Local Time 18:12 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2 "Traffic Lights" on screen and LEDs - LEDs flash on RUN
Nimue
Posted: 08:49pm 11 Aug 2020
Hi all
Testing linking on screen "action" to the physical, so I built some traffic lights that draw a crude set on screen and light some LEDs in time.
All works well and as expected -- except, when the program is RUN for a brief moment (and I mean a literal twinkle) -- the LEDs flash.
My code has only the GREEN LED set as I wondered if it was my wiring -- but with just the green present, it still flashes briefly on run.
Is this default behaviour as PIN 5 is not set until the program actually runs?  Happy if that is the case (just wondering).
Is it possible to set some default values so that the output from all pins is LOW before they are initialised (not sure if this is a daft question).
Anyway my code -- happy for imprvements:
mode 1,8
cls
'Here I will define 3 pins for LEDs
SETPIN 5,DOUT
PIN(5)=0
'Draw the traffic light frame
box 220,70,60,160,2,rgb(white),rgb(black)
'Subs for the states of the lights
Sub RED
 ' SETPIN 7,DOUT
 circle 250,100,25,2,,rgb(red),rgb(red)
 circle 250,150,25,2,,rgb(black),rgb(black)
 circle 250,200,25,2,,rgb(black),rgb(black)
 PIN(5)=0
end sub
Sub RedAmber
 circle 250,150,25,2,,rgb(255,165,0),rgb(255,165,0)
 PIN(5)=0
end sub
Sub Green
 circle 250,100,25,2,,rgb(black),rgb(black)
 circle 250,200,25,2,,rgb(green),rgb(green)
 pin(5)=1
end sub
sub Amber
 pin(5)=0
end sub
Do  ' cycle the lights forever
 RED
 pause 2000
 RedAmber
 pause 2000
 Green
 pause 2000
 Amber
 Pause 2000
 Red
Nimue
Posted: 09:19pm 11 Aug 2020
Ok, so not solved but have a solution for my students....
On first run, the traffic lights need to enter a self test to make sure they all light -- so, on RUN light all and FLASH them to prove they work.
Then enter the real sequence.
Still be interested in the reason they briefly flash....
Nim
CircuitGizmos
Posted: 09:22pm 11 Aug 2020
What is your hardware circuit? Do you have a resistor pulling the pin to an inactive state?
Nimue
Posted: 09:33pm 11 Aug 2020
  CircuitGizmos said  What is your hardware circuit? Do you have a resistor pulling the pin to an inactive state?
Pin(5) to 2k resister through to LED and then through to ground
Am I missing some electronic-fu?  It's been a long time since I learned all this..... pull up / pull down....
N
Nimue
Posted: 09:43pm 11 Aug 2020
Yes missing a pulldown.
Added 1K to pull down -- all fine now.
As I said, been a long time.
Thanks for the steer.
Nim
Edited 2020-08-12 07:43 by Nimue
Posted: 09:54pm 11 Aug 2020
One useful thing to remember when connecting to the real world.
SETPIN 5,DOUT
PIN(5)=0
You will have a short period between the two lines when the output is whatever the CPU decides, not necessarily what you want.
This will be too fast to see but can trigger unwanted events in external circuitry.
If you swap the order of the commands,
PIN(5)=0
SETPIN 5,DOUT
You will be sure that the pin initializes in the low state.
There is still the time from first applying power to running the program that might cause issues so external pull-downs/ups etc are still worth considering.
Nimue
Posted: 09:59pm 11 Aug 2020
  TassyJim said  One useful thing to remember when connecting to the real world.
PIN(5)=0
SETPIN 5,DOUT
Done - plus pull down added.
Now behaving properly.
I left the "self test" idea in -- the students will, I am sure have "fun" designing a test pattern for the lights -- I assume that in the real world, there is a test pattern that lights have --- need a traffic engineer to ask!
Thanks all.
Nim
Posted: 10:56pm 11 Aug 2020
I just realised what was bothering me.
Your simple LED circuit shouldn't be troubled by a powerup 'high'
There is a good reason why it is suffering.
Pins 3 and 5, 27 and 28 are all used for I2C (as well as general IO).
They all have 10k pullup resistors fitted between the pin and 3.3V.
It is those 10k pullup resistors that caused your LED to flash.
Using a different pin would not have the problem, although setting the pin level before setting it as output is still a good idea.
I remember making traffic light during a PLC training course, many years ago.
One of the posters here made an elevator control system using a micromite.
There are lots of real-life things for your students to play with.
Andrew_G
Posted: 11:41pm 11 Aug 2020
Hi Nim (again),
You said you might need input from a Traffic Engineer, how about one with 40+ years experience (I won't bore you with the details but trust me I DO know traffic signals) including those on the Manchester Outer Ring Road, Denton to Middleton section.
There is not a test pattern as such but on every re-start they have steady "all red" for say 8 seconds then flash "yellow" (not "amber") for say 8 seconds and then the green for the main traffic movement (best to check what the UK practice is - the above timings are programmable).
(If I forget, the UK and its colonies, use a short Yellow/Red sequence before the green - in Australia we no longer do (some councils in Victoria used to).
Certainly doing it in software on screen will be much easier than using LEDs etc but see how you go.
These may be useful but are more expensive than separate LEDs. . .
Cheers,
Andrew
(I've always thought of writing a student-level tome about traffic signals and link to the www for more information)
Edited 2020-08-12 10:01 by Andrew_G
Nimue
Posted: 09:30am 12 Aug 2020
This >>>
Doh.
Revising pin usage.  Good spot.
Other good practise incorporated.
Nim
Nimue
Posted: 09:35am 12 Aug 2020
  Andrew_G said  Hi Nim (again),
There is not a test pattern as such but on every re-start they have steady "all red" for say 8 seconds then flash "yellow" (not "amber") for say 8 seconds and then the green for the main traffic movement...
I wanted them to code away from the hardware first - then to move to setting pins etc.  CMM2 makes that really easy.
I was today years old when I knew I needed these.... thanks for sharing.
What's really interesting is just how unaware of the world around them students are -- do it!!  I miss good "old fashioned" (and I mean that positively) text books.
Nim
