Forum Index : Microcontroller and PC projects : Armmite F4 SD card file problems
Posted: 12:42pm 02 Aug 2020
Dear matherp,
While creating the tetris game I ran into some things I could need some guidance with.
It relates to the SD card file handling.
I want to create a file on SD card, and write data in it, and read it back again.
There are 2 problems I ran into:
1/ According to the manual I should be able to write multiple variables in one print statement. I cannot get it to work.
I tried all options (variables separated by space, comma, semicolumn, combinations), see below program, but none seem to work except individual writes (print #). By the way, this problem also exists for individual reads (input #).
2/ When audio is playing, it opens a file handle to the SD card. Not documented, I think this is file handle #1, since when I play audio, I cannot use #1 anymore.
Test code:
Print "test for SD card file access on Armmite F4"
a=100:b=200:d=300:e=400:c=-12
Print MM.Device$;" version";MM.Ver;" (version 5.05.10)"
Print
Print "original variables : "
Print a,b,c,d,e
Print
Print "individual write and individual read from file"
write5individual
read5individual
Print
Print "write 5 using print #1,a,b,c,d,e "
write5comma
read5individual
Print
Print "write 5 using print #1,a,;b,;c,;d,;e "
write5commacol
read5individual
Print
Print "write 5 using print #1,a;b;c;d;e "
write5col
read5individual
Print
Print "write 5 using print #1,a b c d e "
write5space
read5individual
Print
Print "individual write and individual read from file while playing sound"
Print
Play wav "tet16cut.wav"
write5individual
read5individual
End
Sub read5individual
Open "AA" For input As #1
Input #1,a
Input #1,b
Input #1,c
Input #1,d
Input #1,e
Print a,b,c,d,e
Close #1
End Sub
Sub write5comma
Open "AA" For output As #1
Print #1,a,b,c,d,e
Close #1
End Sub
Sub write5commacol
Print #1,a,;b,;c,;d,;e
Close #1
End Sub
Sub write5col
Print #1,a,b,c,d,e
Close #1
End Sub
Sub write5space
Print #1,a b c d e
Close #1
End Sub
Sub write5individual
Print #1,a
Print #1,b
Print #1,c
Print #1,d
Print #1,e
Close #1
End Sub
Terminal Output:
ARMmite F407 version 5.051 (version 5.05.10)
100     200    -12      300     400
100     200    -12      300     400
100     0       0       0       0
100     0       0       0       0
100     0       0       0       0
100     0       0       0       0
[71] Open "AA" For output As #1
Error: File number already open
Am I doing something wrong ? Or should these be documented ?
This is Armmite F4.
Edited 2020-08-02 22:51 by Volhout
Posted: 02:56pm 02 Aug 2020
I got bitten by a version of this 2 days ago. INPUT wants its variables to be comma-separated.
My problem was that I had commas in the text data I was trying to read. It's not in the manual, but the solution is to enclose text which includes commas in quotes: "Now, it works"
This gives what you're looking for with comma-separated numbers:
Sub write5commaSep
Print #1,a;",";b;",";c;",";,d;",";e
Close #1
End Sub
Then you can read back with: Input #1,a,b,c,d,e
(I don't know what playing sound might do to it)
Edited 2020-08-03 01:01 by lizby
CaptainBoing
Posted: 03:28pm 02 Aug 2020
  lizby said  ...INPUT wants its variables to be comma-separated....
Sub write5commaSep
Close #1
End Sub
Microsoft BASICs and others had a "Write" command for exactly this. it would write out comma separated values with a CRLF on the end which did precisely what you want (probably for the exact same reason)
e.g.
Write#2,10,20,30,a,b,c,d,e
would result in the line (e.g. with a-e = 1-5)
10,20,30,1,2,3,4,5
can't remember if strings written out were surrounded in quotes... think they were
http://www.cpcwiki.eu/index.php/Locomotive_BASIC#WRITE_.5B.23st.2C.5D_v.5B.24.5D.2C_v.5B.24.5D
https://www.qb64.org/wiki/WRITE_(file_statement)
https://docs.microsoft.com/en-us/office/vba/language/reference/user-interface-help/writestatement
It would not be easy to write a general SUB to WRITE that handled anything you threw at it due to the arbitrary number of things and types you might want to WRITE out.
Best approach is exactly as lizby shows above - a SUB that deals with the problem onto a target.
Edited 2020-08-03 01:33 by CaptainBoing
