Forum Index : Microcontroller and PC projects : CMM2: Restoring options after a firmware update
Posted: 12:03pm 24 Jul 2020
Hi folks,
I thought I had a clever way to restore my options after a firmware update:
> list "/config.bas"
If Mm.Info$(Search Path) = "" Then
 Print "one"
 option f11 "chdir " + chr$(34) + "/zmim/src" + chr$(34) + chr$(13) + chr$(10)
 option f12 "chdir " + chr$(34) + "/mbt/src" + chr$(34) + chr$(13) + chr$(10)
 option search path "/bin/"
 ' so this script will run again on reset
 option autorun on
 ' this will cause a reset
 option sd timing fast
Else
 Print "two"
 ' so this script will not run again
 option autorun off
 ' this will cause a reset - note even if autorun was still on it wouldn't
 ' take effect because running from RAM means that there will be no current
 ' program after the reset
 option ram
EndIf
So the idea is that after updating the firmware you reset the CMM2 and just type *config.
I use the AUTORUN trickery because both OPTION SD TIMING and OPTION RAM cause a reset.
But it doesn't seem to work, the script doesn't get run a second time.
Can anyone explain ?
... it looks like the AUTORUN doesn't occur after a reset due to changing SD TIMING or RAM. Are there different types of reset going on?
mkopack73
Posted: 12:39pm 24 Jul 2020
Are you sure the search path setting gets maintained after the first reboot so as to cause the else clause to get invoked?
You might want to have the code print the current search path right at the start so you'll see what it thinks it is both times...
Only thing I can think of...
Posted: 02:16pm 24 Jul 2020
  mkopack73 said  Are you sure the search path setting gets maintained after the first reboot so as to cause the else clause to get invoked?
Yes, I am sure.
And if I then do a hard reset the second part of the config script will be executed.
It looks like there is a difference between the reset performed when OPTION SD TIMING FAST, or OPTION RAM, or OPTION USBKEYBOARD are used and a hard reset of the Waveshare.
Edited 2020-07-25 00:16 by thwill
Posted: 04:06pm 24 Jul 2020
So in another thread Peter told me that AUTORUN deliberately doesn't occur after changing an option which requires a reset
So instead I'm using this:
SEARCH_PATH$ = "/bin/"
s$ = Mm.Info$(Search Path)
If LCase$(Mm.CmdLine$) = "reset" Or LCase$(Mm.CmdLine$) = "clear" Then
 Print "OK"
 option reset
ElseIf LCase$(Mm.CmdLine$) = "list" Or s$ = SEARCH_PATH$ Then
 option list
ElseIf Mm.CmdLine$ <> "" Then
 Error "Unknown command line option"
ElseIf s$ = "" Then
 option search path "/magic/"
 Print "Please run *config again to complete setup"
 ' This will cause a reset
ElseIf s$ = "/magic/" Then
 option search path SEARCH_PATH$
 Print "OK"
 option ram
Else
 Error "Unknown state"
EndIf
It's not especially pretty, but it does the job.
