Local Time 02:21 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMBasic question, array assignment
abraxas
Posted: 10:20pm 15 Jul 2020
Is it possible to assign an array to another variable so you can have a level of indirection? For example I’m trying to do a swap of arrays but it doesn’t work or I’m getting the syntax wrong:
DIM foo(10) AS INTEGER
DIM bar(10) AS INTEGER
DIM baz() = foo()
Above won’t work no matter what combinations of brackets or no brackets I’m trying to use.
Likewise I haven’t been able to return an array from a function. I tried to do that as a substitute for swapping them via references.
twofingers
Posted: 10:32pm 15 Jul 2020
  abraxas said  Is it possible to assign an array to another variable so you can have a level of indirection?
No.
You have to copy each array element individually.
Michael
Edited 2020-07-16 08:36 by twofingers
The lone and ...
Posted: 10:36pm 15 Jul 2020
Can you explain further what you mean by "a level of indirection"?
I assume you don't mean: for i = 1 to 10: bar(i)=foo(i): next i
Or: for i = 1 to 10: j=bar(i): bar(i)=foo(i): foo(i)=j: next i
While you can't return an array in a function, you can manipulate global arrays in a sub, and I believe can manipulate arrays passed (by reference) to a sub.
abraxas
Posted: 10:37pm 15 Jul 2020
No
Well, that was succinct... how about the second part of my question, the part about returning arrays from functions?
abraxas
Posted: 10:39pm 15 Jul 2020
  lizby said  Can you explain further what you mean by "a level of indirection"?
No, it’s not what I’m after. I want to have a reference that refers to a different array at different times.
vegipete
Posted: 11:02pm 15 Jul 2020
  abraxas said  I want to have a reference that refers to a different array at different times.
Perhaps you can use an array of arrays. Then your reference is just the index of the desired array.
dim foobar(2,100)
put foo(N) into foobar(1,N)
put bar(N) into foobar(2,N)
Use 1 to access foo, 2 to access bar.
abraxas
Posted: 11:35pm 15 Jul 2020
dim foobar(2,100)
Great idea, that’s probably how I’m going to solve it.
panky
Posted: 11:37pm 15 Jul 2020
@abraxas,
Not sure if this will help but the EVAL command may be a way to achieve what you want?
a=0         ' array index
c="x$"      ' array name
e$=str$(a)  ' array index as string
dim x$(2)   ' 3 element string array
x$(0)="hi"  ' array first slot
x$(1)="lo"  ' array second slot
' do something with the array
print eval(c$+"("+e$+")") ' use EVAL to plug in variable names
So, by changing just a and c$ you could reference any element of any array.
(tested on a CMM2
panky
abraxas
Posted: 12:54am 16 Jul 2020
  panky said  @abraxas,
a=0         ' array index
c="x$"      ' array name
(tested on a CMM2
panky
Using EVAL for this seems like an expensive way to dereference the elements...
It's surprising that MMBasic doesn't let us do what I tried to do in the first place. Since every variable is internally passed by reference it should be quite natural to add as a language feature.
Posted: 12:15pm 16 Jul 2020
  abraxas said  Using EVAL for this seems like an expensive way to dereference the elements...
Still not sure exactly what you're looking for--something like a pointer in C, which could point to an element in one array, or to an element in another?
Tinine
Posted: 01:52pm 16 Jul 2020
Wish I had the time to create a library of such things. No need to bloat MMBasic with functions that are rarely used.
/* copying one array to another */
for(i = 0; i < Size; i++)
   b[i] = a[i];
Craig
