Jun 2020
  Quote  is the issue with a program "RUNning" itself resolved?
It is not something I can look at unless someone can demonstrate it in a simple enough program to investigate. I read your release notes on zmim to mean it was no longer an issue.
Posted: 12:09pm 22 Jun 2020
  matherp said  It is not something I can look at unless someone can demonstrate it in a simple enough program to investigate.
You obviously missed it in the kerfuffle over SD cards, it's on p15 of the previous thread:
Function exec(a) As Float
 Local s$
   Line Input "Run again [y|n] ", s$
   s$ = LCase$(s$)
 Loop Until s$ = "y" Or s$ = "n"
 If s$ = "y" Then Run
 exec = 1
End Function
Sub main()
 Cls
 a = exec(1)
End Sub
main()
Run and answer "y" followed by "n" to get this error:
[17] Error: Nothing to return to
It's not the same error message, but it has the same "feel" of the interpreter having lost context so I suspect it's the same issue.
  Quote  I read your release notes on zmim to mean it was no longer an issue.
Yes, I worked around it, but I thought it might still be an issue that should be resolved for the future.
Edited 2020-06-22 22:10 by thwill
Posted: 12:18pm 22 Jun 2020
Yes - missed it.
Just checked and it is in the MM2 as well so I'll pass it over to Geoff
UPDATE
The problem is fixed by putting an END statement after main(). Please try the same on zmim V1. I don't have a copy.
Edited 2020-06-22 23:54 by matherp
Posted: 01:59pm 22 Jun 2020
What a contrived case!
I can guess as to what is causing this and will add it to the todo list.  In the meantime don't run a program from within a sub.
Posted: 05:53pm 22 Jun 2020
New bug
GPS function not working at the command line but will work in a program
Posted: 08:15pm 22 Jun 2020
  matherp said  The problem is fixed by putting an END statement after main(). Please try the same on zmim V1. I don't have a copy.
That doesn't fix it for the real code. My guess is that in the "contrived example" whatever bad state the interpreter/firmware ends up in has by luck come across that END statement which allows it to end "gracefully", whereas in the real code it hits something that it can't deal with, i.e.
[execute.inc:24] Error: EXEC is not declared
where it looks like it is trying to assign to the EXEC function which it no longer knows about in its bad state.
Perhaps it also matters how deep the call stack is when END is called.
Posted: 08:16pm 22 Jun 2020
  Geoffg said  What a contrived case!
Damned if I do and damned if I don't . The real case isn't contrived but it is hundreds of lines long.
Edited 2020-06-23 06:17 by thwill
Posted: 08:40pm 22 Jun 2020
  thwill said  That doesn't fix it for the real code.
Ignore me I'm talking twaddle.
Ensuring that RUNned program actually invokes the END command instead of just "running off the end of the code" does fix the problem.
Thanks,
Edited 2020-06-23 06:58 by thwill
Posted: 12:50pm 23 Jun 2020
Possible BUG? conditionals don't perform short-circuit evaluation
Try this:
Function always_true()
 Print "always true"
 always_true = 1
End Function
Function always_false()
 Print "always_false"
 always_false = 0
End Function
Cls
Print always_true() Or always_false()
Print always_false() And always_true()
The output is:
always true
always_false
1
always_false
always true
0
I would have expected:
always true
1
always_false
0
My expectation comes from the fact that if the first operand of an OR is true, or the first operand of an AND is false then the code does not need to evaluate the second operand.
As it stands you can't do this:
If tk_char = -1 Or Chr$(tk_char) = " " Then ...
Because Chr$() will report an error when tk_char = -1
I know there are ways to workaround it, but (in a more complex case than this) they are more verbose.
Best regards,
Edited 2020-06-23 22:51 by thwill
Posted: 01:03pm 23 Jun 2020
Everything to do with the core MMBasic language is for Geoff and not me and will probably be common across all V5 MM and possibly V4.5
For this sort of issue can I request that you also test on a MM2 and only post on this thread if you see a difference in behaviour (meaning I've done something stupid). If the behaviour is the same it is probably better to raise the issue on a separate thread for Geoff to comment.
I will keep the CMM2 up-to-date with any of Geoff's changes to core MMBasic but won't be making any changes that cause behaviour to deviate from other versions.
Posted: 01:37pm 23 Jun 2020
  matherp said  Everything to do with the core MMBasic language is for Geoff and not me and will probably be common across all V5 MM and possibly V4.5
OK, but Geoff isn't so foolhardy as to have a BUG reporting thread
  Quote  For this sort of issue can I request that you also test on a MM2 ...
It would be my pleasure if you'd like to send me one in the meantime perhaps someone else will oblige.
  Quote  ... and only post on this thread if you see a difference in behaviour (meaning I've done something stupid). If the behaviour is the same it is probably better to raise the issue on a separate thread for Geoff to comment.
Ack.
Turbo46
Posted: 02:10pm 23 Jun 2020
  matherp said  but won't be making any changes that cause behaviour to deviate from other versions.
The FILES command is an exception?
Bill
CircuitGizmos
Posted: 02:56pm 23 Jun 2020
The output is:
always true
always_false
1
always_false
always true
0
This is what I expect. Given that the functions need to run in order to return either a 0 or a 1, anything inside the function has to be executed.
Posted: 03:07pm 23 Jun 2020
  CircuitGizmos said  This is what I expect. Given that the functions need to run in order to return either a 0 or a 1, anything inside the function has to be executed.
Thanks for confirming. That's not actually the case for the programming languages I'm familiar with which would not evaluate the second operand when its value cannot change the result.
However looking at VB.NET in the table at Short-circuit evaluation it looks like this is not a bug for BASIC, but we are "missing" the AndAlso and OrElse operators.
Edited 2020-06-24 01:08 by thwill
Posted: 03:34pm 23 Jun 2020
  Quote  The FILES command is an exception?
Files in not part of "core" MMBasic - it doesn't even exist on a MM2m, I'm talking about the main language elements. In general commands that can only be run at the command line are not "core"
CircuitGizmos
Posted: 11:58pm 23 Jun 2020
If you are talking a compiled language, then that would be optimized out. MMBasic is interpreted and cannot act another way.
Posted: 12:06am 24 Jun 2020
I don't think you are correct, consider:
a = fun1() AND fun2()
When the interpreter reads fun1() it evaluates it and stores the value, it then reads AND, if the stored value is 0 then it would be permissable for the interpreter to read but not evaluate the second operand since it knows the result of the evaluation cannot change the result of the expression.
Case in point Python only has short-circuit boolean operators yet it is generally called interpreted (though you could argue that it is neither fish nor fowl).
However I have accepted that BASIC apparently doesn't work this way, I never knew.
Edited 2020-06-24 10:10 by thwill
Turbo46
Posted: 12:45am 24 Jun 2020
  Quote  Files in not part of "core" MMBasic - it doesn't even exist on a MM2m, I'm talking about the main language elements. In general commands that can only be run at the command line are not "core"
It IS part of MMBasic for the original Mono Maximite, the Colour Maximite, the Micromite plus, DOS(Windows) MMBasic and probably other ported versions. It's part of Microsoft GWBASIC and QuickBASIC as well.
Sorry but I just think it's an unnecessary deviation from the well trodden path.
Bill
     Page 1 of 4
