Forum Index : Microcontroller and PC projects : CMM2 Turtle Graphics Demos
| Page 1 of 2 |
| Sasquatch Guru Joined: 08/05/2020 Location: United StatesPosts: 385 |
Here is a demo using turtle graphics, Each "slide" displays for 10 seconds. 'CMM2 Turtle Graphics Demo 'Adapted from various sources on the Internet 'by "Sasquatch" Mode 1,8 Draw(400,45.5) Pause(10000) Draw (500,55.5) Pause(10000) Draw (600,60.2) Pause(10000) Draw (800,89.5) Pause(10000) Draw (900,110) Pause(10000) Draw (1000,119.9) Pause(10000) Draw (1000,120.1) Pause(10000) Draw (1000,135.1) Pause(10000) Draw (1000,145) Pause(10000) Draw (1000,176) Pause(10000) Draw (1000,190) Pause(10000) End Sub Draw(Count,Angle) Turtle Reset N = 5 A = 90 For I = 1 To Count Turtle Forward N A = A + Angle Turtle Heading A mod 360 Turtle Pen Colour Map(I mod 255) N = N + 0.5 Next I End Sub -Carl |
This one uses recursion instead of looping. ' Hilbert Curve using recursion Mode 1,8 C = 1 Turtle Reset Turtle Pen Up Turtle Move 20,600 Turtle Pen Down 'Hilbert(Level,Angle,Length) Hilbert(7,90,6) Pause 10000 Turtle Reset Turtle Pen Up Turtle Move 150,550 Turtle Pen Down Hilbert(8,90,2) 'Pause 10000 End Sub Hilbert(Level,Angle,Length) If Level = 0 Then Exit Sub C = C + 0.1 Turtle Pen Colour Map(C Mod 255) TurnTurtle(Angle) Hilbert(Level - 1,0 - Angle, Length) Turtle Forward Length TurnTurtle(0 - Angle) Hilbert(Level - 1,Angle,Length) Turtle Forward Length Hilbert(Level - 1,Angle,Length) TurnTurtle(0 - Angle) Turtle Forward Length Hilbert(Level - 1,0 - Angle,Length) TurnTurtle(Angle) End Sub Sub TurnTurtle(Angle) If Angle > 0 Then Turtle Turn Right Angle Else If Angle < 0 Then Turtle Turn Left Abs(Angle) End If End Sub -Carl |
Recursive Fractal Trees! ' Recursive Fractal Trees Mode 1,8 Turtle Reset Turtle Pen Up Turtle Move 400,600 Turtle Pen Down Tree(120) End Sub Tree(Length) If Length < 1 Then Exit Sub If Length > 20 Then Turtle Pen Colour RGB(139,69,19) Else Turtle Pen Colour RGB(34,139,34) EndIf Turtle Pen Down Turtle Forward Length Turtle Turn Right 20 Tree(Length - 15) Turtle Turn Left 40 Tree(Length - 15) Turtle Pen UP Turtle Turn Right 20 Turtle Backward Length End Sub -Carl |
These Trees include a small amount of randomization making the trees look less uniform and more natural. ' Random Recursive Fractal Trees Mode 1,8 Turtle Reset Turtle Pen Up Turtle Move 400,600 Turtle Pen Down For X = 1 to 5 Tree(100) Pause(1000) Next X End Sub Tree(Length) If Length < 1 Then Exit Sub Local RndLength = Length + Rnd * 5 Local RndAngle = 15 + Int(Rnd * 20.0) If RndLength > 20 Then Turtle Pen Colour RGB(139,69,19) Else Turtle Pen Colour RGB(34,139,34) EndIf Turtle Pen Down Turtle Forward RndLength Turtle Turn Right RndAngle Tree(RndLength - 15) Turtle Turn Left RndAngle * 2 Tree(RndLength - 15) Turtle Pen UP Turtle Turn Right RndAngle Turtle Backward RndLength End Sub -Carl |
Sierpinski's Triangle Recursive Fractal. If you un-comment the pause statement, you will see that the entire thing is drawn as a series of tiny triangles. ' Sierpinski's Triangle Recursive Fractal Mode 1,8 Colour 0,RGB(255,255,255) Turtle Reset Turtle Pen Up Turtle Move 70,575 Turtle Turn Right 90 Turtle Pen Down Turtle Pen Colour 0 Sierpinski(650,7) End Sub Sierpinski(Length,Level) If Level = 0 Then For i = 1 to 3 Turtle Forward Length Turtle Turn Left 120 ' Pause(50) Next i Exit Sub EndIf Sierpinski(Length / 2.0, Level - 1) Turtle Pen Up Turtle Forward Length / 2.0 Turtle Pen Down Sierpinski(Length / 2.0, Level - 1) Turtle Pen Up Turtle Turn Left 120 Turtle Forward Length / 2.0 Turtle Turn Right 120 Turtle Pen Down Sierpinski(Length / 2.0, Level - 1) Turtle Pen Up Turtle Turn Left 60 Turtle Backward Length / 2.0 Turtle Turn Right 60 Turtle Pen Down End Sub -Carl |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12047 |
The Nautilus ' Square Nautilus Turtle Graphics Demo Mode 1,8 Size = 275 N = 100 Angle = 10 Ratio = 0.97 Turtle Reset For i = 1 to N 'Draw a square For j = 1 to 4 Turtle Forward Size Turtle Turn Left 90 Next j 'Rinse and Repeat Turtle Turn Left Angle Size = Size * Ratio Next i End -Carl |
Here is a recursive fractal pine tree: ' Recursive Fractal Pine Trees Mode 1,8 Turtle Reset Turtle Pen Up Turtle Move 400,500 Turtle Pen Down PineTree(100,20) End Sub PineTree(Length,Depth) ' Print Length If Depth <= 0 Then Exit Sub If Length > 2 Then Turtle Pen Colour RGB(139,69,19) 'Make the sticks brown Else Turtle Pen Colour RGB(0,100,0) 'Make the needles Green EndIf Turtle Forward Length PineTree(Length * 0.8, Depth - 1) Turtle Turn Right 120 PineTree(Length * 0.5, Depth - 3) Turtle Turn Right 120 PineTree(Length * 0.5, Depth - 3) Turtle Turn Right 120 Turtle Pen Up Turtle Backward Length Turtle Pen Down End Sub The second version includes a little randomization to make it less uniform ' Random Recursive Fractal Pine Trees Mode 1,8 Turtle Reset Turtle Pen Up Turtle Move 400,500 Turtle Pen Down PineTree(100,19) End Sub PineTree(Length,Depth) If Depth <= 0 Then Exit Sub Local Angle = 110 + 20 * Rnd() If Length > 5 Then Turtle Pen Colour RGB(139,69,19) 'Make the sticks brown Else Turtle Pen Colour RGB(0,100,0) 'Make the needles Green EndIf Turtle Forward Length PineTree(Length * 0.8, Depth - 1) Turtle Turn Right Angle PineTree(Length * 0.5, Depth - 3) Turtle Turn Right 120 PineTree(Length * 0.5, Depth - 3) Turtle Turn Right 240 - Angle Turtle Pen Up Turtle Backward Length Turtle Pen Down End Sub -Carl |
TassyJim![]() Guru Joined: 07/08/2011 Location: AustraliaPosts: 6626 |
Thank you for all the turtle demos. It brings back memories of my brother demonstrating turtle drawing 50 years ago. It was a new thing back then. My brother went on to be a much better programmer than I will ever be. Jim VK7JH MMedit |
Ok, this one is basically blowing my poor little mind. While it doesn't use Turtle Graphics it is a very interesting fractal known as the Barnsley Fern. I may "need" to do this one as a CSUB to see how fast it will fill. It would be interesting to zoom in if it would fill in faster. 'Barnsley's Fern Mode 1,8 CLS G = RGB(0,100,0) For i = 1 to 1000000 Select Case Rnd() Case IS < .01 NextX = 0 NextY = 0.16 * Y Case .01 TO .08 NextX = .2 * X - .26 * Y NextY = .23 * X + .22 * Y + 1.6 Case .08 TO .15 NextX = -.15 * X + .28 * Y NextY = .26 * X + .24 * Y + .44 Case Else NextX = .85 * X + .04 * Y NextY = -.04 * X + .85 * Y + 1.6 End Select X = NextX Y = NextY Pixel X * 100 + 400,600 - Y * 55 ,G Next i -Carl |
Turtle meets Dragon This is perhaps my favorite fractal line drawing. Especially neat is the way they fit together. In this code, the red and green dragons are identical, just rotated 180 degrees. And they fit together perfectly. It does look though that rounding errors are creeping into play here. The start point is fixed but the end point should also always end up the same. But if you watch closely between different orders, particularly the higher ones, the end point moves quite a lot. As a result, the green and red dragons must be the same order or they won't line up at all. Orders higher than 19 don't work because the draw distance becomes less than 1 so nothing beyond a single dot gets drawn. cls turtle reset text 100,500,"Dragon Curve - a Fractal","CT" do print @(0,520) "Order: (1-19)" input "0 to quit: "; dord loop until dord >= 0 and dord < 20 do if dord = 0 then end dord = dord - 1 dist = MM.HRES/2/(sqr(2)^dord) cls turtle reset text 80, 0,"Dragon Curve","CT",2 text 80,20,"Order:" + str$(dord+1), "CT",2 turtle pen up ' no line yet turtle move MM.HRES * .25, MM.VRES * .55 turtle pen down turtle heading 90 - (dord MOD 8) * 45 turtle pen colour rgb(red) DrawDragon(dord,1) turtle heading 270 - (dord MOD 8) * 45 turtle pen colour rgb(green) DrawDragon(dord,1) do print @(0,520) "Order: (1-19)" input "0 to quit: "; dord loop until dord >= 0 and dord < 20 loop sub DrawDragon(ord, sig) if ord = 0 then turtle forward dist else DrawDragon(ord-1, 1) turtle turn right 90 * sig DrawDragon(ord-1, -1) endif end sub Visit Vegipete's *Mite Library for cool programs. |
That is a nice one! At lower orders it doesn't give any clue as to it's potential. It amazes me how such a simple looking algorithm can generate something so complex. Thanks for sharing, if you have any other gems I'd like to see them. -Carl |
| capsikin Guru Joined: 30/06/2020 Location: AustraliaPosts: 342 |
Cool thread, there's some other recursive line fractals I'd like to try if I get time (I think I was inspired by one called the koch curve and I changed things around and got a new one with a kind of hexagonal pattern) |
Cool thread, there's some other recursive line fractals I'd like to try if I get time (I think I was inspired by one called the koch curve and I changed things around and got a new one with a kind of hexagonal pattern). Update: I gave it a quick try by modifying the Sierpinski program above. The rounding errors were already spoiling it before I got as much detail as I wanted. Here's the code I used: ' Hex Gasket Recursive Fractal Mode 1,8 Colour 0,RGB(255,255,255) Turtle Reset Turtle Pen Up Turtle Move 70,575 Turtle Turn Right 90 Turtle Pen Down Turtle Pen Colour 0 'Gasket(650,7) Gasket(650,5) End Sub Gasket(Length,Level) If Level = 0 Then Turtle Forward Length ' Pause(50) Exit Sub EndIf Turtle Pen Up Turtle Forward Length Turtle Pen Down Turtle Turn Left 120 Gasket(Length / 2.0, Level - 1) Turtle Turn Left 60 Gasket(Length / 2.0, Level - 1) Turtle Turn Left 60 Gasket(Length / 2.0, Level - 1) Turtle Turn Left 120 Turtle Pen Up Turtle Forward Length Turtle Pen Down End Sub I changed the program to exactly retrace the same lines when going backwards, rather than taking a shortcut. It's more complicated, but it cancels out the rounding errors: ' Hex Gasket Recursive Fractal Mode 1,8 Colour 0,RGB(255,255,255) Turtle Reset Turtle Pen Up Turtle Move 70,575 Turtle Turn Right 90 Turtle Pen Down Turtle Pen Colour 0 'Gasket(650,7) Gasket(650,10) End Sub Gasket(Length,Level) If Level = 0 Then Turtle Forward Length Turtle Pen Up Turtle Backward Length Turtle Pen Down ' Pause(50) Exit Sub EndIf Turtle Turn Left 60 Turtle Pen Up Turtle Forward Length/2 Turtle Pen Down Turtle Turn Right 180 Gasket(Length / 2.0, Level - 1) Turtle Turn Left 180 Turtle Turn Right 60 Turtle Pen Up Turtle Forward Length/2 Turtle Pen Down Turtle Turn Right 180 Gasket(Length / 2.0, Level - 1) Turtle Turn Left 180 Turtle Turn Right 60 Turtle Pen Up Turtle Forward Length/2 Turtle Pen Down Turtle Turn Right 180 Gasket(Length / 2.0, Level - 1) Turtle Turn Left 180 Turtle Pen Up Turtle Turn Right 180 Turtle Forward Length/2 Turtle Turn Left 60 Turtle Forward Length/2 Turtle Turn Left 60 Turtle Forward Length/2 Turtle Turn Right 60 Turtle Turn Right 180 Turtle Pen Down End Sub |
Good Job! MMBasic does make it easy to try changes quickly. I've added this one to my collection as well. -Carl |
| JohnS Guru Joined: 18/11/2011 Location: United KingdomPosts: 4390 |
Just in case anyone doesn't know, each dragon is the same as folding a piece of paper in half repeatedly (you can't do it much as it gets too thick) then opening it out so every crease is a right angle and viewing from an edge side. Origami... John |
| Atomizer_Zero Senior Member Joined: 04/07/2020 Location: United KingdomPosts: 134 |
Wow, these are awesome. I love seeing these patterns drawing and stuff. Before I got my CMM2, I played around in QBASIC 1 in DOS, and made this https://www.youtube.com/watch?v=zJe2Ajp2eVg Keep em coming! |
bigmik![]() Guru Joined: 20/06/2011 Location: AustraliaPosts: 2982 |
Hi Pete, That code fails for anything after Option 3.. I think it is to do with negative angles. Maybe something changed in a later version of MMBasic, I am using 5.05.04 There is also an error in the Barnsley Fern by sasqatch. Kind Regards Mick Mick's uMite Stuff can be found >>> HERE (Kindly hosted by Dontronics) <<< |
Maybe something changed in a later version of MMBasic, I am using 5.05.04 Mick Yep. All fixed in the latest beta. Jim VK7JH MMedit |
Thanks Jim, I thought it was firmware differences, I will try the latest beta.. I usually stick to the latest release version Regards, Mik Mick's uMite Stuff can be found >>> HERE (Kindly hosted by Dontronics) <<< |
| Page 1 of 2 |
