Local Time 02:25 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : where does the framebuffer live in memory?
berighteous
Posted: 01:56am 17 Aug 2020
Hi!
Where does the frame buffer live in memory?  Does it occupy the same memory as regular video pages?
vegipete
Posted: 02:56am 17 Aug 2020
Test the command "mm.info(page address framebuffer)"
Edit:
Or maybe not. With or without framebuffer defined, it returns the same as "mm.info(page address 0)"
I guess it's a request for matherp.
Maybe a loop peeking through all of memory could find it ...
Edited 2020-08-17 13:04 by vegipete
berighteous
Posted: 03:23am 17 Aug 2020
it gives the same address as page 0.
Edited 2020-08-17 13:25 by berighteous
Posted: 07:05am 17 Aug 2020
The framebuffer is allocated in variable memory when the create command is used. A second copy is allocated when the backup command is used. The position in memory is dependent on other variable use before the framebuffer command. It is not fixed. I'll include
  Quote  MM.INFO(FRAMEBUFFER)
in the next beta (V5.05.05b11) to give its address
Edited 2020-08-17 18:14 by matherp
berighteous
Posted: 04:46pm 17 Aug 2020
We're up to b11 now?  wow.  You the man!
