Local Time 03:29 13 Aug 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Solder
palcal
Posted: 08:24am 25 Jun 2020
My roll of .5mm solder is coming to an end, so I ordered some more. Not wanting to end up with cheap rubbish I went to RS components where I buy a lot of my bits.
Well I got an email from them saying they can't sell to me unless I have a business number because it contains LEAD. I can buy it from the hardware store or the local electronics shop or EBay for that matter but not from RS. That deadly lead.
Posted: 08:30am 25 Jun 2020
I basically don't bother with RS at this point.  They are usually shockingly expensive with their prices too compared to other houses.  I get my 0.5mm(and 0.3mm) 60/40 multi-core solder from Element 14.
hitsware2
Posted: 02:07pm 25 Jun 2020
Interestingly lead is illegal here also ,
but it is not enforced .
my site
Posted: 02:22pm 25 Jun 2020
soon you'll need a note from your mum just to buy a replacement for your lead-acid car battery. think about it... those batteries contain not one, but TWO deadly substances - LEAD and ACID     ingesting either will make your hair prematurely curl!
rob   :-)
Posted: 12:11am 24 Jul 2020
Hi Palcal,
How did you go with sourcing your `decent’ solder?
I know I am late responding but my usual supplier Radio Parts didn’t seem to stock the 0.5mm any more..
I just received an email from Rocky electronics and they are selling 0.56mm 60/40 solder at Reasonable price $13AU for 250Gm
See this specials ad..
Rock by
I hope its useful to you.
palcal
Posted: 08:53am 24 Jul 2020
@ bigmik,   I bought it from Altronics, all is good.
Poppy
Posted: 09:24am 24 Jul 2020
  hitsware2 said  Interestingly lead is illegal here also ,
Is it really illegal for everyone?
In Germany it is still available for exclusively private purpose (at least theoretically, recently I also had some probs getting good stuff for myself), only commercial use is strictly prohibited here.
Edited 2020-07-24 19:24 by Poppy
Andre ... such a GURU?
Posted: 06:29pm 24 Jul 2020
Solder containing lead is illegal for many many puposes. Also for private use.
There has been a transition phase of some 10 years or so, in which more and more product categories where enforced to transition.
ATM only military and aerospace stuff may be produced with solder containing lead.
Previously computer servers where still allowed to contain leaded solder, but that category has also transitioned.
The only reason solder containing lead can currently be sold is for repair purposes.
P.S. IMHO this change was not needed at all. It was driven from electronic equipment ending up in landfills polluting the drinking water. A subsidy system would have made this all unnecessary (PAY FOR RETURNED LEAD, AND SELL IT AGAIN). Similar to companies that re-sell the gold from old computer boards and chips.
And about the risk of lead: I have been using leaded solder for 50+ years now daily, and still breathe.....
Posted: 06:37pm 24 Jul 2020
  Volhout said  And about the risk of lead: I have been using leaded solder for 50+ years now daily, and still breathe.....
I molded, painted, and played with about 1300 lead soldiers from about age 10 through high school . . . and still breathe.
But I admit that the fact that some smokers live to 100 is not an argument that there is no danger to smoking.
Posted: 06:58pm 24 Jul 2020
Isn't the lead-free stuff even worse for the user and the environment, it's just that "lead polution" grabs headlines and hardware failure due to "tin whiskers" doesn't ?
Ditto on the toy soldiers ... though sounds like you grew out of it faster "lizby"
Edited 2020-07-25 05:00 by thwill
Poppy
Posted: 07:37pm 24 Jul 2020
  Volhout said  Solder containing lead is illegal for many many puposes. Also for private use.
The only legal basis that I know is
DIRECTIVE 2011/65/EU OF THE EUROPEAN PARLIAMENT AND OF THE COUNCIL
of 8 June 2011
on the restriction of the use of certain hazardous substances in electrical and electronic equipment
and it simply says "no lead in electric/-onic equipment" it says nothing about specially solder itself, except depending on:
Article 4
Prevention
1.   Member States shall ensure that EEE placed on the market, including cables and spare parts for its repair, its reuse, updating of its functionalities or upgrading of its capacity, does not contain the substances listed in Annex II.
but still nothing about solder as an autonomous product.
Or I just missed it?!?
I guess the production of lead-containing solder is generally running out due to decreasing industrial usage.
Posted: 01:46am 25 Jul 2020
Hi All,
To the best of my knowledge Leaded solder is not illegal in Australia.. But in the last 2 or 3 years of my working career the company changed the rule to only use lead free solder..
We all had our own stock of leaded solder because we hated the lead free rubbish..
We often had to re-solder connectors out in the dirt and mud and not in exactly pristine working conditions and trying to do that with junk that doesn’t like to stick unless its perfectly clean and even when it does it looks like it hasn’t soldered properly and looks `grainy’ instead of shiny silver..
I cannot believe in this day and age a better solution hasn’t been designed..
Would NASA actually use this stuff on space ships that go to Mars and beyond?
Posted: 09:11pm 25 Jul 2020
There is a good reason to go to lead free solder these days. All production processes have been "tuned" for lead-free solder now a days, and the result is not bad at all.
Assembly houses will generally not even have a process for leaded solder anymore.
There is a variety of lead free solders, some based on silver, some on copper, and even more exotic variants (bismuth).
Circuit boards have higher Tg's, Components have been re-engineered to withstand the higher temperatures. Have pure tin plating on the pins (leadframe finish).
Why go for a (theoretical) better material, when the mainstream process is adequate these days.
And mechanical properties of leadfree solders are better. In vibrations tests, components typically stay connected.
One of the disdavantages of lead free solder is the mechanical strength however. In large temperature shocks, the lead free solder could rip copper traces from PCB's since it is stronger than the glue that holds the copper to the board. This is especially true for BGA's, that have very fine traces and pads. Typically at the edges of large BGA's is where the problems show.
on the other hand, the leaded solder would tear apart and show micro cracks, and eventually would also fail.
But for manual soldering and rework...nothing beats the old 37/63 or 40/60 leaded solder.
Edited 2020-07-26 07:13 by Volhout
BrianP
Posted: 11:02pm 25 Jul 2020
Same for me - just try not to breathe in the fumes while using.
