Local Time 17:14 19 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : I2C Help
Chopperp
Posted: 11:56pm 25 Jun 2020
HI
Just experimenting with talking between 2 uMites using I2C according to the instructions & codes in the 5.04 manual.
The two units do talk to each other but the Slave won't receive the full message from the Master.
I get the following messages:
 [9] I2C SLAVE READ 3, MSG(), RECVD
  ERROR: Cannot find RECVD
I take this to mean that the Slave is not receiving the instructions.
I did a fair bit of stuffing around but not getting anywhere.
I'm just trying to turn on a LED on PIN 16 on the Slave.
Any help would be appreciated.
SSETPIN 16, 8  'pin 16 & Digital Out
SPIN 16, 1
PAUSE 300
SPIN 16, 0
SUB SSETPIN 'pinnbr, cfg
 I2C OPEN 100, 1000,pu
 I2C WRITE &H26, 0, 3, 1, pinnbr, cfg
 IF MM.I2C THEN ERROR "Slave did not respond"
 I2C CLOSE
END SUB
' set the output of an I/O pin on the slave
SUB SPIN pinnbr, dat
 I2C WRITE &H26, 0, 3, 2, pinnbr, dat
 I2C CLOSE
END SUB
SLAVE
 OPTION AUTORUN ON
 DIM msg(2) ' array used to hold the message
 I2C SLAVE OPEN &H26, 0, 0, WriteD, ReadD ' slave's address is 26 (hex)
 DO ' the program loops forever
   WATCHDOG 1000 ' this will recover from errors
 LOOP
 SUB ReadD ' received a message
   print "Received Message"
   I2C SLAVE READ 3, msg(), recvd ' get the message into the array
   IF msg(0) = 1 THEN ' command = 1
     SETPIN msg(1), msg(2) ' configure the I/O pin
   ELSEIF msg(0) = 2 THEN ' command = 2
     PIN(msg(1)) = msg(2) ' set the I/O pin's output
   ELSE ' the command must be 3
     s$ = str$(pin(msg(1))) + Space$(12) ' get the input on the I/O pin
 END SUB ' return from the interrupt
 SUB WriteD ' request from the master
   I2C SLAVE WRITE 12, s$ ' send the last measurement
BTW, just found out recently that you can paste more than one line at a time into MMChat using the Paste Icon.
Very handy more running multiple lines of straight code
Brian
ChopperP
Posted: 12:18am 26 Jun 2020
recvd is a variable that is used to hold the number of bytes actually received.
Try declaring it as a local at the start of the SUB.
Chopperp
Posted: 12:32am 26 Jun 2020
Thanks Jim.
Much better. LED flashes.
Had to be something simple
Brian
ChopperP
Chopperp
double post.
Edited 2020-06-26 10:33 by Chopperp
ChopperP
Posted: 01:25am 26 Jun 2020
shouldn't RECVD be created automatically, unless OPTION EXPLICIT has been declared earlier on in the code?
this looks like a bug in MMbasic to me, but i could be wrong.
rob   :-)
Chopperp
Posted: 03:01am 26 Jun 2020
I wouldn't have thought that the variable needed declaring in this case.
I assumed that the demo programs were tried & tested.
Of course, I would have declared it in a real program & used OPTION EXPLICIT
BTW I forgot to remove the comment in the following line before posting. Was playing.
Brian
ChopperP
