Forum Index : Microcontroller and PC projects : CMM2: V5.05.05 beta
Page 7 of 7 | |||||
capsikin Guru Joined: 30/06/2020 Location: AustraliaPosts: 341 |
Also I can test this by pressing Ctrl-C at the command prompt, doesn't need to be interrupting a program. It does this even when I set autorepeat to 2000,2000 and do it in well under 2 seconds. Doing the same with Shift-C instead of Ctrl-C does a capital C, and a lower case C only after about 2 seconds. (i.e. the issue only happens with control, not with shift) Edited 2020-08-29 18:46 by capsikin |
matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 8579 |
Just tested and it does exactly the same in W10 when typing into notepad. Nothing to do with the CMM2 just the way USB keyboards work. Workround: release the C key before or at the same time as Ctrl!!!!!!!!!! Edited 2020-08-29 20:40 by matherp |
CircuitGizmos Guru Joined: 08/09/2011 Location: United StatesPosts: 1421 |
5.05.05b22 From the manual: PLAY TONE left [, right [, dur]] PLAY TONE 440 results in [2] Error: Argument count Either code is wrong or doc is wrong. Micromites and Maximites! - Beginning Maximite |
Corrected in the "to-be-released" version of the manual |
Page 7 of 7 |
