Forum Index : Microcontroller and PC projects : Graphics Programming on the CMM2 -v1.0e
| panky Guru Joined: 02/10/2012 Location: AustraliaPosts: 1135 |
This update to the manual includes additional info from Peter on Quaternions and the FRAMEBUFFER command as well as a Table of Contents with clickable links to the various sections. If you find any typos or errors, please reply to this post. For Geoff - this updates the version you have that is included in the CMM2 release pack. Doug. Graphics Programming on the CMM2-v1.0E.pdf ... almost all of the Maximites, the MicromMites, the MM Extremes, the ArmMites, the PicoMite and loving it! |
| fiziwig Newbie Joined: 09/07/2020 Location: United StatesPosts: 22 |
This is great! Thank you. Just what I've been needing. |
| capsikin Guru Joined: 30/06/2020 Location: AustraliaPosts: 342 |
One bit that's now out of date: OPTION MODES UNLOCKED is no longer required or available, from my reading of this thread |
| Geoffg Guru Joined: 06/06/2011 Location: AustraliaPosts: 3369 |
Thanks Doug. I have updated the release zip. Geoff Graham - http://geoffg.net |
TassyJim![]() Guru Joined: 07/08/2011 Location: AustraliaPosts: 6626 |
You might like to update the test card program to cover the new modes. ' test card for CMM2 ' TassyJim August 2020 OPTION EXPLICIT OPTION DEFAULT NONE DIM INTEGER wd, ht, wbox, sh, x, w, n, nn, m, cd, maxMode, keepMode DIM FLOAT a, defaultMode DIM k$, imgtitle$, fname$, imgRes$ DIM INTEGER c(8) c(0) = RGB(BLACK) c(1) = RGB(YELLOW) c(2) = RGB(CYAN) c(3) = RGB(GREEN) c(4) = RGB(MAGENTA) c(5) = RGB(RED) c(6) = RGB(BLUE) c(7) = RGB(WHITE) c(8) = RGB(64,64,64) maxMode = 9 cd = 8 a = 1 defaultMode = MM.INFO(MODE) CLS DO IF m = 0 THEN MODE 1,8 CLS TEXT 400,100, "Video mode test",cm,5,1 TEXT 400,180, "Ratio = aspect ratio used in the circle command",cm,1,1 TEXT 400,220, "Q to quit, P to save page as a BMP",cm,3,1 TEXT 400,260, "Up Down arrow to change resolution",cm,3,1 TEXT 400,300, "Left Right arrow to change colour depth",cm,3,1 TEXT 400,340, "+ - to change circle aspect ratio",cm,3,1 ELSE IF keepmode THEN ' only change resolution if needed keepmode = 0 ELSE MODE m,cd ENDIF wd = MM.HRES : ht = MM.VRES nn = INT(wd/80) imgtitle$ =" MODE "+STR$(MM.INFO(MODE))+" Ratio "+STR$(a,1,3)+" " imgRes$ = " "+STR$(MM.HRES)+" x "+STR$(MM.VRES)+" " wbox = wd / 8 PAGE WRITE 1 ' no flicker during write CLS ' primary colours FOR x = 0 TO 7 BOX x*wbox,ht/4,wbox,ht/2,0,c(x), c(x) NEXT x ' full gradient for each primary colour and greyscale FOR x = 0 TO wd-1 sh = 255*x/wd LINE x,0,x,ht/12,1,RGB(sh,0,0) LINE x,ht/12,x,ht/6,1,RGB(0,sh,0) LINE x,ht/6,x,ht/4,1,RGB(0,0,sh) LINE x,ht*9/12,x,ht*10/12,1,RGB(0,sh,sh) LINE x,ht*10/12,x,ht*11/12,1,RGB(sh,0,sh) LINE x,ht*11/12,x,ht,1,RGB(sh,sh,0) LINE x,ht/2,x,ht*3/4,1,RGB(sh,sh,sh) ' greyscale NEXT x ' circle to check aspect ratio CIRCLE wd/2,ht/2, ht*15/32,3,a,c(7) sh = 0 x = wd/2 - 55*nn/2 ' black white bars to check monitor bandwidth FOR w = 10 TO 1 STEP -1 FOR n = 1 TO nn sh = 255 - sh LINE x,ht*3/8,x,ht*5/8,w,RGB(sh,sh,sh) x = x + w NEXT n NEXT w ' white and red border to check that image fits on monitor BOX 0,0,wd,ht,3,c(7) BOX 1,1,wd-2,ht-2,1,c(5) ' title IF wd > 600 THEN TEXT wd/2,ht/2, imgtitle$,cm,4,1 TEXT wd/2,ht/2+25, imgRes$,cm,4,1 ELSE TEXT wd/2,ht/2, imgtitle$,cm,1,1 TEXT wd/2,ht/2+25, imgRes$,cm,1,1 ENDIF ' show the new image PAGE COPY 1 TO 0 ,B ENDIF ' wait for keypress DO k$ = INKEY$ LOOP UNTIL k$<>"" ' SELECT CASE k$ CASE "Q","q" EXIT DO CASE "P","p" fname$ = MID$(imgtitle$,2)+".bmp" TIMER = 0 SAVE IMAGE fname$ PAGE WRITE 0 TEXT wd/2,ht/2,"Saved as "+fname$+" in "+STR$(TIMER/1000,3,2)+" Sec" ,cm,1,1 DO k$ = INKEY$ LOOP UNTIL k$<>"" CASE CHR$(128) ' up arrow m = m - 1 IF m < 1 THEN m = maxMode CASE CHR$(129) ' down arrow m = m + 1 IF m > maxMode THEN m = 1 CASE CHR$(131) ' right arrow res up cd = cd + 4 IF cd > 16 THEN cd = 8 IF m = 9 AND cd = 12 THEN cd = 16 ' skip 12 bit for mode 9 CASE CHR$(130) ' left arrow res down cd = cd - 4 IF cd < 8 THEN cd = 16 IF m = 9 AND cd = 12 THEN cd = 8 ' skip 12 bit for mode 9 CASE "+" ' ratio plus IF a < 1.4 THEN a = a + 0.01 keepmode = 1 CASE "-" ' ratio minus IF a > 0.75 THEN a = a - 0.01 keepmode = 1 CASE ELSE ' same as down arrow m = m + 1 IF m > maxMode THEN m = 1 END SELECT LOOP setmode defaultMode ' restore original mode before ending program PAGE WRITE 0 CLS END SUB setmode dotMode AS FLOAT LOCAL INTEGER mm, md ' use float returned by mm.info(mode) to set MODE mm = INT(dotmode) md = (dotmode - mm)*100 IF md > 20 THEN md = md/10 MODE mm, md END SUB Jim VK7JH MMedit |
| Andrew_G Guru Joined: 18/10/2016 Location: AustraliaPosts: 906 |
Hi Doug, a great idea, and effort, to immortalise Peter's words into a document and great to have it as part of the documentation. One suggestion if I may? Can you possibly omit the word "Page" (or use "Pge") from the footer of future versions. This would make searching for "PAGE" sooooo much easier. Thanks again, Andrew |
Thanks Jim and Andrew, I am working on the 5.05.05 version now and will incorporate your inputs. Doug. ... almost all of the Maximites, the MicromMites, the MM Extremes, the ArmMites, the PicoMite and loving it! |
| chris Regular Member Joined: 24/08/2020 Location: United KingdomPosts: 56 |
What is the difference between the FRAMEBUFFER and pages. Naively, I thought pages were the abstraction of the FRAMEBUFFER (make changes on page 1, blit to page 0). For example, in the "Graphics Programming on the CMM2 PDF", there is a snippet of code that refers to pages as framebuffers. 'clear the first three framebuffers (pages) I am not at all a proficient graphics programmer, and this is my very first rodeo, so if someone could explain in simple language what to use PAGE 0, FRAMEBUFFER, and PAGE 1 .. n for then it would be much appreciated. I think PAGE 0 is special and it is the the page that is asynchronously rendered to the screen so if you are writing during a screen refresh then you have glitches, so I just assumed that you prepare your frame in one of the other pages, then blit it to page zero on an interrupt. I really really don't know what I'm doing, so please be kind. |
| Nimue Guru Joined: 06/08/2020 Location: United KingdomPosts: 450 |
Oh my -- you asked the question I wanted to, but felt I should already know the answer to. Q: Is there an "essential" guide to this (probably from the 1980's) that is worth a read? Entropy is not what it used to be |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12047 |
The graphics guide was written before the "framebuffer" was included in the firmware. Pages are 1:1 memory areas that are the equivalent size to what is displayed on the monitor so you can copy one page to another with PAGE COPY. Video pages use dedicated RAM out of a pool of 3.5Mbytes. The framebuffer is an area of memory that can be up to 1600x1200 pixels in size irrespective of the current mode. The memory for the framebuffer is taken from the 5Mb of variable memory. Rather than PAGE COPY you use FRAMEBUFFER WINDOW to move data from the framebuffer to main memory. This allows you to have a playing field bigger than the display and window what is displayed on the screen to different part of the field with a single command. There are other things you can do with the framebuffer as detailed in the manual (check out BACKUP and RESTORE). An simple example of using the framebuffer is shown here This a concept I created for the CMM2 so you won't find it documented elsewhere Edited 2020-09-07 20:46 by matherp |
I have updated the Graphics Programming manual to version 2.0a to include the new features from MMBasic 5.05.05. I have also added an introductory section on colour - I am sure I will get a sharpish rap on the knuckles from Peter if there are errors or omissions Graphics Programming on the CMM2-v2.0a.pdf Please do not hesitate to let me know of any errors, omissions or suggestions for improvement. Doug. ... almost all of the Maximites, the MicromMites, the MM Extremes, the ArmMites, the PicoMite and loving it! |
Updated the CMM2 download (https://geoffg.net/Downloads/Maximite/Colour_Maximite_2_MMBasic.zip ). Thanks. Geoff Geoff Graham - http://geoffg.net |
