Local Time 18:11 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: RUNning a program named by a variable$ or string-expression
Posted: 12:54pm 28 Jun 2020
The following post contains attributions to both matherp and TassyJim. I apologise in advance for any innaccuracies or misrepresentation.
I've come across this limitation in my development work and thought I would share in the event that others hit the same.
MMBasic on the CMM2 requires the target of a RUN statement to be a string literal , i.e. it doesn't allow you to do the following:
s$ = "foobar.bas"
Run s$
TassyJim suggested a workaround equivalent to the following:
s$ = "foobar.bas"
Open "/tmp.bas" For Output As s#1
Print #1, "Run " + Chr$(34) + s$ + Chr$(34)
Run "/tmp.bas"
But matherp said "This is a ... bad idea and causes the flash to be re-written twice." I think this argument was regarding wearing out the flash on the microcontroller, but it may also have been a comment on performance.
I thought some more about it and believe the following should work without the double-hit on the flash:
s$ = "foobar.inc"
Print #1, "#Include " + Chr$(34) + s$ + Chr$(34)
Run "/tmp.bas"
Though it does require you to provide foobar as a .inc file instead of a .bas file. Of course if you also need to execute foobar standalone you can just have a parallel foobar.bas file consisting of a single #Include statement.
Best regards,
Edited 2020-06-28 22:59 by thwill
Posted: 08:02pm 28 Jun 2020
Dang! it doesn't work in the general case because .inc files are not allowed to #Include other .inc files I guess I have to try an persuade Peter to make more changes
EDIT: and it would also be limited by the fact that #Include does not support absolute paths.
Edited 2020-06-29 07:24 by thwill
Posted: 12:48pm 01 Jul 2020
I have been thinking some more about this and there are two related use-cases I'm seeking a solution for:
1. RUN a program where its name comes from a string expression.
2. RUN a program using the * command where that program is not situated in SEARCH PATH
 - some programs have additional .inc files and use other file resources you don't want to copy into SEARCH PATH and you don't want to use absolute paths to.
 - you don't want to hit the flash twice so the "solution" of having a stub file in SEARCH PATH that calls RUN on the real file is undesireable.
I believe there is a single solution to both, and looking at the MMBasic source (Pi version) it doesn't look too difficult to implement:
a. You define a .lnk file type that contains a single line containing the path of a .bas file to run.
- ideally it would also allow comments because I'm interested in autogenerating these files and autogenerated files should always indicate their origin.
b. When we use RUN or * and the file argument specifies a .lnk file then MMBasic reads that file and RUNs (i.e. "FileLoadProgram") the program specified therein.
This fixes problem (1) as follows:
s$ = "A:/subdir/foobar.bas"
Open "/tmp.lnk" For Output As s#1
Print #1, s$
Run "/tmp.lnk"
And for problem (2):
If you create a file "zmim.lnk" in the SEARCH PATH containing:
/zmim/src/main.bas
Then typing *zmim would RUN /zmim/src/main.bas with only a single hit on the flash.
Thanks for reading,
Edited 2020-07-01 23:14 by thwill
